Question about Epson Aculaser C1100 Printer
Epson Acculaser c1100 ink blead
Epson Acculaser C1100 model KBB1a colour blead and patchy coverage. New toner cartidge fitted and made no difference.
    Scholar:
  • 81 Answers
First rule out that it is a paper issue by trying a different type of paper
If that dosnt work
check if the gradation setting is too small when printing graphics. On the Basic Setting menu in the printer driver, click More Settings, adjust the gradation setting by sliding the Contrast slider bar
If that dosnt work
Clean the print head .
see steps at the bottom
If that dosnt work
It is starting to look like drum/photoconductor problem, this may need to be replaced (the most expensive solution)
Follow the steps below to clean the printer head.
Epson Acculaser c1100 ink blead - r_1.gif Open the cleaner cover on the right side of the printer. Then, open cover A. d580095.gif
Epson Acculaser c1100 ink blead - r_2.gif r_2.gif Pull the blue lever Epson Acculaser c1100 ink blead - d580096.gift inside of the printer. d580096.gif
r_3.gif Move the blue clEpson Acculaser c1100 ink blead - r_space.gify in and out once. d580097.gif
Epson Acculaser c1100 ink blead - r_space.gif src="http://i.fixya.net/uploads/images/r_spaceEpson Acculaser c1100 ink blead - r_space.gifr_space.gif" class="h_mi" /> r_note.gif Note: r_space.gif r_space.gif Move the cleEpson Acculaser c1100 ink blead - r_5.gifmpletely in and out. Otherwise, the printer may not be cleaned effectively. Push back the blue lever on the right inside of the printer. d580098.gif
Posted on Sep 11, 2009
My Epson Aculaser C1100 shows 'change toner K'
I've just replaced the the Yellow and Magenta colour toner based on your fantastic advice...
gbdmequick
Jul 17, 2012 | Epson Aculaser C1100 Printer
I keep getting a message on the printer saying install C TnrCart Ive repeated the process twice and installed a new toner but it keeps saying it?
Epson C1100 toner detection is based on freq. your chip on the toner might be old or faulty.
The toner does not have contact point.. at the right side of the printer, there is a receiver, and at the side of the toner, there is a round chip..
Apr 07, 2010 | Epson Aculaser C1100 Printer
How do you remove the other cartridges from the Epson Aculaser C1100? The Cyan cart is at the rear and easily accessable. I cannot see any levers, etc to access other cartridges and the download setup does...
On the left hand side is a lever. Pull down door 'A' and on the Left hand side you will see the arrow indicating the toner guide placement.
Directly to the left of this is a slot. Insert a biro (screwdriver or whatever fits) into it and push the lever UP to allow free rotation of the drum assembly.
Mar 10, 2010 | Epson Aculaser C1100 Printer
Epson acculaser c1100 ink replacement
K- black
M- Magenta (red)
Y- Yellow
C- Cyan (blue)
Hope this helps.
Jul 03, 2009 | Epson Aculaser C1100 Printer
What colour is K on low ink
Toner K low refers to the black toner.
May 15, 2009 | Epson Aculaser C1100 Printer
Replace toner problem
To replace the cartridges before they are actually empty you should:
  1. Navigate to the reset menu (using down arrow)
  2. Select this (right arrow)
  3. Navigate till you get to Change Toner x (where x is the colour)
  4. Select this.
  5. Wait for the printer to stop churning.
  6. Open the front door and you should see the correct toner cartridge at the back.
  7. Follow the instructions just inside the door (or on the cartridge box.)
Feb 16, 2009 | Epson Aculaser C1100 Printer
How to install toner chip on epson c1100
The toner chip is situated on the end of the toner cartidge - it's a circle, about 1.5cm in diameter.
They may have given you a new housing, in case you damage the one currently on your toner, when you try to remove it.
Nov 15, 2008 | Epson Aculaser C1100 Printer
Epson C1100 - Vertical faint stripes on colour photos
see if this solution fixes the problem.
Also clean the print head using instructions in the manual
http://www.fixya.com/support/t241840-smudges_color_printing_black_ok
Mar 04, 2008 | Epson Aculaser C1100 Printer
Epson aculaser c1100 cant access empty ink cartridge.
go to the reset menu (right arrow and then down arrow until reset menu is displayed) on the lcd display and then choose change toner #(right arrow until the desired toner is displayed) Hope this helps
Sep 27, 2007 | Epson Aculaser C1100 Printer
Epson c1100
Yes, they do make this model, I'm using one now. I had the same problem
The solution for me was to clean inside of printer thoroughly, with the C (or whatever) cartridge removed. The sensors get dirty.
Sep 04, 2007 | Epson Aculaser C1100 Printer
Epson Aculaser C1100 Printer Logo
157 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
