Hose connections are good, drain pipe does not seem to be clogged. I have water leaking from beneath my washing machine, mainly on the right side. Is there anything I can check before calling out a repairperson? Can you help with component location/dissassembly info if I need to do that? Thanks!
Water leaks underneath my washing machine, mainly on one side (when facing maching it's on my right side) and it leaks when its on the wash cycle and rinse cycle, not while filling up to water level. It's an Amana Washing Machine, top loading, model LW4303 and it about 15 years old. Thank you!
Well this MIGHT come in handy but not many parts are left for those old machines.
http://www.partselect.com/Models/LW4303W/Sections/OUTER-TUB-COVER-AND-PRESSURE-HOSE/?ModelID=111720&ModelNum=LW4303W&mfgModelNum=P1163303W%20W&ManufactureID=1&Selected=19122&Position=14&mfg=Maytag&Type=Washer&Mark=14
Posted on Apr 17, 2017
SOURCE: Water Leaks from beneath my washing machine
Our WM2077CW just started the water leaking from underneath. We unplugged the electrical cord and disconnected the hoses (water, drain). We then removed the inspection plate from the back and checked for wet hoses. The big black hose on the bottom was a little wet. On careful examination we found a small hole that looked like a material fatigue failure at the point where the accordion part of the hose met with the solid part of the hose near the main drum connection. I suspect this is may occur in other LG washers of the same design. Unless your floor is perfectly level it's hard to tell whether coming from the left or right side really indicates where underneath the water is coming from.
Posted on Dec 05, 2007
Oct 06, 2015 | Bosch Washing Machines
It is so common that the drain leaks in many ways and is the most problematic fault in a washing machine. In all occasions it is important that your observation is most important and so is vital to the identification /rectification and solution. If you have noticed that water has leaked then as the drain hose pump/valve and fittings are located on the underside of the machine it is important that you look for possible leaks here. In some cases the drain hose would be clogged at the drain end to outlet of the house and so there will be back flushing resulting in overflow to the outside. Also the drain pump/valve can be clogged or the drain hose clamps can be loose on the grip which can all cause the leak to occur. Removing and cleaning the drain pump/valve, tightening of the hose is also very important. Also water can leak if there are gaps on the front door gaskets and must be checked but this will happen only during the cycle and not on the drain cycle end.
Tips for leak: http://www.espares.co.uk/advice/washing-machines/a/7/1461/do-you-have-a-leaky-washing-machine.html
Check for tips on the link below to identify parts and removal:
Jul 02, 2012 | GE Washing Machines
Jun 11, 2012 | Frigidaire Washing Machines
It is so common that the drain leaks in many ways and is the most problematic fault in a washing machine. In all occasions it is important that your observation is most important and so is vital to the identification /rectification and solution. If you have noticed that water has leaked then as the drain hose pump/valve and fittings are located on the underside of the machine it is important that you look for possible leaks here. In some cases the drain hose would be clogged at the drain end to outlet of the house and so there will be back flushing resulting in overflow to the outside. Also the drain pump/valve can be clogged or the drain hose clamps can be loose on the grip which can all cause the leak to occurs. Removing and Cleaning the drain pump/valve, tightening of the hose is also very important. Also water can leak if there is gaps on the front door gaskets and must be checked but this will happen only during the cycle and not on the drain cycle end.
Sep 20, 2011 | Bosch Washing Machines
Aug 03, 2011 | Washing Machines
It is so common that the drain leaks in many ways and is the most problematic fault in a washing machine. In all occasions it is important that your observation is most important and so is vital to the identification /rectification and solution. If you have noticed that water has leaked then as the drain hose pump/valve and fittings are located on the underside of the machine it is important that you look for possible leaks here. In some cases the drain hose would be clogged at the drain end to outlet of the house and so there will be back flushing resulting in overflow to the outside. Also the drain pump/valve can be clogged or the drain hose clamps can be loose on the grip which can all cause the leak to occurs. Removing and Cleaning the drain pump/valve, tightening of the hose is also very important. Also water can leak if there is gaps on the front door gaskets and must be checked but this will happen only during the cycle and not on the drain cycle end. You have indicated that the spin was activated to drain off and so the drain exit seems good . Hence I would advice that you check the drain hose fittings and drain pump. Check once again to confirm if this was a program controller malfunction of the cycle. finally keep your machine in slight slant /tilt so that the water drains off fully to the exit valve.
Apr 11, 2011 | Washing Machines
Nov 08, 2010 | GE WHRE5260E Top Load Washer
Oct 22, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Sep 13, 2008 | Washing Machines
Nov 26, 2007 | LG WM-2277HW Front Load Washer
624 people viewed this question
water leaks from underneath the washing machine
exact same problem
same exact problem
same problem, but mine's closer to 20 years old. Still cleans well.
