Question about Creative Labs ZEN Vision:M Digital Media Player
My zen vision m player is stuck on lock
My creative zen vision m player is stuck on lock, have tried reseting via the pin hole but still button appears stuck on lock. , even after timeing out then restarting.
    President:
  • 392 Answers
Check the hold button...is it set to on position..?
Posted on Sep 11, 2009
My creative zen micophoto will not boot up what do
Hi.
You tried these yet?
Reset, Format or Clean Up a Zen Vision:M
If your player stops responding, you can reset it. To reset the player, push the end of a pin-like object (for example, a pin or straightened paperclip) into the Reset hole. This should not cause you to lose any data or audio tracks, unless you were in the middle of transferring an audio track.
To reset Zen Vision:M to factory default settings:
  1. Press on the Menu/Back button on your player, and select System, and then Reset.To Format or Clean Up Zen Vision:M Detach the Zen Vision:M player from your PC , and ensure that the unit is off.If the battery is too low, charge the battery fully before continuing
  2. Slide the Power switch towards the Power icon and hold the switch in the Power On position.
  3. Push the end of a pin-like object (for example, a straightened paper clip) into the reset hole, press gently and remove.
  4. Release the Power switch when the Creative logo appears. The Recovery Mode appears: * Clean Up (Performs a disk scan on the player's hard disk, it will not affect music files)* Format All (Formats the players hard disk - Note: all contents will be lost)* Reload Firmware (Reloads the Operating System on the Zen. Select this option ONLY if there is a firmware available to reload.)* Reboot (Reboots the device)
  5. Select Clean Up or Format from the Recovery Mode, and then select Reboot
Good Luck^^
Nov 02, 2009 | Audio Players & Recorders
My Zen vision: M is stuck in hold. Sliding the switch does nothing except make the hold symbol blink when slid all the way to the power on/off position.
Support for Zen Vision M on this site:
http://support.creative.com/Products/ProductDetails.aspx?catID=213&CatName=MP3+Players&subCatID=214&subCatName=ZEN&prodID=14331&prodName=ZEN+Vision%3aM
Enter the word "hold" in the bar Knowledgebase Solutions.
This will give you access to various answers.
One answer could be to do a recovery:
  1. Slide the power button towards the power icon and hold it in the Power ON position
  2. While holding on to the power button, Gently push the end of a thin object (such as a pin or straightened paperclip) into the Reset hole.
    The reset button for your player is located at the bottom of the player, to the left of the sync adapter port.
  3. Release the power button when the Creative logo appears.
  4. The Recovery Mode screen appears, and four menu items are shown: Clean Up, Format All, Reload Firmware and Reboot.
  5. To clean up your player's memory, select Clean Up.
  6. When the cleanup is complete, select Reboot. Your player restarts and starts rebuilding its music library.
  7. Should the above solution is unable to resolve the issue, please install the player's latest firmware. To obtain further instruction on getting the firmware reload into the player, you can refer to the following article:
    SID 63033 - Reloading Firmware / Formatting your Player
Jul 28, 2009 | Creative Labs ZEN Vision:M Digital Media...
My creative zen screen wont light up its dark i tried the light up feature but no luck
1. Detach the Zen Vision:M player from your PC , and ensure that the unit is off.
* Reboot (Reboots the device).
5. Select Clean Up or Format from the Recovery Mode, and then select Reboot.
hope this helps you
Jul 24, 2009 | Creative Labs ZEN Stone MP3 Player
Firmware Problem?
If a reset does not work using the reset hole, then try this: First, back up all of your music and do this: Turn off the player and disconnect it from the computer. Then press and hold the play/puse button and turn it on simultaneously. The player should be in recovery mode. Scroll down and select format (all) and let it format. Then reload all of music back onto your player and it should work like new. Hope this helps!
May 03, 2009 | Creative Labs ZEN Vision:M Digital Media...
Creative Zen Vision M stuck when turning on.
If it is under warranty, get it replaced. The firmware is corrupted and unless the computer recognises it, you can't restore the firmware. If you can get it to come up to the maintenance menu you may be able to reset the player.
Best wishes
Jan 31, 2009 | Creative Labs ZEN Vision:M Digital Media...
Zen player stuck on -shutting down
Try to find a small hole with the text "Reset" next to it. Find something small(paper clip for instance) and simply just press the button inside the hole, you will hear a small "click".
Jan 25, 2009 | Creative Labs ZEN Vision:M Digital Media...
Creative zen m vision won't start up,
http://dmzweb4.europe.creative.com/...com:80,Case=obj(14048),Kb=ww_english_add
pls rate it, thanks
Nov 12, 2008 | Creative Labs ZEN Vision:M Digital Media...
ZEN VISION M
This sounds like it might be a hard drive problem. To put it into Recovery Mode, do this: put a paperclip in the Reset hole while holding the power button in the On position. Then release the paperclip and continue to hold the power button until it goes to the Recovery Mode screen. You should at this point try Format and Scan Disk/Cleanup, then Reboot. If it still gets stuck at the same spot, then its going to be a hardware failure.
Click here to view my step-by-step troubleshooting guide.
Click here to send in your device for free diagnostic testing.
Sep 03, 2008 | Creative Labs ZEN Vision:M Digital Media...
My zen is freezeing
1. I'd try a system clean up first (instructions below)
2. definitely upgrade your firmware (http://us.creative.com/support/downloads/)
3. If all else fails, back up all your music on your PC and format it (instructions below)
.... from Creative's site
Reset, Format or Clean Up a Zen Vision:M If your player stops responding, you can reset it. To reset the player, push the end of a pin-like object (for example, a pin or straightened paperclip) into the Reset hole. This should not cause you to lose any data or audio tracks, unless you were in the middle of transferring an audio track.
  1. Detach the Zen Vision:M player from your PC , and ensure that the unit is off. If the battery is too low, charge the battery fully before continuing
  2. Slide the Power switch towards the Power icon vision_m_reset.jpgand hold the switch in the Power On position.
  3. Push the end of a pin-like object (for example, a straightened paper clip) into the reset hole, press gently and remove. vision_m_reset1.jpg
    • Clean Up (Performs a disk scan on the player's hard disk, it will not affect music files)
    • Format All (Formats the players hard disk - Note: all contents will be lost)
    • Reload Firmware (Reloads the Operating System on the Zen. Select this option ONLY if there is a firmware available to reload.)
    • Reboot (Reboots the device).
Jan 05, 2008 | Creative Labs ZEN Vision:M Digital Media...
Creative Labs ZEN Vision:M Digital Media Player Logo
572 people viewed this question
Top Creative Labs Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Are you a Creative Labs Audio Player and Recorder Expert? Answer questions, earn points and help others
