Home | Insignia | 600W Bridgeable Amplifier with 12" Subwoofer | Sub stopped working, unl...
Insignia 600W Bridgeable Amplifier with 12" Subwoofer
Problem for Insignia 600W Bridgeable Amplifier with 12" Subwoofer
Sub stopped working, unless i push on it?
By schurney on Sep 11, 2009
I have a 12" MTX Thunder sub is in great shap but wont work. I know the rest of my gear works fine.
if i hook up the MTX nothing. If i push in on the cone a bit, it will start working agin till i let go.
Anyone know what this is or how to fix it.
Thanks
Shaun
Best Solution
posted on Sep 11, 2009
Helpful)
print-or-die
Rank: Guru
Rating: 88%, 42 votes
sounds like maybe the wiring from the cone to the magnet is ripped or broken.... which is why when you push the cone in it works because it pushes it far enough to make the wires touch just barely, but when you let it go the wires seperate and you get no sound.
Your wire is built with slack, so when the cone goes in and out during a song, the wire can move with it and not get broken. but when you cone moves too in or too far out, then that wire can snap or become disconnected.
I have fixed this by soldering the copper wire, but you may lose some power because your copper wire might be a bit shorter(it will probly break again)... or you can lengthen it, but it is not easy to solder... some places will fix it for you but the cost may be more than what it is worth.
This is just a guess, take your speaker outta the box, and look to see if these wires are broken, lose, or frayed.
good luck.
Comments:
Sep 11, 2009
- i thought i gave a pretty detailed explanation... should have given me 4 thumbs up.. next time ill just say to buy a new one
Was this helpful?
Yes
No
3 people thought this was helpful
Popular Solutions for Insignia 600W Bridgeable
Questions and Unsolved Problems for Insignia 600W Bridgeable
Do you recommend Insignia 600W Bridgeable Amplifier with 12" Subwoofer?
Answer
Answer
my 12" subwolfer has two ports how do i install it to my amp
Answer
can i connect 4 speakers and asub to a kenwood kac m645
Answer
i have got ford fiesta zetec climate 1.4. For some reason my two speaker has stopped working, front... (More)
Answer
How do you get at the rear speakers on a Rover 214......Cheers Spanner
Answer
i bought an insigna kit i guess off of ebay with 2 12' subs and an 600 watt amp now on one of da sub... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Insignia 600W Bridgeable...:
Top Car Speaker and Sub... Experts
Rank: Guru Guru
Solutions: 14736
Experience: 40 years of automotive repair work, home appliance repair experience and general electrical repair.
Ask Me
Find more Car Speaker and Sub... Experts
Top Audio & Video Equ... Repair
(888) 737-1752
XBOX360 & PS3 REPAIR EXPERT SERVICE We can...
xbox360 fixer
(888) 399-5512
EverGreen Electronics is the ONLY Apple iPod and...
Apple iPod Service
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
