Question about Simplicity Sew Precious SWSP2 Mechanical Sewing Machine
How do you thread the machine, top and bottom, please.
I bought the machine at a garage sale with no manual. It's been over 25 years since I have actually sewn anything, and I've forgotten the basics of threading a machine.
    Problem Solver:
  • 5 Answers
From the Simplicity Sew Precious Model SWSP2 manual:
Inserting a new bobbin:
  1. Place wound bobbin into the bobbin case.
  2. Pull about 6 inches of thread out from the bobbin.
NOTE: Be sure that the bobbin rotates COUNTER-CLOCKWISE when thread is pulled.
  1. Pass the thread from the bobbin, under the bobbin case spring, and toward the back of the machine.
  2. Slide bobbin cover back into position.
Upper threading:
  1. Turn the handwheel toward you to raise the take-up lever to its highest position.
  2. Lower the presser foot.
  3. Place a spool of thread and spool cap on the spool pin.
  4. Place the thread into the first thread guide at the top of the machine.
  5. Bring the thread down the right slot of the threading path, then around the tension dial. Push the thread tension release lever and pull the thread up so the thread is secure in the thread tension dial.
  6. Bring the thread up the left slot of the threading path and through the take-up lever from right to left.
  7. Bring the thread back down the left slot of the threading path and into the needle eye from front to back. (Clip the thread end with sharp scissors fro easier needle threading.)
Raising the bobbin thread
  1. Make sure the presser foot lever is raised.
  2. Hold the end of the needle thread with your left hand. Turn the hand wheel toward you with your right hand until the needle goes down once and comes back up, stopping when the needle is at its highest position.
  3. Gently pull up on the needle thread. The bobbin thread, looped around the needle thread, will be drawn up through the needle hole.
  4. Push the thread tension release lever and pull about six inches of both the upper and lower threads toward the back of the machine, placing them under the presser foot.
You can obtain a copy in pdf format for free at:
http://www.simplicityhomecare.com/ftp/whitepapers/SWSP2-english.pdf
Posted on Jul 29, 2010
  • Simplicity Master
  • 1,860 Answers
Tip
Garage Sale Sewing Machines
Before you get a sewing machine for $25 at a garage sale, make sure it truly sews.
You will need to bring thread, scrap material, and a pair of scissors. (I bring a couple types of pre-wound bobbins and a needle.) First, does it have all the parts? Bobbin case, bobbin, cord, foot pedal? Are the cords frayed, or the plugs broken? Will the owner let you plug it in? Are you able to thread it and wind the bobbin? Does it make a stitch in the straight stitch AND zig zag modes? If any of these are no, walk away. Use that $25 to save towards a quality new machine, or wait for another garage sale.
on Mar 05, 2015 | Singer Sewing Machines
Singer 5523
Hello
You can download the manual for free here: http://www.singerco.com/support/instruction-manuals/search
Please let me know how this goes for you.
Happy Stitching
Sewingirl/
Mar 09, 2017 | Singer Sewing Machines
I purchased an older Singer Stylist zigzag model 457 sewing machine at a garage sale. It doesn't have the owners manual and the bottom thread gets all knotted up. It also is hard to feed the material...
I can definitely help you with the owners manual. Go to http://parts.singerco.com/IPinstManuals/457A_105_125_135_143A.pdf and you can download it direct from singer, no viruses, nothing. Just save it in Adobe format.
The bobbin thread problem is called a birds' nest and can be from a number of problems. First thing to do is to change your needle, especially if it was the one you bought the machine with. It may look perfectly straight to the naked eye. But it only needs to be a little bent to cause a problem. If this doesn't clear the problem up, make sure you're using a new bobbin, freshly wound. If the bobbin isn't wound properly or is an old bobbin that's slightly bent or not quite round, it'll cause problems, too. Finally, the machine may need a new bobbin casing. Do a google search for Singer sewing machine parts and search for a bobbin casing for a model 457. You'll remove the plate from the top of the machine CAREFULLY (the screws are small, so be careful not to lose them!). Take pictures if you need to with your cell phone so you can see what to do when you need to put the new casing in. Bobbin casings are usually $25-30. This is the last thing, and I would only do this if you see that thread is catching on something in the bobbin area when you're moving the wheel by hand.
I've tried to be clear on the last bit, but I realize it can be a little awkward. If you need any other help with that, please leave me a comment back. It goes straight to my email, so I'll see it quick and will get back to you right away. The manual doesn't help a lot with your bobbin problem, so I'll do whatever I can to help you through it and get you sewing. Good for you for finding a great garage sale find!
Jun 08, 2011 | Singer Sewing Machines
Where are the tension controls on this machine? I am not sure which is which, have not sewn in many years and am having huge problems figuring out this basic machine. Also the material in coming towards me...
Go to www.singerco.com and under support you will see that you can download your manual for free. Save it to your computer, and enlarge the diagams for easy viewing. Then look under frequently asked questions and you will get some really good tips. Their site is a very good one. Good luck
Jan 22, 2011 | Singer 1507
I was given for my birthday a very old Kenmore Zig Zag Deluxe (bought at a garage sale for $25) that was supposedly the first model that was both electric and foot pedal adaptable. The machine itself is...
Oh, fantastic!! These old sewing machines are just wonderful, and being all metal, will continue to work for years and years. Here are a couple of websites to check out:
http://zigzaggers.typepad.com/zigzaggers/
(reviews of old machines by people who love them and use them)
http://www.ismacs.net/home.html
(vintage, antique, and rare sewing machines)
http://www.sewmuse.co.uk/
http://www.tias.com/stores/relics/
http://www.treadleandcrank.com/
(the last one focuses on treadle and crank machines, but still is interesting.)
Happy sewing!
Robbie
Jan 31, 2010 | Kenmore Sewing Machines
I have no manual, I bought it at a garage sale for my granddaughter to learn on.
Try entering "kenmore sewing machine manual" in Google or other. there are plenty on the Web
Aug 05, 2009 | Kenmore Sewing Machines
When threading my Viking sewing machine., the needle won't pick up the thread. I.ve used it 15 years. This is the 1st time this happened. Help...
Do you mean it wont pick up the bobbin thread? You need to get into the user's manual on removing the bobbin shuttle that the bobbin holder clips into (actually pretty easy, I clean ours yearly especially if fuzzy material like velour is sewn) and brush the fixed area out that the bobbin shuttle floats in then reassemble and test. Also remove the throat plate/needle plate and you'll find that fuzz/lint gets between the plat and the feed dogs keeping the dogs from coming up fully.
Also if thread breaks one thing to look for if you've had needles break is a burr around the oval opening in the plate where the needle goes into it. Small Swiss file takes care of the burr and no more burr to break/cut the threads.
On rare occasions you may find the actual bobbin carrier (the one that holds the bobbin and is clipped into the machine) gets worn and wont stay clipped into the shuttle that holds it. Replacing the bobbin carrier is needed then. A1 Sewing on the net carries parts for the #1, #1+ etc.
Apr 26, 2008 | Husqvarna Viking 1
Simplicity Sew Precious SWSP2 Mechanical Sewing Machine Logo
1,227 people viewed this question
Top Simplicity Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
doylesouders
Level 1 Expert
Are you a Simplicity Sewing Machine Expert? Answer questions, earn points and help others
