Question about Evesham Nav-Cam 7700 GPS Receiver
Nav cam 6400
Sat nav was plugged into incar charger via cig lighter ,working ok , the for no reason it turned of and has never been able to switch on .have tried to reset ??????????? help from someone out there appreciated as have tried to contact sales support on 4 occations , each time holding for 20 to 30 mins being driven to near suicide by the hold music and promises of your call will be answered shortly aaaaaaaagggggggggggg!!!
Re: nav cam 6400
Well one thing is certain after reading all the problems involving this Evesham GPS receiver sure makes me aware that I will look at a lot of other brands before I buy any GPS system.
Posted on Feb 26, 2008
0 characters
3 Points
My tomtom go 510 will not charge in car but ok at home
The Car chargers are generally the defective unit.
I have also faced a similar issue as the spring loaded cigarette lighter was pushing the charger causing it to disconnect.
Jul 31, 2016 | Tomtom GPS Devices
Just purchased a Via 135 sat nav unit after 2 days it shut down and refused to come back on. Returned to supplier who replaced it only for that 1 to shut down also. Any ideas.
Possibly both died due to a voltage overload, test the power output from the car charger. Anything over 5.6volts and the car has a faulty cig lighter port. Get it fixed
Oct 28, 2013 | Tomtom GPS Devices
Am holidaying in spain, have hired a c max and do not think the 12v lighter supply is working so sat Nav wont recharge. is there a switch or key position i'm missing as have not driven a c max previously....
Hi, their is no switch or key to get it working, on this car it should start working as soon as you turn the ignition on so as your driving it should be charging.
the only reasons it may not be working could be a fuse or some one may have shorted it out by leaving the cig lighter down to long.
have a look in the glove box and see if the owners handbook is in their if it is have a look in their at the fuse box diagram and locate the fuse for the aux cig lighter then check if the fuse has blown, if it has blown their should be a spare fuse in the fuse box and it should tell you this in the owners handbook,
if how ever the fuse is ok then this means some one has shorted the lighter out and the only way of getting it working is to get the main part replaced and as this is higher car its something you wont be doing.
i would check the fuse and if its blown put the spare in or if their is no spare then it would be worth buying one as they cost next to nothing to buy.
let me know how you get on or if you need further assistance ok
Aug 16, 2010 | GPS Devices
When I power my sat nav through my computer using a USB lead the sat nav works properly (ie the screen display is perfect) when I use the sat nav in my car using my cigarette lighter as the power supply...
Hi Ernie, as you've already tried two different chargers, it sounds clear that it's not a charger problem. But, did you try also a different cigarette lighter? The problem may due to your car CL over power (maybe a fuse went...) If it doesn't work please let me know, we'll try smth different. Regards, Peter
Aug 07, 2010 | MyGuide 3100 GPS Receiver
Where to get in car charger for evesham 7211
I just bought an in-car charger for the 7211 on ebay.
It is 5v with a 2amp flow.
It's not for the mini-USB port on the side but for the dc input hole on the other side.
I've just plugged it into my laptop via the mini-USB port to see if it will charge that way but it doesn't seem to be doing.
Hope this helps.
Aug 09, 2009 | Evesham Nav-Cam 7700 GPS Receiver
No charger with my evesham 6400 sat nav
This should of came with the charger. I would complain.
You can probably get the charger on ebay as well, otherwise the Evesham web site
Aug 06, 2009 | Evesham Nav-Cam 7700 GPS Receiver
3 amp fuse in sat nav power lead keeps blowing
possibly a spike through the ciggarette lighter plug, try putting slightly larger fuse in ( 4 or 5 amp )
temporarily and see if it blows the slightlty larger fuse. if it does it's more likely to be something wrong with the ciggarette lighter socket if it doesn't blow the fuse it's more likely to be the power supply. Ebay for another one perhaps ??
Apr 13, 2009 | LG GPS Devices
Evesham sat nav update??
Evesham is no longer in business but the following url is for a company that supports their products..
As a matter of fact, I understand this company has ex-Evesham employees. Good Luck and please rate this solution..
Apr 07, 2009 | Evesham Nav-Cam 7700 GPS Receiver
Looking for a power adapter that plugs into the cigerette lighter for my Nav-Cam 7000 and I can't find where to purchase one.
go onto ebay, they start from 99p + p&p. they have car chargers and 2 & 3 pin plug chargers. good look.
Mar 10, 2009 | Navigator Evesham Nav-Cam 7000 GPS...
Evesham Nav-Cam 7700 GPS Receiver Logo
91 people viewed this question
Top Evesham GPS Devices Experts
Juriy Crook
Juriy Crook
Are you an Evesham GPS Device Expert? Answer questions, earn points and help others
