Question about Nextar HGPS35 GPS Receiver
Nextar stuck in loading and wont do nothing - Nextar HGPS35 GPS Receiver
Wont turn on
my nextar is not turn off and making lines nothing appear.
May 16, 2010 | Nextar X3 GPS Receiver
Unit is stuck on loading screen?
Hello :
Turn it on again , then when it stucks again press reset to solve the problem .
good luck .
please rate !
Mar 28, 2010 | Nextar Q3 GPS Receiver
GPS stuck up
Since the operating system and navigation software are preloaded into the internal flash memory of the GPS, the freezing may either be software or hardware failure. First, press the "Reset" button or push the stylus into the "Reset" hole, to see if the navigation software can load successfully. If the program still does not load, then the software may be corrupted. Also, if the internal memory fails to read or write and the software cannot load properly, it may be caused by hardware failure. In this case you must return the unit for exchange or repair to the retail location from which you purchased it, or contact Nextar for further assistance.
For technical support for your Nextar GPS see http://www.nextar.com/frontend/support.asp or you can phone them on 888-849-0846
Jul 07, 2009 | Nextar X3-02 GPS Receiver
GPS locked up
Did you try the switch on the back of unit
Jun 30, 2008 | Nextar Q3 GPS Receiver
Nextar mn2707 firmware update
I had this problem too with the one I got from my sister. If you tap your finger in the lower right of the touch screen mine came back on. I think it resets the screen with commands that come back into the screen area. Try that and let me know. Dale.
May 09, 2008 | Nextar X3B GPS Navigation System
MY NEXTAR MA9336A1S IS STUCK ON THE NEXTAR SCREEN
Since the operating system and navigation software are preloaded into the internal flash memory of the GPS, the freezing may either be software or hardware failure. First, press the "Reset" button or push the stylus into the "Reset" hole, to see if the navigation software can load successfully. If the program still does not load, then the software may be corrupted. Also, if the internal memory fails to read or write and the software cannot load properly, it may be caused by hardware failure. In either case, please return the unit for exchange or repair to the retail location from which you purchased it, or contact us for further assistance.
Apr 06, 2008 | Nextar MA933A MP3 Player
X3-02 nextar gps
three step solution, easily correctable. wrap in towel, smash with ball peen hammer, gently lay in trash. You should have no more issues after this.
Mar 22, 2008 | GPS
Nextar w3g-01 mp3 function
Is there a map update for Nextar GPX model X3-01. If so, please supply link
Thank you.
Peppercorn
Mar 15, 2008 | Nextar X3B GPS Navigation System
Nextar q3
Do a hard reboot, take batt out for more than 15 min. Or let system die out power. Then start over.
Dec 18, 2007 | Nextar Q3 GPS Receiver
Nextar HGPS35 GPS Receiver Logo
65 people viewed this question
Top Nextar GPS Experts
Are you a Nextar GPS Expert? Answer questions, earn points and help others
