Question about Insignia Sport MP3 Player
Ce 1177 the battery wires disconnected
Ce 1177 the battery wires have become disconnected
Can I get a replacement battery?
    Problem Solver:
  • 6 Answers
Yes but u have to get it were u got it from
Posted on Sep 11, 2009
What monitor can I use with a lenovo ce 1177
Almost any with a VGA plug will work. It should automatically reconfigure the size and resolution of the external screen.
Sep 18, 2016 | Lenovo Computers & Internet
Battery was dead, charged it, started jeep but will not keep running, is it the battery
It could be the battery, yes, but it could also be an alternator fault.
If the alternator is faulty -( usually when the rectifier pack on the back of the alternator burns out) - the battery can run to earth and become flat within seconds, or it feels like a misfire when driving.
I once had a car that needed the battery charging every time just in order to start it. Once running, there was a misfire. Then the battery was too flat to restart the car. It was an alternator fault.
Disconnect the plug/wiring from the rear of your alternator FIRST. Charge the battery. Leave the plug DISCONNECTED from the rear of the alternator. Start your vehicle.
If your vehicle starts and runs ok with the alternator wiring disconnected - the alternator is suspect. The usual culprits are the diodes in the rectifier pack (the bit on the rear of the alternator). Burnt out, they can cause a battery to become flat within - literally - seconds.
Leave the alternator disconnected and try starting the car several times. Switch on your headlamps and try and restart the vehicle a few times over a 15 minute period.
If it continually starts even when the headlamps are on, your battery probably is ok.
Even better ... take your vehicle to an auto electrician. It would probably take 2 minutes for them to dignose the problem. this saves you 'guessing' and buying replacement battery/parts that aren't at fault.
It doesn't sound as though you have a big problem .. just one of the many 'irritations' that we motorists suffer...
If the problem is the alternator there's no need to replace the whole unit - you can replace the rectifier pack on the rear. If it is the battery at fault (an auto electrician will tell you within seconds) .. well, that's life.
Jul 11, 2014 | 1999 Jeep Grand Cherokee
How to set up
how to setup bass & treble in pioneer sc 72 and adding stereo equalizer?
Jan 10, 2014 | Measuring Tools & Sensors
CE error displays
hello there and thank you for choosing fixya
CE Communications Error If there is any breakdown in communication between the machine controller and the motor controller, CE flashes and the unit beeps once.
Some common causes of CE errors include:
· Conformal coating on serial communications pins between the machine controller and motor controller. After disconnecting power to the unit, try scraping this coating off the pins.
· Check the resistance values between the serial communications pins with the connectors in place. Make sure the harness does not have a bad connection.
· Check the quick disconnect at the motor terminal. The drive motor must be hooked up properly or a CE error will occur.
· Drive motor thermal protector has opened.
·Motor controller is not powered or fuse has opened. Replace motor controller.
Press STOP/CANCEL to clear the display.
Jul 31, 2011 | Washing Machines
My Washing machine has a fault code of CE - any ideas?
You will need to do troubleshooting.
CE Communications Error .If there is any breakdown in communication between the machine controller and the motor controller, CE flashes and the unit beeps once.
·Motor controller is not powered or fuse has opened. Replace motor controller.---------------------- If any part need to get replaced,then you can get required part from www.repairclinic.com .-------
Thank you.
Feb 09, 2011 | Washing Machines
CE error code on hayward pool heater
CE= Communication Error between Control Module
and Display Interface Assembly
1. Disconnect and then reconnect power to heater.
2. Check for faulty wiring or connection.
Inspect Display Interface Wiring. Ensure Display Interface Plug is securely attached to Control Module. .
3. Control Module and/or Display Interface Assembly
are defective.Replace Control Module and/or Display Interface Assembly.
Here is a linkt oH aywardmanuals:
http://www.haywardnet.com/inground/products/manuals.cfm
Jul 04, 2010 | Hayward 250kbtu Ng Pool Heater - Inground
My kenmore elite calypso has a code of ce
CE Communications ErrorIf there is any breakdown in communication between the machine controller and the motor controller, CE flashes and the unit beeps once.
May 09, 2010 | Washing Machines
Code ce shows we have tried to reset and the code CE come up each time
"CE" Communications Error If there is any breakdown in communication between the machine controller and the motor controller, "CE" flashes and the unit beeps once.
Some common causes of "CE" errors include:
·Conformal coating on serial communications pins between the machine controller and motor controller. After disconnecting power to the unit, try scraping this coating off the pins.
· Check the quick disconnect at the motor terminal. The drive motor must be hooked up properly or a "CE" error will occur.
Nov 29, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Code ce flashing
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jun 27, 2009 | Kenmore Washing Machines
Kenmore Elite Top Loader "CE" error code.
CE means communications error
Dec 27, 2008 | Kenmore Oasis HE 27082 Top Load Washer
Insignia Sport MP3 Player Logo
403 people viewed this question
Top Insignia Audio Players & Recorders Experts
Curt Larson
Level 1 Expert
Steven Wander
Steven Wander
Are you an Insignia Audio Player and Recorder Expert? Answer questions, earn points and help others
