Question about GE Microwave Ovens
Unable to open the microwave door since this morning. the oven still works but its closed. when press at the bottom right side corner, the door supposed to be open.
    Scholar:
  • 53 Answers
More than likely, the little lever behind the button has broken. You may notice there is less resistance when pushing the button, but perhaps not if your model has a spring behind the button as well. If your handy, you could remove the front panel and take a look at it, but if you dont feel comfortable doing this, it may be equally as expensive to repair this as it would be to buy a brand new one. I'm assuming its out of warranty at this point, but if not, send it back!
Posted on Sep 11, 2009
The CD door will not open.
Is it Microwave ?
you mentioned Cooking range in elsewhere for the same question.
Or is it Music system with CD?
Jun 27, 2016 | Microwave Ovens
Oster microwave starts when door is closed but no buttons pressed
This is usually caused by a door switch that has come loose or out of adjustment.
Jul 19, 2014 | Oster 0.7 Cu. Ft. Countertop Microwave -...
My microwave is cooking without me wanting it to
The fact that pressing CANCEL did nothing leads me to believe the controller may have failed but a failed door interlock could be a contributing factor.
Jan 08, 2014 | Kenmore Microwave Ovens
I have a Sharp Microwave Carousel R-420B. I put a bowl of soup in , closed the door, pressed Minute Plus, and hit Stop with approx 20 seconds to go... pressed the door release but nothing happened... door...
Usually, the door lever or hinges is the cause of this type of problem.
But in this case, I don't think the door lever or hinge is the cause of your problem.
I think the door is jammed and only needs some force before is can open or unjam.
Use your hands or a flat Philips screw driver to forcefully open the door. Don't apply too much force. Just apply a reason amount of force that could open the oven door.
Before you attempt to forcefully open the microwave door, leave it for about 45mins to 1hr, after that forcefully open the door.
If the above doesn't help to open the door, please let me know so that I can direct you further.
I wish you good luck.
Regards.
Mine does this occasionally, and it's because the door hinges have got a bit out of line, allowing the door to drop slightly, so the catch mechanism won't quite disengage.
Look along the bottom edge of the door and see if it has dropped lower than the front panel next to it. Try applying a bit of upward pressure on the bottom edge with your fingers, while pulling towards you at the same time, and with your other hand press the release button.
If that gets it open, remove last night's failed meal, open the door fully and carefully force it up a bit at a time, to bend the hinges back to level - keep pushing the door back so it nearly closes, and look at the bottom edge to check on progress. When the bottom of the door looks level with the panel , try closing it fully and see if the release button will open it again.
Jun 03, 2011 | Sharp R420L Microwave Oven
Spacemaker II door latch problem
Most microwave ovens have catches that are shaped like hooks, these hooks catch on a fixed bolt or a raise in the frame of the oven.
The next time you get the oven open check these hooks to see if the springs are working in a strong positive manner, or if you have to push a button on the model check to see that the button releases the hooks.
Hope this helps.
Feb 16, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Broken latch microwave door - won't open
I have a semmins microwave working in great condition, last night the latch mechanism inside the microwave don't allow the door latch to close.Only the top portion, bottom portion is ok.
Sep 14, 2008 | Sharp R-1870 Convection/Microwave Oven
It works even if I open or close the door.
if thats a microwave.. then the sensor of the closed door is broken.. thats why it worked even when open.. and that is really dangerous...
so.. your best bet would be opening it and find the broken thing that tells the microwave when its closed...
that thing is usually the little secures attach to close the oven..
if its not a microwave, the problem might still be something similar to this..
Jan 08, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
My Microwave flickers and buzzes
This problem normaly happens when the door is not closed properly for a long time and flashing and buzzing starts to give user a indication for same. Allthough it is not risky as microwave oven has safty door switches wich does not allow oven to operate while door is open. Take care and close the door properly before you leave kitchen..
Aug 02, 2007 | Kenmore 66469 / 66462 / 66464 Microwave...
Microwave Ovens Logo
125 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
