I have a 20'x30'steel framed greenhouse and want to reroof
I have a 20'x30'steel framed greenhouse and want to re roof it with Thermoclear 20mm Lexan I need specs. for loads etc and samples of the material. I am in Ontario, Canada near Belleville in the eastern part in Prince Edward County.Jerome Krause 613-393-3102 krausejohnson@sympatico.ca
I am looking for a list of dealers as well.
I have found out that GE sold its plastics unit to SABIC and contacted them
Posted on Sep 12, 2009
Testimonial: "I had to find out by pure luck calling GE numbers listed on the internet"
Broken part on the roof assembly of the 6x8x7 greenhouse
if it is aluminium frame and glass , go to a glass shop( window , showers doors etc )and see who makes the frame shape
Oct 29, 2016 | Cars & Trucks
When reroofing a house, should I remove the asphalt singles or leave them,
This is the car and truck section, but I'll go ahead and give an answer.
Generally speaking, you should not add shingles over a layer that is 30 yrs old. Some people do, but you run the risk of the old shingles warping and damaging the new layer.
Your insurance company might be a good source of info.
Oct 08, 2015 | Cars & Trucks
My house has big puck in the roof. It's making the rooftop with a sink.. how & what to use to fix this? Its an old house wood frame.
FLO call a roofing contractor FAST .you have rotted sheeting that needs replaced and possibly rafters also .we had to re-roof our home 2 years ago and decided on a steel roof instead of the asphalt shingles that were on it since built .it will not be CHEAP either way .
Sep 29, 2015 | Heating & Cooling
WHERE CAN I BUY FLEXIBLE POLYCARBONATE SHEETING FOR MY 10FEET BY 16FEET GREENHOUSE?
this product is available on line --E-Bay-- from the manufacturers---and by order from you local hardware store. Comes in a variety of profiles and lengths and colours including a uv controlled style
Oct 10, 2014 | Cars & Trucks
Replacing new tines or a complete new drum
flexrake.com/1f-lawn-rake-head-only-flex-steel.html
Apr 29, 2014 | Flexrake Lawn Rake With 21 Flexpoly Lexan...
WIRING DIAGRAM FOR A DAYTON EXH. FAN FOR A GREENHOUSE. tHE FAN GOES TO A THERMOSTAT THEN TO ELECTEICAL BOX
So far, I cannot locate a wiring diagram for an installation. However, this is a single phase "shaded pole" motor.
For a single speed, shaded pole motor, there are only two power wires. For a dual speed motor, a third wire provides a second speed. One wire will be one side of the motor coil(s)...connected to the white power wire. The other wires are the opposite side of one or two motor coils, connected to the black power wire or through a thermostat. A thermostat is simply a temperature operated switch. An additional wire may (should) be a green "grounding" wire.
Specification Sheet from Grainger.
http://www.grainger.com/product/DAYTON-Exhaust-Fan-4C361
Installation manual.
ftp://207.99.53.68/array1/pacs/AS-BUILT/D1112-50-GLOBAL-Terminal&Container(15KV_ARC-RES-Swgr_Outdoor)/D1112-50-O&M/D1112-50%20Global/BM%20%23%20549%20Exhaust%20Fan.d20100210-u113426.pdf
Mar 23, 2014 | Dryers
What is the best roof support system for a 2 car garage
Steel beams will need to be used if you want open space with no poles. Laminated beams can also be used but support poles will have to be added. Build a truss roof over top and do away with the flat roof.
Sep 25, 2013 | Behm Design 20 x 20 Two Car Garage Plan...
What is a miniature greenhouse called?
It's called a cold frame. It is a close to ground enclosure with a roof that is usually transparent.
Jan 29, 2013 | Garden
Im roofing over an existing shingle roof,how long a nail should i use with a bostich gun? thanks
1 1/4" work just fine. 99% of our roofers buy those. We rarely sell any other lengths.
Jun 30, 2012 | Air Tools & Compressors
Residential reroof, 3 layers comp. is ice & water required over eaves & rakes ???
Probably not required unless an older home or low slope roof, but very easy and not expensive to do when re-roofing. When attics were poorly insulated snow would melt above the attic from heat lost from the house, then refreeze at the eave causing an ice dam. More melting water hits the ice dam then back up under roof shingles and felt paper.
It is not required, but your specific conditions could warranty it. If your roofer is recommending it I would do it.
Aug 28, 2011 | Jensen JER-422 Universal Remote Control
Computers & Internet Logo
66 people viewed this question
David Payne
David Payne
