Question about GE Spectra JGBP30 Gas Kitchen Range
Can't get stove to light
My husband has converted the same model stove to LP by changes the orifices and adjusted the broiler and oven but, it seems like there in no propane coming through. We bought this stove used and do not have an owner's manual to try and troubleshoot. All we received was a 1 sheet instruction manual for converting.
    Problem Solver:
  • 6 Answers
You must get some flame and put were the gas is
Posted on Sep 11, 2009
Whirlpool WFG510S0AS2 range - stove burners work just fine, but both the oven and broiler does not stay lit. NOTE - this unit has been converted from natural gas to LP
when the lp conversion is done , it is normally just a jet size change that is done
however the air shroud has to also be adjusted to get a clean blue burn of the flame
The just jet change results in a slightly yellow flame which is incomplete burn of the gas and that creates carbon build up at the jet and burners causing partial blockage
I would suggest that you call in an accredited gas fitter to check the problem and if necessary , clean the jets and adjust the air shroud
Dec 30, 2015 | Whirlpool WFG510S0AS
Brown TM210-4 kitchen range... how do i switch from LP Gas to Nat. Gas on this model? Is it just a regulator adjustment? or do i have to change the orifices as well?
Both. If this is a sealed top range, then you will have to change out the orifices and flip the cap on the regulator. If this is an open top style range (the top lifts up around the burners) then the orifices need to be adjusted and the regulator cap flipped. The oven/broiler orifices will also need to be changed or adjusted, depending on which kind they have. Some older models also require converting the oven thermostat from LP to natural gas (and vice versa) by turning the screw to the correct marked setting. If you have your owner's manual, it explains the conversion in it. If not we may be able to find it online for you to download. Douglas
Oct 09, 2010 | Brown Stove Works TM210 Gas Kitchen Range
I have a K/A kgst307 gas stove that was bought new as a natural gas unit. After 3 years, I moved to a house that had propane. NO PROBLEM because an LP conversions kit came with the stove. Used the stove on...
Although the natural gas orifices for the stove top burners were replaceable with propane orifices, many ovens/broilers orifices are simply adjustable using a 1/2" open end wrench to convert from one gas to another. Some brands are adjustable and some have to be changed out. It depends on the make and model. Do you have your owner's manual? It contains detailed info on converting your unit. I included a link below to choose from the list to download your manual. You'll need your exact model # listed on your stove. Pull out the bottom drawer and look at the data plate for the model # and then find it on the list for the correct manual. Douglas
http://shared.whirlpoolcorp.com/product_literature/search_results.jsp?searchTerm=KGST307&siteCd=WHRCOM&userType=Consumer
Oct 01, 2010 | KitchenAid KGST307 Gas Kitchen Range
Hi I am trying to convert my Dacor stove/oven from NG to Propane. We can't find the conversion kit anywhere. Any ideas?
Hi, to convert from NG to LP is easier in some ways but harder in others. The pressure part is easy because LP runs at the same pressure that comes into the house so the regulator is normally locked wide open to allow a direct by-pass. You could just as easily remove the regulator and plumb straight in from the houseline. You don't say what model but usually the sealed cooktop burners will need smaller orifices and the oven and broiler orifices are adjustable. If that is the case, the oven and broiler orifices can be tightened until they bottom out which be the correct output for LP. You would need to remove the cooktop orifices and find replacements which are correct for LP, these are non-brand specific. Honestly, if you go to repairclinic.com and enter the brand and model number, I'd be surprised if you couldn't find the conversion kit. Even the Dacor site should be helpful. I found many different kits available at the repairclinic.com site even without a model number. Best of luck.
Jan 29, 2010 | Dacor Preference SGM365SS Gas Cooktop
With the Jenn-Air PRG4810NP (Natural Gas), is there any way this can be converted to LP with a regulator? I'm not sure if I ordered the regulator for the LP range and attached it to the NG model, if this...
Conversion is usually accomplished by flipping the regulator cap around. Nat side is hollow and LP is solid to hold the regulator open. The oven orifices are adjustable and the surface burnres can be either adjustable or have LP replacements.
Eric
Jul 01, 2009 | Jenn-Air PRG4810 (NP) Gas Kitchen Range
Yellow flame after an Lp conversion
I remember having a stove with an adjustable orifice in the oven. It looked like a double nut arrangement. If that is what you find, tightening them to each other shrinks the size. Should turn fairly easy, do not force. You may also find a pilot adjustment behind the oven control knob. Hope this helps.
May 19, 2009 | KitchenAid KGST307 Gas Kitchen Range
2002 GE XL44 converting from LP to Nat Gas
the jet sizes will have to be changed due to the weights of different gasses
Jan 20, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Converting aan LP oven to gas
In most cases the pressure regulator has to be changed or adjusted. The orfices on each burner, oven, broiler and surface burner may need to be changed also. Sometimes they can be adjusted. Sometimes the threads on the pipe are different also. This is to prevent accidental connection to the wrong fuel. The big difference is the gas pressure. LP is usually around 10 - 12 lbs and natural gas is usually around 3 lbs. Properly adjusted you will like natural gas much better than LP as it is slightly hotter. The information will be in the instruction book and also on the Jenn air web site. Whirlpool owns both Maytag and Jenn aire so check all sites. The conversion kit is usually less than $50.
Apr 20, 2008 | Equipex PZ-330 Electric Single Oven
Lp flames to top of oven
You need to tighten down the orifice spud for the bake burner. Remove drawer in bottom of oven. Look for bottom of burner tube, where the shutter adjustment is. Right below it is the orifice spud. Usually a goldish color. Take 1/2 inch open end wrench and tighten until it stops. Do-not overtighten! Try it now. If flames are still to high, tighten a little more. Repeat if needed.
Nov 18, 2007 | Kitchen Ranges
Open Questions:
See all GE Spectra JGBP30 Gas Kitchen Range Questions
GE Spectra JGBP30 Gas Kitchen Range Logo
246 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
 Fix Your Board
Fix Your Board
Are you a Kitchen Range Expert? Answer questions, earn points and help others
