Machine spins and drains but clothes r still soaked
My washing machine goes through the cycle spinning and draining but the clothes are still soaked im having to spin and drain again sometimes more than once my machine is a beko wma 510s
ive checked the drainage hose n its clear as is the filter a few people have told me it could be the brushes is there any expert advice out there??
    Problem Solver:
  • 5 Answers
Checking the hose is good but also check to see if the hose end is above the pumping ability of the washing machine
Posted on Sep 11, 2009
Kenmore Series 70 Top Loading Washing Machine Model # 110.20722991 Serial# CL 1134809 Hello, Our washing machine is leaving our clothes soaking wet when finished. What could the problem be?
2 things are possible. Can you tell if the spin cycle is engaging? If the spin cycle is not engaging properly or very fast, then the water will not leave the clothes. less likely is that the machine is not draining the water away properly or fast enough.
Jun 09, 2016 | Kenmore Washing Machines
Wme8227b broken?
Possibly blockage in pressure system
Jun 13, 2013 | Washing Machines
I own a Fridgiaire washer Model# FXW223LB56. The machine will not spin on the final spin cycle and leaves the clothes soaking wet. Tub does drain but does not spin. Sounds like it's engaging but still...
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
=- =- =0
Sep 10, 2011 | Frigidaire Washing Machines
Washer will not spin goes through all cycles but clothes are left soaked
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
If you are having problems with your front load washing machine then checkout this tip...
heatman101
Apr 16, 2011 | Frigidaire GLTF2940E Front Load Washer
Spin cycle is not working. clothes are soaking wet when cycle is finished.
heatman101
Dec 21, 2010 | Whirlpool Ultimate Care II LSQ9564J Top...
Machine gets to the spin cycle and stops. Clothes are soaking in water because it won't drain.
heatman101
Sep 30, 2010 | Washing Machines
Will not do final spin cycle leaving clothes
Your drain pump has something lodged in it. Remove drain motor, open it up and inspect for obstruction. remove it then reassemble.retrywashing cycle.
Nov 12, 2009 | Maytag Neptune MAH5500B Front Load Washer
My washer won't complete the final spin cycle. It goes through the wash and drain OK but won't spin, clothes are soaking wet. I removed the drain pipe and made sure it was not blocked, also removed and...
Hello, problem here is the spin control board is bad. Remove panel under the door and you can locate the spin control at the rear right of the machine screwed to the floor. Replace it and you will be all set. Mike
Nov 09, 2009 | Frigidaire ATF6000ES Front Load Washer
Washing Machines Logo
349 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
