Sony Grand WEGA KDF-60XBR950 60 in. Rear Projection HDTV Television
Problem for Sony Grand WEGA KDF-60XBR950 60 in. Rear Projection HDTV...
KDF60XBR950 doesnt turn on....fan is on just flashes green
By iamfree on Sep 11, 2009
when i try to turn it on i hear a slight screeching (or whining ) sound and the light just flashes green. took the back off to see/hear better and it is coming from the back...bottom right
Comments:
Sep 11, 2009
- red lamp light flashes after 1 minute
Sep 11, 2009
- never mind...lamp is blown....thanks anyway...gnr
Sep 12, 2009
- i think my tv is lcd not dlp....i have a lamp coming today...ihope that fixes it. i pulled the other one out and it is busted. thank you for your response. have a great weekend. support our troops, james
Oct 20, 2009
- fixed it...pulled out the lamp and it was busted...thanks to those that tried to help
Clarification Request
Posted by djeletronics on Sep 11, 2009
dlp tvs have a color wheel that goes bad-google model number and color wheel to find
Solution #1
posted on Oct 20, 2009
Not Helpful)
alfredjparks
Rank: Apprentice
Rating: 70%, 2 votes
Yes, the cooling fan for the lamp is clogged with dust or debris and is not spinning. The fan blades may be over heated and distorted making it stop spinning. Shine a flashlight into the vent opening to see if the fan is spinning. If you get a series of four red flashes on the front panel lights, it means that the this fan has failed and needs to be replaced.
Was this helpful?
Yes
No
Solution #2
posted on Sep 12, 2009
Not Helpful)
Skyassoc
Rank: Guru  Sony Televisions & Videos  Expert
Rating: 90%, 273 votes
There is no less than two Cooling Fans on the right side. Either one of them could cause the problem. The one that turns slow or stops turning quickly is the one that is probably causing the problem.
I hope this helps,
Sky Assoc
Was this helpful?
Yes
No
Popular Solutions for Sony Grand WEGA KDF-60XBR950
Questions and Unsolved Problems for Sony Grand WEGA KDF-60XBR950
Do you recommend Sony Grand WEGA KDF-60XBR950 60 in. Rear Projection HDTV Television?
Answer
Answer
my sony rear projection green is blurry, i pressed the fix button but the green stays the same. i... (More)
Answer
popping and cracking do not appear to effect picture but blue ghost is annoying
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Sony Grand WEGA KDF-60XBR950...:
Top Projection Television Experts
Rank: Guru Guru
Solutions: 790
Experience: 30 Years of professional repair and design.
Ask Me
Find more Projection Television Experts
Top TV Repair
(859) 609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC...
(316) 283-8873
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
