Question about Philips 55P8341 55" Rear Projection Television
Philips 55P8341 switching between inputs...
My tv must have a ghost standing in front of it turning it on and off. Also it will switch between inputs as it sees fit. Is this an unusual problem? Is it an expensive repair?
    President:
  • 4,402 Answers
Unplug it for a while then try it again.
Posted on Dec 10, 2007
How to switch to av mode on philipse vardana sl TV
Varadan has no menu button on it front panel to select the inputs. You must have its original remote control to select it input.
Feb 12, 2013 | Philips 20PT643R 20" TV
Connect Apple tv to Philips LX700
OPTION 1 (using remote):
Press the system key on the remote,
find the digital input option,
choose optical,
finish!
OPTION2: (Using LX700 button)
"program" button on the front panel for 5 seconds,then press LEFT or RIGHT button to choose DIGITAL INPUT,and Press "program" button again,then change coaxial to optical by rotating VOLUMN control on the front panel. then just confirm by pressing the "program" button again and wait for 5 sec to quit menu. Now switch OFF and switch ON receiver again.
Now make sure the source id DISC IN (ie., digital input ).
Your LX700 should be picking up optical signal!!
It worked for me and i hope it works for you to as well.
-SASi (ssasi2000@gmail.com).
Dec 15, 2012 | Philips LX700 System
I have a philips big screen projection tv modul#55p8341 that turns off after being on for a while. great picture and sound
Your horizontal output chip is going bad after it heats up to a certain point it fails and shuts your set down. After a while if not replaced your set will fail to power up at all.
Aug 13, 2010 | Philips 55P8341 55" Rear Projection...
Tv turns on and off by itself
Picture tubes rarely go bad. You have a bad connection or something on the circuit board that is breaking down due to the temperature change . Probably an easy fix. Not something an unqualified person can do though. Your local shop should fix this for about $60-100.
Jul 17, 2008 | Philips 25PS40S 25" TV
Power Problem (Phillips 55P8341 Projection TV)
Same problem... I pulled out the second electronic board going from right to left and see a burned diode at position 3307. I wanted to know if anyone has a schematic of this TV and could tell me the numeric value of the part in position 3307. It would be appreciated it you could let me know.Thanks...
May 30, 2008 | Philips 55P8341 55" Rear Projection...
Blinking lights on philips 55P8341
5 volt protection is causing the set to go into protective shutdown. Check for shorted diode 6306. Part#934038020127
or shorted capacitor 2318. or faulty voltage regulator
May 18, 2008 | Philips 55P8341 55" Rear Projection...
I HAVE A PHILIPS TV MODEL#55P8341 AND WHEN I TRY TO TURN IT ON THE POWER LIGHT JUST KEEPS ON BLINKING AND BLINKING I TRYED TO RESET IT BUT IT STILLS DOES THAT IM TRYING TO FIND SOMEONE TO HELP ME OUT AND...
Your set is shutdown for protective reasons due to a failed component in the stand by or operating voltage circuits. You can get the service manual at the link I am posting and they will provide free on line instant message tech support when you purchase the service manual which they email you. heres the link.
http://servicemanuals.vstore.ca/
May 01, 2008 | Televison & Video
TV Volume turns down by itself - Philips 29PT8319 Matchline 27"
Most likely the volume down button on the front of the TV or the switch that it activates is sticking. Should be an easy fix otherwise.
Feb 05, 2007 | Philips 27PT8320 27" TV
Philips 55P8341 55" Rear Projection Television Logo
42 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
