Question about HP OmniBook 6100 Notebook
I have purchased a new battery,but will not turn on my laptop.The battery is fully charged and will re-charge through the laptop,but does not work the it any ideas
  • Matthew Albert
    Matthew Albert May 11, 2010
    nothing? no lights or beeps? can you here a fan when you first try to turn it on?
  • 77 Answers
Have you tried to use another ac adapter? or you might need to load bios defaults of your computer, or need to replac motherboard.
Posted on Sep 12, 2009
Battery not charging dell inspiron 630m
Determine if the laptop battery is defective. While less than 1 percent of batteries are defective, the possibility is still there. If the battery is new and only charges some of the way, it may just require a BIOS update to charge fully. New batteries that refuse to charge at all may be defective. Purchase a new dell inspiron 630m battery to replace the defective one.
Test the laptop power adapter to see if it's faulty. Run the laptop directly from the laptop power adapter and without the battery. If the laptop does not work with the adapter plugged in, the adapter is dead and you will need to replace it. The laptop battery may refuse to charge if the adapter is faulty. Charge the battery with the laptop turned off.
Insert the laptop battery into another laptop to test it. If the laptop battery charges in another laptop, the laptop's motherboard may be bad. Replacing a motherboard in a computer can be very expensive. If the cost to fix the computer is not worth the cost of replacing the motherboard, consider purchasing a new laptop.
Reinstall the battery to ensure all connectors latch properly. The latch mechanism that holds the laptop battery should click into place. If the latch does not close, remove the battery and examine the compartment for signs of damage.
5
Troubleshoot the BIOS to determine if there is a hardware problem. Turn on the laptop and immediately enter BIOS setup by holding down the "Del" and "F1" or "F2" keys, depending on the make and model of the laptop. When the BIOS screen appears, see how long it takes for the battery to charge down. If the battery does not last as long as the BIOS setup, a hardware failure may be the problem.
Apr 05, 2013 | Dell Inspiron 6400 Notebook
Dell d810 battery not charging
Instructions
Determine if the Dell Latitude D810 battery is defective. While less than 1 percent of batteries are defective, the possibility is still there. If the battery is new and only charges some of the way, it may just require a BIOS update to charge fully. New batteries that refuse to charge at all may be defective. Purchase a new laptop battery to replace the defective one.
5
Apr 02, 2013 | Computers & Internet
My m2000 battery is not working
The possible causes are as follows:
Determine if the laptop battery is defective. While less than 1 percent of batteries are defective, the possibility is still there. If the battery is new and only charges some of the way, it may just require a BIOS update to charge fully. New batteries that refuse to charge at all may be defective. Purchase a new laptop battery to replace the defective one.
5
http://www.aurabuy.com/cheap-12-cell-battery-for-hp-compaq-presario-b3300-c300-c500-m2000-paypal.html
Mar 31, 2013 | HP Compaq Presario V2000 Notebook
Dell vostro 3500 shows battery connected but not charging and intermittently shoes no battery detected
Instructions
5
http://www.aurabuy.com/cheap-9-cell-battery-for-dell-vostro-3400-3500-3700-7fj92-04d3c-paypal.html
Mar 28, 2013 | Dell Vostro 3500 Laptop Computer (Intel...
Laptop won't charge battery
Laptop battery problems are quite common among owners of all brands of notebooks. On average, laptop batteries last one to three years. Their exact lifespan depends on several factors, such as how much you use the batteries, the number of charge-discharge cycles and the quality of the batteries. Lithium-ion batteries begin to lose the ability to hold a charge over time. Before you replace a laptop battery, consider that there may be other reasons that the laptop is not working properly. You may be able to recharge the battery instead.
1.Determine if the laptop battery is defective. While less than 1 percent of batteries are defective, the possibility is still there. If the battery is new and only charges some of the way, it may just require a BIOS update to charge fully. New batteries that refuse to charge at all may be defective. Purchase a new laptop battery to replace the defective one.
2. Test the laptop power adapter to see if it's faulty. Run the laptop directly from the laptop power adapter and without the battery. If the laptop does not work with the adapter plugged in, the adapter is dead and you will need to replace it. The laptop battery may refuse to charge if the adapter is faulty. Charge the battery with the laptop turned off.
3. Insert the laptop battery into another laptop to test it. If the laptop battery charges in another laptop, the laptop's motherboard may be bad. Replacing a motherboard in a computer can be very expensive. If the cost to fix the computer is not worth the cost of replacing the motherboard, consider purchasing a new laptop.
4. Reinstall the battery to ensure all connectors latch properly. The latch mechanism that holds the laptop battery should click into place. If the latch does not close, remove the battery and examine the compartment for signs of damage.
5. Troubleshoot the BIOS to determine if there is a hardware problem. Turn on the laptop and immediately enter BIOS setup by holding down the "Del" and "F1" or "F2" keys, depending on the make and model of the laptop. When the BIOS screen appears, see how long it takes for the battery to charge down. If the battery does not last as long as the BIOS setup, a hardware failure may be the problem.I hope you find it very helpful. Best regards.
Dec 05, 2012 | Lenovo Computers & Internet
Battery light flashing amber
Is the battery a exact spec.? Some aftermarket batterys, inexpensive replacements, do not play-well with your laptop. If you purchased from a computer store, return for a replacement. That said, It may be that it's not fully charged or need to be drained and charged, cycle it a few times. Some batteries have to go through a "learning" process. It says fully charged in windows software, right? again, some replacement batteries don't play-well with windows.Its a "pins" thing in the battery connector.
Nov 19, 2012 | Lenovo Computers & Internet
The battery on my c650 laptop has a charging problem
Your battery may not be securely in the laptop.
You may also need to purchase a new laptop battery.
I would go to ebay or amazon to find a decent priced laptop battery.
Aug 26, 2012 | Toshiba Computers & Internet
I have a Dell XPS M1210 laptop for which I have just purchased a new 9-cell compatible battery. It worked great for a couple of hours, but now shuts off immediately when unplugged from the AC power supply....
You might want to try what I did when I had a completely discharged battery for my Dell Laptop. I attached the battery to the computer, make sure the computer is off and plug in the charger for a full twenty four hours (undisturbed). And this really worked. I had no problems with the battery. Good luck.
Feb 26, 2010 | Dell XPS M1210 Notebook
Batery hang problem
batteries have a charge memory in the, when you purchase a new battery the best thing to do is to fully drain the battery before charging it up, this will tell the battery that it needs full charge, if you charge the battery before this it will only charge the battery to a certain percentage.
what you need to do now is find a way to fully discharge the batteries
kind regards
Dec 23, 2008 | HP Compaq Business NX9110 Notebook
Open Questions:
See all HP OmniBook 6100 Notebook Questions
HP OmniBook 6100 Notebook Logo
60 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
