Question about HP Officejet Pro L7680 All-In-One Printer
HP Officejet Pro L7680 - image has unprinted horizontal sections
HP Officejet Pro L7680 - image is broken up by blank, (unprinted) horizontal bars across the printout every inch or so. So there is about an inch of printing, half an inch of blank then another inch of printing.
All four ink cartrtidges are near full - recently replaced. removed cleaned and replaced print heads as instructed - no effect.
Why is my HP Officejet Pro L7680 printing a solid 3 inch bar
I've never owned your model HP printer, but Fixya keeps asking me to solve their problems. All I can do is refer you to this webpage that solves printing problems with your model printer: Go: http://h10025.www1.hp.com/ewfrf/wc/documentSubCategory?tmp_rule=75572&tmp_task=solveCategory&cc=us&dlc=en&lc=en&product=2512009 Hope this helps you.
Jun 24, 2014 | HP Officejet Pro L7680 All-In-One Printer
HP Officejet Pro L7680 All-In-One printer. copies come out black
Probably either the scan lamp or the sensor bar has failed. Do you see the scan lamp glowing under the cover when you try to scan a document? (Lift the edge of the cover slightly and watch the underside of the cover, you should see the reflection from a bright bar of light moving from one end of the original to the other. Do not look directly down into the light if it is on!)
Nov 25, 2011 | HP Officejet Pro L7680 All-In-One Printer
I have a HP Officejet Pro L7680 All-in-One It appears to print the text in a reverse mode (just like Koranic Text). What should I do for the text to come out normal (readable)?
The image is mirrored in the printer options. Find the check mark next to "Mirrored" and uncheck it.
On the same tab of the driver you have also "Inverted" option.
Both options are usuable for press release. Mirrored images are printed on transparancy and used for preparing the drums of the typographic machines. The Inverted image is for preparing photopolymer stamps.
Aug 05, 2010 | HP Officejet Pro L7680 All-In-One Printer
How do I replace the ink cartridges on the L7680
You may view this video regarding your OfficeJet Pro: (copy and paste this link into the location bar of your browser)
http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?lang=en&cc=us&taskId=110&prodSeriesId=3601422&prodTypeId=18972&objectID=c00840264
Dec 10, 2009 | HP Officejet Pro L7680 All-In-One Printer
Can you use mirror image when copying? I have a HP L7680
The copy function does not support mirror images. I'd scan it and manipulate a mirror image with photo software and then just print it.
Oct 30, 2009 | HP Officejet Pro L7680 All-In-One Printer
Partial scanning from an HP Officejet Pro L7680
Either download the User Guide by using the link below or get your own one out of the drawer
When you have a copy turn to page 57 and set the scan to A4 you have probably got it on Letter
Click on the link
http://h10032.www1.hp.com/ctg/Manual/c00863866.pdf
Jun 16, 2009 | HP Officejet Pro L7680 All-In-One Printer
HP Officejet Pro L7680 All In One Printer Spits Out Blank Papers.
Are these new cartridges? If so, take the protective plastic off of the cartridge and reinsert them:)
Feb 15, 2009 | HP Officejet Pro L7680 All-In-One Printer
HP Officejet Pro L7680 All-In-One Printer Logo
79 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
