Question about Apple iPhone 3G
Iphone camera screen is green
When I turn my iphone on and access the camera the screen shows a green and black display almost like it is in a nightvision mode. All pictures taken look like they are being taken with nightvision
I was able to solve this problem simply by pinching my phone around the area where the camera is. Don't pinch with too much force, just enough to pop whatever seems to be loose back into place.
I dealt with this problem for a long time and was dumbfounded that the solution for fixing this was so easy. I hope this helps you and whoever else has this problem.
Posted on Nov 17, 2009
  • Joe Brown
    Joe Brown Nov 12, 2013
    Worked for me! Thanks!
SUPER HELPFUL!!!!!! Im so glad I didn't restore anything in my software!!! WHEW! THANK YOU SO MUCH!!!!!!!! In a second it was fixed!
Posted on Aug 22, 2010
4 Suggested Answers
zohail
  • 1223 Answers
SOURCE: my iphone camera just shows a black screen when i
pls see this First !! B4 reset
Straight from Apple Iphone Manual
Camera is not functioning
  1. Tap Camera, then point and shoot. Note: If you take a picture with iPhone turned sideways, it is automatically saved in landscape orientation. If you do not see Camera on the any of the multiple Home screens, check to make sure that Restrictions are not turned on by tapping Settings > General > Restrictions. If they are, set Allow Camera to ON or tap Disable Restrictions (in iPhone 2.1 software or later).
  2. If that doesn't work, clean the camera lens with the cleaning cloth that came in the box with iPhone.
Posted on Mar 28, 2009
Freddy009
  • 82 Answers
SOURCE: problem with iphone the camera shows ablack screen
Clean any debris from lens with soft cloth.
Try and download a free "camera" app from app store.
If app doesnt display camera correctly, restore your iPhone, if still not working your hardware may be damaged.
Posted on Jan 03, 2010
  • 5 Answers
SOURCE: iPhone camera doesn't work. Screen goes black.
That sounds like a software problem not saving pictures but does the shutter open up at all? Did the camera ever work or is it only recent that the problems are happening? I would suggest that you back up your phone then restore it back to its factory settings, after that sync it as a new iphone as any past bugs would just be reinstalled into it and cause the same problems. The latest software would then be installed in the iphone at the same time. Try not to download any apps for a day or so and see if that makes any difference.
Posted on Jan 02, 2011
It does not turn off at the set work pressure?
Sony Cyber-shot DSC-W5 Troubleshooting - iFixit
https://www.ifixit.com/.../Sony_Cyber-shot_DSC-W5_Troubleshoot...
iFixitCamera Won't Turn On; Power Turns Off Suddenly; Replacing Battery Terminal. Display ... If that doesn't work attempt to give the camera a good jolt. A shake of ...
D700 Control Panel Won't Turn Off - Photo.net Nikon Forum
photo.net > ... > Forums > Nikon > Nikon Digital - Cameras and Scanners
May 28, 2013 - 17 posts - ‎9 authors
Setting c2 is set to value = no limit. Maybe? ... Does the AF work normally with a halfpressure on the shutter button? In any case the top LCD ... As long as the camera isnot shut down, this is completely normal. This is like this ...
iPhone 5 Camera Not Working? Fix Your Problem ' ISeen Lab
www.iseenlab.com/fix-problem-iphone-5-camera-not-working/
May 17, 2015 - Let's go though iphone 5 camera not working black screen. ... Virus Problem : This problem can disable your phone whole system. ... Light Pressure : This will occurs when your iPhone 5 had hardware problem. ... my iphone 5 front camera is working but rear camera does'nt work show the blank screen.
Rear camera stopped working after iOS 7.1.2 upd... ' Apple Support ...
discussions.apple.com > Support > Apple Support Communities
Apple
Jan 20, 2016 | Cameras
How do i fix my iphone 3g thatb willm only power on and off and will only display the apple logo on a completely black screen and constantly blinks on and off when turned on
This is probably too late but I really hope this can help you or others.
1,Possible Reasons for your iPhone's Black Screen of *****
A. Hardware Damage
B. Failed Software Update
2,Common Ways to Fix the Black Screen issue in your iPhone.
A. Perform a Hard Reset on your iPhone.
B. Restore Factory Settings using iTunes
3,Best Solution: Fixing your iPhone's Black Screen issue with FoneDog
Step 1: Launch and connect.
Step 2: Detect the Affected iPhone Device.
Step 3: Proceed to the System Recovery Process.
Step 4: Download the Firmware.
Step 5: Perform Another Option for Firmware Download.
Step 6: Repair in Progress.
Step 7: Turn on the Device after Repair.
Reasons for Black Screen of ***** and How to Fix it
May 10, 2017 | Apple FOR APPLE IPHONE 3Gs PHONE CAR+HOME...
Shows strange colors- like a negative image- in all apps. Help! Not able to find solution under settings or camera
I agree with "kyleconyo"--
However, here's a different way to get there.
Go to Settings, select General, (scroll down) select Accessibility, then toggle White on Black to OFF.
Hope that helps!
Aug 23, 2011 | Apple iPhone Smartphone
Problem with iphone the camera shows ablack screen
Jan 03, 2010 | Apple iPhone Smartphone
Kodak camera shows me a blank/black screen
You have a bad CCD imager. Find a repair shop that can strip a CCD from a camera with a bad lens. This is the least costly repair.
Jul 02, 2009 | Kodak EasyShare P850 Digital Camera
My iphone camera just shows a black screen when i touch the camera app and wont allow me to take pictures what can i do
Mar 27, 2009 | Apple iPhone Smartphone
Iphone screen beoken, black liquid showing; phone stops working
hello basicly the the liquid is the lcd that lays between the screen that gives you the display if this fluid escapes it will no longer display properly and as it leaks more display will be lost ,to solve you will need to replace the screen
Jan 18, 2009 | Apple iPhone Smartphone
Display will not come on
Turn your command dial to P or to auto. Press the menu button. The screen should light up with the main menu. If it does not, find the two buttons on your camera that has small green dots beside them. Press both of these buttons together at the same time until the LCD screen flashes on the top of the camera. Now try to access the menu again. If that does not help, call 1-800-nikonux for their 24/7/365 tech help
Dec 16, 2008 | Nikon D70s Digital Camera
Camera display problem
while turn on camera it shows .....other application is runing close it and than start.
Oct 29, 2008 | Sony Ericsson W850i Cellular Phone
Les extended, screen remains black
tuen on camera then press display a few times. it sounds like the display is just turned off. the lens system should be open.
Jan 03, 2008 | Pentax Optio S50 Digital Camera
Apple iPhone 3G Logo
4,634 people viewed this question
Top Apple Cell Phones Experts
Computer Repairing
Computer Repairing
Lesley Cameron
Lesley Cameron
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
