Question about LG 42PX5D 42 in. Plasma HDTV
The screen having red and green tiny dot all over the place, have replaced the Y and Z sustain board ,but the problems are still there, please help ,Thanks alot!
  • LG Master
  • 19,396 Answers
Red dots on your plasma can appear because of a too high voltage to the plasma panel.
This can be caused by a bad voltage settings, or bay faulty control panel, and has nothing to do with sustain board.
Try resetting settings to factory default.
This is done by pressing Mute followed by 1, 8, 2, Power in sequence to enter service mode. In service mode select RESET, so to reset to default and exit.
Do not touch anything else or the TV may have more problems afterward.
If that does not fix the problem, call a technician to verify if the panel is faulty, or to test high voltage to panel (that is not just a plain volt reading).
Posted on Sep 11, 2009
Red dots on dark back ground screen
for this symptom (over diffusion) the voltage for Vsetup has to be decreased, or for opposite (under diffusion) has to be increased. These would be on your sustain board Y. Make very SMALL adjustment, as this can be very touchy potentiometer. There is a sticker on back of panel that will have all the voltages for Vs, Va, Ve, Vscan; these are very important, have to be spot on.
Nov 20, 2011 | LG 42PC3D 42 in. Plasma Television
Red dots all over screen poor picture more when
This is a "mal-discharge" fault & will need either an adjustment on the Y-Sustain board or a software update to the control board. Contact your LG dealer to arrange someone to sort this out for you.
Oct 26, 2009 | LG 42PC3D 42 in. Plasma Television
LG plasma have an amber light when turning on then green then red
After all the research I found out that the IC on the Z board is bad and new board was ordered and replaced. The plasma work fine after that and picture is excellent with the new board. This forum is great, without this I couldn't fix it myself. Thank you.
Sep 30, 2009 | Zenith P42W46X 42 in. Plasma EDTV
Blue tints w/ tini blue dots
if you see blue pixel type groups of squares or dots you may have a burnt light engine and this is common in many LCD rear projection sets; a blue screen may mean the engine became burnt--LCD rear projection sets of this kind have an optical enginge--with red,green,blue prizims--sometimes they get burned by the lamp---a photo would tell me or most techs what the problem is---the cost of a replacement engine is very expensive--some models with this problem are covered by Sony even if the set is no longer in warrant
Aug 07, 2009 | Sony Grand WEGA KF50WE610 50" Rear...
Vizio P50HDM No Picture/No Sound
replace the sustainer boards should correct this problem. New sustainer boards may cause red and green pixilation. If this happen, replace control board and TV is as good as new.
Apr 05, 2009 | Vizio P50HDTV10A 50 in. Plasma HDTV
Red dots on my LG 42PX5D
Hello, you do not need to replace any of the sustain boards in your TV to fix the problem you are having. All you need to do is remove the back cover and make an adjustment to the Y sustain board. You will need to adjust the set_up & or the set_down! If you would like to do the adjustments to your TV please feel free to give me a call or message me. Ask for Dave! 1-503-432-9904 or message me @ pleasefixitdave@yahoo.com You will need to remove the stand & the back cover. Then put the stand back on the TV so that you are able to set the TV in the up right position with the back cover off! Then you'll need to hook the TV up to a DVD player so that you are able to pause the picture while you are doing the adjustment to the Y sus! Do not adjust any other adjuster on the Y sus other then the SET_UP or the SET_DOWN. In order to identify the correct adjusters on the Ysus just look on the board and it should say SET_UP & SET_DOWN next to the correct adjusters. If you need more help please feel free to give me a call or message me!
Jan 12, 2009 | LG 42PX5D 42 in. Plasma HDTV
Hitachi Plasma EDTV has green dots flickering all over screen
that is called diffusion. that can be adjusted out in most cases by adjusting the y sustain pcb but can also be the main pcb, the logic pcb and panel itself but not likely.
Jan 11, 2009 | Hitachi 55HDS69 55 in. Plasma Television
Need to take off tinys green dots in my screen tv.
It seems that your DLP Engine is going. The DMD board in the engine is the problem. it is an expensive fix
Jun 29, 2008 | Olevia Televison & Video
Kolin PT-501 LCD/LCOS HDTV, rear projection TV
Well i really do not know what that is but i do have a thought it could be a bad connector and if you want i have the same tv for sale for $300 shipped just for parts the problem with my pt501 was the screen turned colors but the lamp is in excellent shape and so is the lcos screen the ownly thing that does not work is the main board (ciruit board) i will send you the hole thing for just 300$ shipped if you'd like email me back giovani.rivera@yahoo.com
Jun 29, 2008 | Olevia Kolin DLT2711M 27 in. LCD...
LG 42PX5D 42 in. Plasma HDTV Logo
47 people viewed this question
Computer Repairing
Computer Repairing
