Question about Motorola Mobility Motopure H12 Bluetooth Headset
Motorola h12 speaker is not working, mic works fine, cannot hear anything, rings, etc connects just fine, picks up my voice but i cannot here any rings or anything on speaker
Problem with the Motorola Motopure H12 Bluetooth Headset I can't hear anything on my h12 headset. other people can hear me but i can't hear them.
Hi.
I'll really advise you to perform a FDR on the bluetooth. You will need to Press and hold the Call button while turning on the headset to turn on Reset to factory default. Follow the voice prompts to make changes to the settings.
You can find this information on the Link How do reset my FINITI to factory default
Hope it helps.
Marge
Motorola Mobility.
Aug 06, 2014 | Motorola Mobility Motopure H12 Bluetooth...
Just bought motorola 4 Talkabout MH230R they are working fine except for one which is only receiving the voice and not transmitting anything. I tried Ringing other Walkie Talkie and thats not working and...
is it water proof? did you dip it in water?... if you did that's why the mic isn't working, the call and mic isnt working
make sure the channel is on the right channel for the walkie talkie
Mar 14, 2014 | Motorola MH230R Two Way Radio
My H12 has no sound, it will answer but i cant hear anything. I've tried turning the volume up but its not working
In that case it could be as simple as needing a new little speaker. The one in there is probably high-quality, but you should be able to replace it with any little speaker-- say from a pair of headphones. I successfully repaired the same problem in my Jabra bluetooth using this method.
It could also be a radio problem, however. Bluetooth headsets allow you to talk at the same time as the other person, so they use two frequencies at once. It could be that there is something wrong with the transmitter, but I'm afraid repairing that is beyond my abilities.
Mar 20, 2010 | Motorola Mobility Motopure H12 Bluetooth...
Someone calls me i cant hear them,they hear me, my speakers work fine for everything else
If you can't hear anything.
Check the following:
* That you microphone is plug into.
* Settings on the Volume Properties should be the Mic is enabled.
* Test some configuration where as you maybe can hear your voice into speakers.
* Try it.
Jan 25, 2010 | Yahoo Messenger
I can't hear.
I am not completely sure i understand whats going on. it seems like it could be a few things because of different parts of the question.
With my CB everyone else can hear me and the signal transmits fine
Good!
I have tested to see that my CB is picking up the signal
how? A meter on your radio should either light up or a needle should swing if you are receiving.
their voices don't play through my mic of my PA
A Mic is a microphone, i think you mean speaker.
Ok this may be the cause of the problem....
Try a couple of these.
First, unplug the PA Speaker, this simple act should make you to be able to hear the incoming signal.
Make sure the CB is on AM or CB not PA
If you can not hear the speaker may be busted or an internal part may be blown. (needing the expertise of a required technician)
If you can here when you do this make sure the speaker is working by plugging it into a computer. (mp3 players will barely put out enough power to make a sound audible) if this works, make sure you plug it into EXT not PA on the back of the radio.
one more thing to check. i dont know what radio you have but try turning it untill you hear static. if its all the way the other way you may not hear anything, also turn up any RX or rec. knobs.
i have limited knowledge about whats going on, but i hope this will help fixya
Jan 05, 2009 | Midland 1001Z 40-Channels Base CB Radio
My computer is not detecting microphone when making internet phone calls.
Troubleshooting - Can't get voice chat to work.
Here are a few things you should know and check for to get the voice chat to work. · Firewalls - the voice chat feature may not work well behind company firewalls. Even though you can get other features of Yahoo! Messenger to work, the voice chat feature uses separate technology and may not work as well.
· Check connection - When you enter into a voice chat with friends, each participant should take turns trying to press and hold down the Press to Talk button. Everyone else should see their name turn red when they do that. If you see their names turn red, but don't hear anything, it may be a microphone / speaker problem, or it may be that we have more bugs that we need to fix. If you don't see their name turn red, you are probably having connection problems and that's why it's not working.
· Get the latest version - Please make sure that everyone who is using the voice chat feature has the latest version.
· Check mic and speakers - Check that your microphone works and that your speakers are turned on. Here's how:
* make sure the mic is plugged in correctly.
* adjust the mic properties.
- go to the control panel (start button -- settings -- control panel)
- click on the multimedia icon
- you should see a tab for audio
- make sure that the recording volume is set high.
* you can test your mic. by doing the following.
- Click the Windows Start button, then go to Programs, then Accessories, then Multimedia, then click on Sound Recorder
- A new window called Sound Recorder will pop up. Click on the record button (a red circle), then say a few words, then click the stop button (black square).
- Click the play button (black triangle).
If you can hear yourself fine, then your microphone is okay. If you can't hear your voice using Sound Recorder, the voice chat should not work either.
Jan 12, 2008 | Toshiba Satellite A105-S4334 Notebook
MS VX-6000 webcam Mic / Video problems
When i try to talk to talk to anyone on msn with the VX6000 webcam they cannot hear me for screeches, echos and distorted voice, i have tried everything on support site and got nowhere. When i test in voice playback it does the same. Any help appreciated!
Oct 23, 2007 | Microsoft LifeCam VX-6000 Webcam
Sound problems
Hi mack79, I would assume that you are using Yahoo Messenger on a Windows machine. By "I've done the mic set-up ...works fine there", again I would assume that you have tried the YM Call Setup Assistant and you have a green light on that. By "...connected ...doesn't...pick... voices.", perhaps you simply have to activate handsfree. If my basis for assumptions are off, pls post back with details: 1. laptop or desktop; 2. are you using an external keyboard with Audio in/out; 3. is the Logitech built-in mic the only mic attached to your PC; and 4. are you using headset or external speakers? Good luck and kind regards.
Sep 09, 2007 | Logitech QuickCam Pro 5000 Webcam
Motorola Mobility Motopure H12 Bluetooth Headset Logo
295 people viewed this question
Top Motorola Mobility Radio Communications Experts
Coss
Dennis
Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
