Question about HP Computers & Internet
Will not star
Compaq EVO N1610c.
Will not start. Power adapter ok
    President:
  • 1,187 Answers
Here's one trick to power up the laptop:
The battery may be too low for the power supply to charge it AND power up the laptop.
1. Remove the battery from the laptop
2. Plug in power adapter
3. Turn ON laptop; it should startup
4. Logon (if required)
5.Wait for the OS (Windows?) to settle down....
6. Put battery back in
7. Allow battery ro recharge a few hours.
Optional:
(8. Obtain a heavier-duty (more watts) power adapter.)
(8A. You will have a spare to keep at your desk and one in the case)
If that doesn't work, then perhaps the power jack on the laptop is damaged. Check to see if the power plug at the laptop is "loose". If so, then:
1. Move the power plug to the left or right to see if the power lights on the laptop change on/off.
2. If they change, move the cord to whatever will keep it ON and charge the battery.
3. The jack may have come disconected (un-soldered) from the motherboard.
UNLESS:
1. The power cord plug may be defective. You said that the power adapter is ok; however, if your conclusion is based on the fact that the LED light is ON on the adapter, it means that the power is at least getting to the converter part, but not necessarily to the plug at the end of the cord.
2. If you can further test it ... on another computer or voltmeter or use another adapter on your laptop (swap with someone, but don't use anything other than a Compaq power adapter).
I hope the first solution works! Please comment... to let us know...
Posted on Sep 11, 2009
Compaq evo n1015v will not boot up when power is pressed
For this kind of issue, please follow up the following steps to check:
1.confirm the battery and ac adapter connect the laptop normally.Maybe the bad connect lead to this problem. If there are no lights when you turn on laptop, one of possible reason is that your adapter is malfunction.
2.the second possible cause is laptop dc jack failure. If the dc jack is broken or loose, you are required to replace it or repair it.
3.Another possible reason is that there is something wrong with laptop motherboard. For this situation, it includs two kinds of possibility,a failure in an electronic circuit and BGA malfunction.
For more detailed reasons and solutions, please have a look at the following article:http://www.ifitjams.com/lappower.htm
If you verify your laptop adapter is dead and you plan to order a new one, I recommend one for you on the basis of your laptop model:
http://www.chargerbuy.com/replacement-compaq-evo-n1015v-ac-adapter-90watt.html
Dec 18, 2012 | HP Compaq Evo Notebook N1015v (470046-573)
If i plug an ac adapter 19 volts 4.7amperes to my compaq evo n610c, will it broke
YES - the N610c uses hp power pack 402018-001 18.5vlts 3.5amp 65W 50/60hz -
Jun 16, 2010 | HP Compaq Evo n610c Notebook
I Have A Compaq Evo N600c Laptop No Power Help!!!
Yeah it could be. Always use the correct adapter mentioned for your laptop. Otherwise it could harm the inner wirings and the motherboard. Always go for the right adapter. If it was any motherboard problem, atleast it would've blinked. So this might be the problem of your adapter or may be of the power button.
Apr 18, 2010 | Compaq Evo N600C PC Notebook
Compaq evo n600c battery wont work
wrong battery for it or connectoers on battery dirty could be the charger for the battery is bad and shorted battery out
Mar 26, 2009 | HP Compaq Evo Notebook N600c
Evo n610c
The computer's power light may blink to indicate that there's a problem with the power from the AC adapter.
Mar 25, 2008 | HP Compaq Evo n610c Notebook
EVO N600C 'S POWER SUPPLY
Sounds like the power adapter connector on the motherboard needs to be replaced. or soldered in tighter.
Mar 23, 2008 | HP Compaq Evo n610c Notebook
No power
You sound like you have either a dead power supply inside or a dead motherboard. Best thing is to open it up and test each. replace the culprit.
Feb 18, 2008 | Compaq Evo N610C Notebook
Evo 610c won't turn on
see may be your battery is completly discharge everything is ok just charge it completly it will work
Oct 08, 2007 | HP Compaq Evo n610c Notebook
Power failuer
First off it?s a fairly risky proposition to plug a power adaptor from one device into another without making absolutely sure it supplies the correct voltage, amperage and has the correct polarity. Your laptop needs 18.5 volts, 3.5 amps, and approximately 65 watts to charge the battery. If you power adaptor is less that 3.5 amps it will shut down to prevent any damage so that?s probably what is happening. I would suggest going to the HP (now owns Compaq) or Ebay web sites and purchasing a replacement there.
Jul 24, 2007 | Compaq Evo N610C Notebook
Computers & Internet Logo
71 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
