Question about Samsung DLP HL-P5663W 56" TV
Samsung DLP Vertical Hold
Picture loses vertical hold temporarily. It eventually stops but takes a few minutes. Can I adjust/fix this problem myself?
  • 1,694 Answers
Problem is either bad connect inside or heat-related failure....
also called thermal will need help from a knowledgeable SAMSUNG tech.....prefer authorized service
center, then you can give feed-back to SS customer service if needed.......................T.
Posted on Dec 21, 2007
I had pin holes on my projection tv, with the hlp of jimmys .com video I was able to change out the dlp chip, tv looks great except picture is1in to high on the screen. Samsung HL67A750A1FXZA . HELP
A Convergence of the screen problem made by a special tool made on marketing technical decision in a little memorychip or (maybe there is a special servicemode for picture geometrical adjustments , ask for it your dealer or it has autoconvergent then there could be are also a few bad capacitors to replace. most change to find in the vertical group.
Samsung HL67A750A1FXZA Service Manual Page 19
Sep 03, 2016 | Samsung Televison & Video
Sony trinitron KV-32HS510 has vertical hold problem
It could just be a resistor or two ,
check for Vert Oscillator Circuit & AGC
Jul 27, 2012 | Sony FD Trinitron WEGA KV-32HS510 32" TV
Vertical white lines appear on the screen. Samsung provides the following information but doesn't say what circuitry they are referring to. Samsung says: DLP TV: I Have Vertical White Lines...
That answer I agree makes no sense.
Most of these sets have NO vertical hold and if did it will not cause the lines.
A brief educated guess:
Set has a main board that communicates and controls the screen--tests for that are not simple (checking waveforms with a scope and signal generator).
The model indicated here is a DLP that uses a lamp (let me know if model listed is not the one you have).
In DLP sets aside from main/digital board you also have a optical light engine---it processes all signal in and out to the screen.
Optical engines do fail and cause some simple and some complicated picture issues.
Some will even cause the set to "lock up" with a picture or strange looking screen---clue to this is you have to shut the set off by pulling the power cord.
The set may be old enough they do not really want to help you or even talk about it.
May 22, 2012 | Samsung HL-S6187W 61 in. HDTV
How do you adjust the vertical hold on this TV?
Modern TV's haven't got a vertical hold control like in the old days. The TV system now uses a system of counting. For instance;
UK is 625line which is 15.625KHz line frequency. Divide it down by the correct amount and we get 50Hz frame frequency. There is no need for external controls. That is how copycode on video works. Supply 620 lines and in the end that is not divisable to give 50Hz so video cannot be copied as TV shows the wrong speed frame and will cause no colour and picture disturbance.
Likewise the same rule applies to USA 60Hz system.
Mar 02, 2011 | Samsung DLP HL-P5663W 56" TV
Continuous vertical roll on tv
Wow 5 months without a solution. NOT GOOD.. Well I hope I can help...
This sounds like a vertical hold problem, and is normally easy to fix.... There should be a couple of nob's on the lower back of the TV. One for vertical and one for Horizontal hold. You need to find the vertical hold nob and adjust it, until the rolling stops and stabilizes. If however these nob's are not visible you will have to take TV to an engineer to fix it.
Hope this helps..
Nov 11, 2010 | Zenith B27A11Z 27" TV
How do adjust verticle picture on Hitachi 46F510
You can adjust vertical height through the service menu, but i would recomed that you trouble shoot the vertical section as its probably a solder joint , leaky diode or something that is causing the problem. Often its bad solder at the vertical output IC itself that causes that sympton.
Apr 09, 2008 | Hitachi 46F510 46" Projection HDTV
Problem with the White vertical lines on Samsung 50 in DLP
Get DMD board part # and shop for best price.......
I will do the same......let me know.....T.
Nov 05, 2007 | Samsung HL-P5063W 50" Rear Projection HDTV
Hitachi 60FX32B picture
Replace vertical output IC with first quality part,check caps
in vertical power supply......If you don't have access to parts,
then solder pins of IC,should hold for awhile.
If you need further assistance, let me know.....T.
Oct 26, 2007 | Hitachi 60FX32B 60" Rear Projection...
Samsung DLP HLR5668W has mostly dark picture + grinding noise
Pix looks like a light pipe issue, inside the Light Engine. as far as the shutting down, could be a bad fan causing the grinding and when stopps the DMD turns the set off.
Jul 08, 2007 | Samsung HL-R5668W 56" HDTV
Picture has horiz. lines
There is no vertical hold in the tv circuits now adays. You may find a vertical center or a vertical height. Your problem sounds like (if it has PIP Thats Picture in Picture) its in the PIP module and its a small module that stands up and most models of Mistubishi this module is no longer availabvle. The problem with the module is the small pana caps are leaking and ruins the PC traces. I have heard that theres a kit available on E-Bay to jump out this module. Now if its not the PIP model then it could be a few capacitors in the vertical sweep circuit. Also the B+ feed off the Flyback that supplies voltage to the vertical output IC could have a bad or leaky capacitor in the circuit. If your not a tech or solid state troubleshooter theres not much you can do and SHOULD take this set in to a repair center. Good Luck
May 21, 2006 | Mitsubishi VS-45605 50" Rear Projection...
Samsung DLP HL-P5663W 56" TV Logo
487 people viewed this question
Jerry Greenberg
Jerry Greenberg
