Question about HP DeskJet 1280 InkJet Printer
HP deskjet 1280 paper jam
My printer has a paper jam and switches off automatically every time I turn it back on. Can I manually remove the paper?
  • 61 Answers
Yes you can manually remove the paper. It can be pulled out from the feed area (pulled out backwards).
To clear the jam status....
Take the back cover off, there is a reset switch in the top left hand lock hole. Push a pen (or similar) into this hole, the switch will give slightly and be the same depth as the others.
put the cover back on, all should be well
Posted on Sep 11, 2009
Testimonial: "Thanks so much for your help - problem solved."
ESP5200printer,new,paper jam message
Hi slicknick58,
Paper jam message occurs when there are stuck papers inside the printer. There are several ways on how to correct this problem, either you remove the visible stuck paper manually or replace the toner or ink cartridge. Below are the steps you'll want to follow when this problem still occurs.
1. Turn off the printer. Turn the printer off and on to see if it can automatically clear some or all of the jam.
2. Inspect the location or tray the printed paper ejects to. If the stuck paper is visible manually remove it. Remove any paper trays. Inspect them for wrinkled or damaged paper.
3. Open the printer door that allows you access to the printer ink cartridges or toner and look for any stuck paper. If the stuck paper is visible manually remove it.
4. If necessary, remove the toner or ink cartridge. Place it in a bag or away from light to avoid damaging it.
5. If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
6. If the paper does tear, try rotating the roller gears manually to free the paper . Don't force anything.
7. Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
8. If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path and try repeating the above steps again.
Hope it helps.
Thank you for using FixYa.
Apr 20, 2011 | Kodak ESP 5 Printer
Paper jam hp deskjet 1280
Hi syarief03120,
Actually you can manually remove the paper from the printer. It can be pulled out from the feed area.
And to clear the paper jam message: You have to take the back cover off, there is a reset switch in the top left hand lock hole. Use an object to push in the pin hole. After that put back the cover on. This should help you fix the problem.
Hope it helps.
Thank you for using Fixya.
Apr 15, 2011 | HP DeskJet 1280 InkJet Printer
My HP 1280 Deskjet printer doesnt print any paper even the test page and the LED of the ink cartredge still falshing while i fill the ink cartredge and its not empty so what I can do plz help because my...
hello
the problem of your printer is the mechanical board try to switch off for the moment and turn back on, remove the plug form the wall outlet. leave it off for 5 minutes.
thanks
Feb 28, 2011 | HP DeskJet 1280 InkJet Printer
The paper is getting jammed in the printer every time.
Hello
Turn the printer off and on to see if it can automatically clear some or all of the jam. Many printers provide an error-code listing on the front panel display for the area where the jam occurred. If your printer shows an error code, be sure and check the printer manual to see if that identifies the area of the printer where the jam occurred.
Turn off the printer and remove any paper trays. Inspect them for wrinkled or damaged paper.
Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
If the paper does tear, try rotating the roller gears manually to free the paper, Don't force anything, though.
If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
GOODLUCK
Jan 30, 2011 | Epson Stylus Multifunction Inkjet Printer/...
Carriage jam problem/1280 printer
If you are getting a 'carriage jam' error as soon as you turn on your printer with no tasks in progress, then check for any piece of paper stuck in the carriage. Remove the paper carefully. If the paper tears, part of it might remain inside the paper path and damage the product.
Follow the steps for fix HP Printer Carriage Jam
  • Turn off the printer and open it to see where the paper is stuck.
  • Manually move the carriage toward the opposite side.
  • Check the paper path and remove any piece of paper or any other object that is stuck in the path.
  • Reconnect the power cord and turn on the printer.
http://www.fixya.com/support/t6088190-hp_7400_displays
Sep 06, 2010 | HP DeskJet 1280 InkJet Printer
Paper keeps shifting during loading and eventually gets jammed every time
Seems like the rollers are either dirty, or worn out. Probably the latter.
“Paper jams” on page 68
“Paper or specialty media misfeeds” on page 68
“Printer does not feed paper, envelopes, or specialty media” on page 69
“Banner paper jams” on page 69
Paper jams
Is the jam in the paper
support?
1 Press to turn off the printer.
2 Firmly grasp the paper, and gently pull it out.
3 Press to turn the printer back on.
Is the jam in the printer? To automatically eject the paper:
2 Press again to turn the printer back on.
The paper automatically ejects from the printer.
To manually remove the paper:
If paper or specialty media misfeeds or skews, or if multiple sheets feed or stick together, try the following solutions.
Check paper
condition
Use only new, unwrinkled paper.
Check paper loading Load a smaller amount of paper into the printer.
Load paper with the print side facing you. (If you are not sure which side is the printable
side, see the instructions that came with the paper.)
See “Loading various paper types” on page 21 for information about:
Maximum loading amounts per paper type
Specific loading instructions for supported paper and specialty media
Troubleshooting
68
Remove each page as
it is printed
Remove each page as it exits, and let it dry completely before stacking.
Adjust the paper
guides
Adjust the paper guides:
When using media less than 8.5 inches wide
To rest against the edges of the paper or media, making sure it does not buckle
Jul 22, 2010 | Lexmark X2500 All-In-One Printer
I have a Epson stylus CX9400fax a piece of paper is jammed way inside the machine, I can't even see it to try and get it out! I've tried turing the machine on/off numerous time (still not expelling the...
If paper is jammed, a Paper jam message will appear on the control panel display.
Follow these steps to clear the jam:
  1. Gently pull any jammed paper out of the output tray or sheet feeder.
  2. If the paper is stuck inside, turn off the Epson Stylus CX.
  3. Open the scanner, remove the jammed paper and torn pieces, close the scanner, and turn the Epson Stylus CX back on.
    alert_note.gif Note: Be sure to check the far left of the carriage area when checking for jammed paper. Paper that is jammed there may be hidden from view.
If paper jams inside the Automatic Document Feeder, clear the jam as follows:
  1. Open the Automatic Document Feeder cover and remove any jammed paper.
  2. If necessary, lift the document cover and remove any paper that has jammed inside.
  3. Press OK to clear any messages on the display screen.
Jun 02, 2010 | Epson Stylus Multifunction Inkjet Printer/...
Stylus CX9400 Photo Printer: paper jammed inside printer...
May 18, 2010 | Epson Stylus CX9400 Photo Printer
Clearing a paper jam
Dear Sir,
plzz follow this step to solve your problem,
  • Step 1 Turn the printer off and on to see if it can automatically clear some or all of the jam. Many printers provide an error-code listing on the front panel display for the area where the jam occurred. If your printer shows an error code, be sure and check the printer manual to see if that identifies the area of the printer where the jam occurred.
  • Step 2 Turn off the printer.
  • Step 3 Remove any paper trays. Inspect them for wrinkled or damaged paper.
  • Step 4 Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
  • Step 5 If necessary, remove the toner or ink cartridge. Place it in a bag or away from light to avoid damaging it.
  • Step 6clear-printer-paper-1.6-120x120.jpg jQuery(document).ready(function(){ jQuery('#jsArticleStep6 span.image a:first').attr('href','http://i.ehow.com/images/a00/3f/31/clear-printer-paper-1.6-800X800.jpg'); }); If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly (see A). The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
  • Step 7clear-printer-paper-1.7-120x120.jpg jQuery(document).ready(function(){ jQuery('#jsArticleStep7 span.image a:first').attr('href','http://i.ehow.com/images/a00/3f/31/clear-printer-paper-1.7-800X800.jpg'); }); If the paper does tear, try rotating the roller gears manually to free the paper (see B). Don't force anything, though.
  • Step 8 Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
  • Step 9 If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path
  • Thanks For YOur Time,
    Apr 08, 2010 | Brother HL-2040 Laser Printer
    When i try to print something, a window pops up that says I have a paper jam and the printer has an e then a 3 flashing. there is no paper jam. I've un-installed and re-installed with no luck and I can't...
    Dear Sir,
    plzz folow this step to solved your problem
  • Thanks For Your Time,
    Apr 08, 2010 | Canon PIXMA MP150 All-In-One InkJet...
    HP DeskJet 1280 InkJet Printer Logo
    979 people viewed this question
    Seeker5211
    Seeker5211
