Hi, Sounds like you removed the battery to re-charge this then needs to have the computer system re-set before anything will work back to normal. Hopefully your nearest dealer may be able to send a mechanic out to try & re-set the computer. Should you ever have battery problem next time re-charge whilst battery is still in car with the connectors still attached. Please leave me feedback, Malcolm Campbell.
SOURCE: Dual valve 1994 w124 E300
Not sure what dual valve but go to buymbparts.com, autohausaz.com or call a dealer with the vin number and youll get the right one.
SOURCE: mercedes 1999 c200 key fob
Hello Haq!
Could it be the key just needs re-coding? maybe you are worrying to much as £177 would be about right as that would need coding etc., Try phoning your local Merc dealer or take the key and V5 to them for coding (Hopefully)
Good Luck!
Paul 'W'
Onyer~EDson(:0)~[><
SOURCE: Mercedes Benz 2002 C Class 180. Key fob batteries
You have to seperate the front of the fob casing by sliding or prising at the side this will then reveal the batteries. You can get replacement batteries from most garages or your MB dealer (who will probably fit them as well)
SOURCE: have mercedes E class key fob will not open doors,
If key will not turn
Car battery flat,charge or jump to activate elec ignition
SOURCE: c240 mercedes key wont turn seems locked
I have a 2001 C240 with the same issue. I removed the positive battery cable from the battery and kept it off for 30 seconds then replaced it. Everything was reset and the key worked.
