Question about Ruud Central System Air Conditioner
I had a 14 seers Trane installed 18 months ago. The thermostat goes blank and the system doesnt come back on until I flip the breaker or disconnect power to the ac.
  • 55 Answers
Try replacing the batteries in the thermostat on your wall. probably has 2 AA's this may fix it if not may have bad or old wiring from tstat to main indoor system. when you had a trane installed did they change the air condition components only(likely) or did they put in new furnace, new wiring, new t-stat, a full install?
Posted on Sep 13, 2009
Where are the heat strips on a rheem classic 10 seer heat pump
3 Ton Heat Pump Split System ' eBay
www.ebay.com/bhp/3-ton-heat-pump-split-system
eBayGoodman 3 Ton 14 SEER Heat Pump Split System GSZ140361 with Installation Kit.10k Heat Strip,Thermostat,Wiring, Disconnect Box,Pad. $1,912.00; Buy It ...
Jul 28, 2015 | Heating & Cooling
Where is the low voltage 24 vac transformer located?
The transformer is located in the furnace. You might want to check to make sure the furnace door is on correctly brcause theres a swich that will open for safety . Also some have a fuse on the solid state board.
May 26, 2014 | Rheem RASL024JEC-RHPNHM2421JC 2 Ton 18.50...
Had 16 xi Trane heat pump installed 3 years ago. It ran well for the first couple of years. It began to stop heating and would blow cold air only. Have tried both aux heat and reg. heat to run and neither...
That's a complicated system that needs a qualified technician to service it. Lots of people can install them and they run fine, for a few years. Your indoor unit, operating on 2 heat elements, will feel like its blowing cold air even though its heating, just not so well. And not like you are accustomed to. Each element (5kw)=22.7amps, on average. So 3 elements operating should trip a breaker. Its probably been operating on 2 heat element plus the heat pump. And now you have trouble with the heat pump. If you can't TRUST the guys working on your equipment, try someone else. A second opinion. Normally a 3 or 4 ton unit will have 15kw heat installed, heatpump or not. 5 ton, 20kw. If yours is a 3-4ton, cooling, the 100amp(or normally two 60 amp) breaker should have been installed upon equipment change out. If yours is blowing cold all the time, something is wrong with your heatpump. The electric heat inside operates only when the heatpump can't keep up(real cold outside), the heatpump is in defrost(then it's actually in cooling mode), or if you have the tstat in aux/em. heat. Try a local trane dealer? Of a technician with 15-20 yrs under their belt. A trane dealer should have trane tech support also. BIG HELP!!!
Mar 01, 2017 | Haier Energy Star ESA3183 Air Conditioner
Dear Sir,I have an Amana Distinction 2.0 Ton heat pump, SEER 14 installed in my department about 4 months ago. I've noticed that the AC has a regular pattern running in the on/off cycle and that i
You need a tech. All 14 seer units have an X13 motor which speeds up and down on start up. A tech will adjust your tstat programing. Fan stays on after unit is done cooling to help drain water in cooling and cool off heat strips in heating,
Jun 15, 2013 | Heating & Cooling
I had a power surge on my 15 year old HVAC residential Trane Unit. I can either have my insurance repair it or I can pay the difference to replace. I do have coverage to pay for Alabama state building...
13 seer minimum for new installs. I have seen ratings as high as 18 or more on
some units (410A systems)
I recently replaced my system with a 13 seer R22 system, since they are
more easily serviced and I am very familiar with them. Given the average lifespan of
a system before major service is around 10 years depending on model.
I have worked on Trane, Carrier, Intertherm and Goodman units and prefer the Goodman
units, as they seem to be much quieter running and are built in America.
Jul 15, 2011 | Heating & Cooling
Where is the reset button on an Amana ASZ14 unit?
I don't think the Amana ASZ14 Heat Pump has a reset switch, but you can still reset it by resetting the power (when it's not running... turn your thermostat OFF first).
To reset the power, locate your circuit breaker box. There should be a double-breaker for the Heat Pump and another double-breaker for the Air Handler. Turn them both off for at least 2-3 minutes. Then flip them back on and turn your thermostat back ON.
You're thermostat may also have a RESET button that you can push. I have to reset mine every time I change the batteries in it.
Here are some more repair tips...
Heat Pump Troubleshooting & Repair:
http://www.hometips.com/repair-fix/heat-pump.html
Heat Pump Troubleshooting Repair
Amana ASZ14 web page:
http://www.amana-hac.com/products/heat-pumps/14-seer-asz14
ASZ14 Heat Pumps
Amana ASZ 14 SEER Technical Manual
(45-page PDF):
http://www.manualslib.com/manual/877256/Amana-Asz-14-Seer.html
Amana ASZ (and ASX) Service Instructions (66-page PDF):
http://www.acdirect.com/media/catalog/files/RS6200006.PDF
Jan 11, 2011 | Amana PTH123B25AJ Heat Pump Air...
Inside Electric Furnace/Air Handler Not Working. Please help!
ok this can be simple or tricky is the breaker that trips the same size as the one in the breaker panel 2.look in the unit itsself see if there r breakers inside the unit there usually are and they might have tripped it might be as simple as flipping a breaker but the problem with the breaker tripping is what concerns me now it may just be undersized or getting weak and finally crapped out get ur meter and flip the breaker on and see if u r getting power to the unit if ur not u have gott a breaker that isnt letting power go thru now if u have power u might have a bad blower motor turn the unit on and calling for the fan on if the fan doesnt start try spinning the blower by hand now if it starts then u probably have a bad capacitor they r usually mounted on the side of the blower housing it is oval and its gonna be a 5mfd(microfarad) or 7.5mfd and that couldve been what was kicking the breaker now if the blower is stuck and it wont turn or its very hard to turn then make sure the blower wheel hasnt slipped on the shaft and is rubbing up against the housing if it is just loosen the set screw and set it back even and tighten it back up now if the wheel is free and its still hard to turn then u have a bad blower motor its not a big deal to change out and not real expensive if this dont help hit me back and well walk thru it hope this gets lil momma and the pets warm have a good day
Feb 26, 2010 | Heating & Cooling
My dryer will not heat. I had this problem about 6 months ago. I have a res6745rq0 model.The thermostat was replaced and the fuse 6 months ago
try flipping you breaker off and on 2 or 3 times (hard and fast) if this don't work check element, timer , thermostats and safety switch on motor 2 heavy red wires (check wiring diagram for pin numbers of safety switch)....if this switch goes bad the motor will still run but it wont let power go to element
Aug 16, 2009 | Dryers
A/C not turning on - Digital screen is blank
Your honeywell should have battery back up but the primary power for this is a 24 volt transformer located in the air handler probably in your attic. All these controls run on 24 volts
Jul 11, 2009 | Honeywell Programmable Thermostat Heater
Ruud Central System Air Conditioner Logo
333 people viewed this question
Top Ruud Heating & Cooling Experts
Bill Long
Tim Whalen
Dennis Boxerman
Are you a Ruud Heating and Cooling Expert? Answer questions, earn points and help others
