Question about Zenith R45W47 45" Rear Projection HDTV
Blue wont alaign
What is the mechanical setup and the electrical setup? I have my tv apart and need to know how to get this fixed.
  • 556 Answers
If the blue will not align then most likely you have a convergence ic that has gone bad and maybe some of the low ohm resisters that are next to it.
Posted on Sep 11, 2009
My xenius blue light is on but the tv wont actually come on?
Try unplugging the tv and re plug in. Or you may have an issue with your power board.
Apr 13, 2013 | Televison & Video
Channel setup
for that you should tune your tv to get the channels try
Jun 16, 2008 | Durabrand DWT1905 TV
Xenius 37" lcd blue light just keeps flashing
my 37" xenius tv started losing its picture to a stripe screen then started flashing red blue green .know wont come on at all .wht part do i need to fix it please
Aug 07, 2012 | Televison & Video
Pioneer Elite Pro-118 rear projection tv
ya mine did something close to the same. at the moment i covered the blue canon inside the tv now the picture isnt 2 of eveything. the tv comes apart easy from the front good luck mike
May 02, 2010 | Pioneer PRO-200 60" Rear Projection...
I have faulty cassette mechanism it keeps ejecying the tape can this be fixed
Yes that can be fixed its a mechanisim alaignement problem you a specilized tech in camera to fix it;
or its just need a goog air but the camera as to be open to be clean if you are not a tech dont open that
it's a complex machine...
Feb 22, 2010 | Canon MV800i Mini DV Digital Camcorder
The rear door of my peugeot 307 will not open??.
Hi
Try pushing against the door while lifting the handle then pull it hard. they stick on the 307 because the latches dont alaign properly, if that does not cure it try locking and unlocking the car's central locking repeatedly, while still trying to open the door.
If that does not fix it then you will need to remove the door card/door trim. It sounds like either the mechanisim has failed or the rod which connects the mechanism has came off, this can be a tricky job as normally you would have the door open to remove the door trim. you may not get the trim all the way off you might have to put your hand on the inside of the door and unlock it, try pulling each rod gently, and feel around where the latch is try and free it.
Like I say theres no easy fix for this fault, it may take you some time to get the door open.
Let me know if you need more info
Regards
Dan
Jan 23, 2010 | 2005 Peugeot 405
Ws-65611
you have convergence menus
Activate ……..MENU-2-1-5-9
Coarse Green Tilt
Coarse Red & Blue Tilt
the TV should have a Crosshatch or convergence signal
green done first to make it level
then blue and red to match the green
be carefull not to change any other setting other than the Tilt; because you can really mess up your convergence
if the menu adjustments dont do this for you:
you have a light box assembly inside the set that has the Red, Green and Blue Guns mounted on it: it can be mis alaigned as a whole causing what you are discribing. Also, you have a mirror that relects the guns onto the back of your screen: less likely but it could be misaligned..
Just be carefull not to touch any of the following:
wires, circuits, circuit boards, heat sinks, and especially the three Big wires that go to the 3 picture tubses... they have high voltage
the heat sinks could also be live .. Just be carefull !
make sure you have really good lighting and room to work and you should be able to fix this without a problem.
Ed
Apr 09, 2009 | Mitsubishi WS-65611 65" Rear Projection...
42' polaroid tv wont show screen still
well if the light stays blue , that means its still on ...what you may need to do is go to your menue and select the setup selection and then go to tuning band.....i belive it will be on page 32 of you manual, under customising the setup settings....in order for the tv to start working it needs to be able to scan for channels.....if you are useing a cable company like comcast or direct tv...depending on how you pluged it into the tv ,(like using the input 1 or 2 , s-vidio, cable , ectra,)...you need to push the input button thats on the lower right side of your remote and select the propper input area as to how you hooked up your cable box
Dec 14, 2008 | Televison & Video
WONT WORK *****
if you see near plug it might be due to sparking in socket or plug by calling electrician it might be repaired easily. But you have seen blue light in tv & chattering sound than it is dangerous. do not put on tv &call skilled person.
Sep 15, 2007 | RCA 32V550T 32" TV
Zenith R45W47 45" Rear Projection HDTV Logo
26 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
