Question about Acer Aspire 5920-6727 Notebook
My ACER 5920 will not boot up when the charger is plugged in th
When the charger is plugged in the Green led on the charger flashes and is dimmer.
Laptop is dead any help or advice would be appreciated
    Scholar:
  • 85 Answers
Things to try:
1. With the power unplugged from the laptop remove the laptops battery
then plug the power cord back in and give it a try.
2. Try another power adapter. Generic replacement laptop power adapters usually work well for this purpose, and if not they work well on your next laptop.
3. The computers motherboard may be bad. look for another same model laptop on ebay and swap the computers hard disk drive into the replacement. If the hard disk is still good then you are good to go
Posted on Sep 11, 2009
    President:
  • 548 Answers
Try removing the battery and start the laptop only with ac power. clean the contacts of the battery, put the battery back in and boot.
try to find from a friend a similar charger and see if it starts. if not buy yourself an universal charger. it cheaper and you can use the ac jack not only for your laptop.
  • 615 Answers
Dear Sir,
By analysing your problem it seems to be your adapter dead.So first check your adapter,so your laptop battery may not have backup to turn on the laptop.
  • Chandrashekhar N.G
    Chandrashekhar N.G Sep 11, 2009
    if you have any query regarding this issue leave a feed back we glad to assist you
    good luck
Acert 5920 black screen
If your laptop appears to boot up and the hard disk LEDflashes, then the problem is probably a back light fault. This can be a faultyinverter or a faulty CCFL lamp. Please click on this link and follow myinstructions to identify the fault and possible fix :- http://www.fixya.com/support/r3598095-faulty_laptop_lcd_screen
Mar 04, 2012 | Acer Aspire 5920-6423 Notebook
Acer Aspire 5920 won't turn on, the charger lights up, (bright green) until you plug it into the back of the laptop, then the light goes dim and flashes.still no power to the laptop,not even the fan.
Your power supply or regulator in you laptop has gone south. sorry no quick fix for this one. It needs repaired and would include tracking down soldered connections.
sorry to tell you this.
clb199@yahoo.com
pls rate me 4 stars
Nov 27, 2009 | Acer Aspire 5920-6727 Notebook
My Acer Aspire 5920 is not booting up. When the power supply is plugged into the wall, its green LED is solid. As soon as I plug it into the laptop, the light starts to flash. When connected to the AC...
Your motherboard is probably shorting out your A/C adapter, you may need a new motherboard. With a Dell, the A/C adapter light will be green when plugged into the wall but as soon as you plug it into the PC the green light goes off. Which means that the Motherboard is shorting out the A/C adapter...
hope this helps
Sep 08, 2009 | Acer Aspire 5920-6727 Notebook
Acer 5920 wont charge.
The problem is not the ram.
Remove the battery and try to boot the laptop up on AC power only, if it boots up then the problem is not the charger.
If the result is the same then there is a problem with the laptop's motherboard or the adapter itself is faulty.
If the latter is the case then you will need to take the laptop to a service center or PC repair store.
Regards.
Acer Aspire 5920 will not boot at all...
The power button may not work, that is most common in laptops, or you have a short.
Aug 23, 2009 | Acer Aspire 5920-6727 Notebook
No Power. Flashing charger green LED when plugged into computer
Check the RAm and replace with a working one, it should come up
Aug 19, 2009 | Acer Aspire 5920-6727 Notebook
I have an acer 5920 laptop will not turn on. when i plug the charger into the wall socket the charger has a constant green light. when i plug the charger into the computer the green light flashes the...
sounds like the power jack at back of computer has gone bad, check voltage of battery and see if it has good power if not then it is dead and not getting charged through port the jack at rear generally requires MB replacement and is very expensive and cheaper to get new laptop, u can remove HD from old lap top and copy data over. another choice is to get stand alone charger for laptop battery and use battery mode,
if battery tested good them there is slight chance power switch is bad
Jul 07, 2009 | Computers & Internet
Dead laptop
hi guys...can you try to remove the battery then plug the AC/Charger then see what happen..only charger no battery pack in Laptop...
thanks
Apr 05, 2009 | Acer Aspire 5920-6335 Laptop
Acer Aspire 5920-6727 Notebook Logo
446 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
