Question about Garden
The blades on my Flymo 350 lawnmower have become blunt. How easy it is to replace them once i have purchased replacement blades?
    President:
  • 1,129 Answers
It is a matter of unscrewing the bolt that holds the blade on just make sure when installing the new blade that it locks into the mounting shaft correctly on some mowers there is a mating hole to shaft pattern that allows the blade to interlock onto the shaft yours may just have a rectangular support the blade fits into just make sure when you tighten the blade it is set into the shaft correctly and you are wearing a pair of raw hide gloves when holding the blade as you tighten or somehow block the blade with a piece of two by four wood.
Posted on Sep 11, 2009
Flymo instruction manuals
www.flymo.com/uk/robotic-lawnmower-support
www.flymo.com/uk/contact-us
Jul 14, 2014 | Garden
Flymo tines
What are you referring to as tines, it sounds like you are working on a roto-tiller. I will need more info as well. Model# Unit type-ie. lawnmower. Are talking about the blades? If so the there is a large nut that bolts the blade to the lawnmower. Remove bolt by holding blade with gloved hand and long breaker bar. You can strike the breaker bar with a three pound hand sledge to break it loose. Replace or sharpen blade as necessary. Apply grease or never-seize ti threads on crankshaft, spin on the bolt and tighten with long breaker bar. Good luck!!!!! If this is a tiller, then let us know, ok?
Mar 26, 2014 | Garden
Why wont my overlock cut
probably because the blades are blunt and out of adjustment. They are only mechanical scissors that rub each other and like ordinary scissor they become blunt. Most shops the sell or service overlockers will have replacement blades for your machine.
Sep 14, 2013 | Janome MyLock 634D Mechanical Sewing...
My flymo 350 turbo compact isint cutting can i adjust the blade height ?
You can put spacers under the blade, a twin pack of spacers are available from Flymo part no. 513811081., from memory you are allowed to fit three spacers.
Aug 10, 2012 | Garden
How do I lower my lawnmower blade (flymow)
Good day. Unfortunately there are no settings to lower the blade on a Flymo. Hope this helps
May 10, 2011 | Beckett Water Gardening Water Garden...
My flymo H33 mower has blunt blades. Are they worth repairing and where in Brisbane?
Hi Lesley, The blades on your mower are easily sharpened and if needed balanced and straightened so they are just like new if done properly. As far as Brisbane is concerned, it is located in Australia if I understand your question right. Hope this is helpful. All the best and good luck.
Feb 15, 2011 | Garden
My Flymo microlite 28 lawnmower is very noisy...
You got it, replace the disc before you use it again.
Jul 09, 2009 | Garden
Flymo micro lite - cutting height of blade
you twist the plate holding the blades and it will lift off, then you turn the blade plate upside down and replace making sure you align the notches and then twist to lock into place. hope this helps
Oct 16, 2008 | Garden
Garden Logo
239 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
