Kenmore 53082 / 53084 Side by Side Refrigerator
Problem for Kenmore 53082 / 53084 Side by Side Refrigerator
Fridge never stops
By rseyferth on Sep 11, 2009
my fridge never stops running why? rseyferth@comcast.net
Solution #1
posted on Sep 11, 2009
Not Rated)
57 varieties
Rank: Guru  Kenmore Expert
Rating: 88%, 588 votes
Most likely that the thermostat is defective or the main controller board is defective. Try powering off at the mains and leaving it off for 30 mins and then turning back on the power - it sometimes works. If not then call in a repair man asap.
Was this helpful?
Yes
No
Solution #2
Not Rated)
woodchuck789
Rank: Guru  Kenmore Refrigerators  Expert
Rating: 91%, 639 votes
How to check everything
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
Was this helpful?
Yes
No
Popular Solutions for Kenmore 53082 / 53084 Side by
Questions and Unsolved Problems for Kenmore 53082 / 53084 Side by
Do you recommend Kenmore 53082 / 53084 Side by Side Refrigerator?
Answer
Answer
106.53502300 kenmore side by side fridge quit cooling - frozen food all melted & fridge part... (More)
Answer
replacing the water hose to the water dispencer on the front door
Answer
ice maker will not dispense ice thur door after taking apart! I feel like something was not lined up... (More)
Answer
My freezer is currently at 0 degrees and the refrigerator at 35. However, every- so-often the motor... (More)
Answer
ice maker works perfect but water dispenser does'nt work and i can't figure out how to get the... (More)
Describe your Refrigerators problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Refrigerator Experts
Top Refrigerator Repairmen
in , PA
(423) 303-3782
Refrigerator parts delivered overnight nationwide....
 Appliance Parts Pros.com
(816) 471-5334
* Please Contact us for More Information
At Your Service Appliance Repair
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
