Question about Bosch Ovens
My sagi oven does not power up
I moved to flat and the sagi oven does not power up, i have checked the power supply and the same line has the hot plate connected up which is working.
when i turned the therostat to heat the oven there is no power light comming on and oven light does not work either
i hope someone will give me some suggestions please
SOURCE: smeg single fan oven
I have the same problem. The oven was working fine until I cleaned it. There was a power failure during the cleaning, but it appeared to function properly until the cleaning cycle finished. I spoke to Dacor customer service and they told me there is a "high limit" switch to ensure that high temperatures do not damage the electronics. They recommended calling a local servicer to come and check the oven and reset the switch. They indicated that the servicer may be willing to tell me over the phone where the switch is so that I could reset it myself. They like to have someone come out just to make sure nothing else is wrong with the oven. Given that there was a power failure in my case, chances are a simple reset will do the trick. You may have a similar situation. If anyone knows where the switch is, it would be good to share on this forum. In any event, I'll call the local service department tomorrow and try to find out.
Posted on Oct 31, 2006
SOURCE: Oven won't work after power cut.
The power outage may have been a result of a power surge or included one. Check the surge protection, breakers or fuses, most likely found inside control panel. Of course turn power off to stove before opening up the panel. Breakers should be pushed all the way off before being pushed to the on position.
Posted on Nov 05, 2007
SOURCE: leisure rangemaster 55 gas cooker
It sounds exactly the same as I am experiencing on my oven of the same model. My theory is that the full flame gas is controlled by a thermostat, and that this has broken hence why the oven only stays on preheat. This will be a matter of a replacement part. Most likely the thermostat is a bi-metal strip that, because it has heated and cooled so many times in it's life it has simply finally given up. Try searching online for the correct part and get a corgi registered fitter or another suitably qualified fitter to come and replace it.
Posted on Apr 07, 2008
  • 112 Answers
SOURCE: GE double oven wall, JKP85B0A3BB
I would start by checking all of the door switches. Once you remove the shell, you will see them all on a rail where the door latch goes. Some will be normally open, some normally closed. If they all check out, check all of your overloads and thermal fuses. They should all read closed. If they all check out as well, replace your magnatron, capacitor, and diodes.
Posted on Oct 25, 2008
SOURCE: Won't start
I wired the oven to a different socket temporarily to check it and all the display lights came on immediately so I assume every thing else will work on a permanent supply.It is in fact a supply problem at the oven supply point and the electrician who rewired the house is coming tomorrow to solve the problem hopefully.
Posted on May 18, 2009
Hi I have a sagi wall oven and I carnt stop the beeping any help will be great
pull or turn off the ovens main fuse at the house power board
if beeping continues after power is restored to the oven
turn off the ovens power again
get the oven checked out by an electrician
Apr 09, 2017 | Ovens
Jtp45 lower oven hot heating on any cycle
Possibly a tripped thermal fuse. Should be located behind the panel in between the upper and lower ovens. Might have a red reset button on it you can push down. If it clicks and then works again, look for possible cooling fan problems.
May 12, 2014 | GE JTP45 Electric Double Oven
Sagi oven grill works oven dosent
it sounds like the heating element
Aug 24, 2012 | Ovens
The oven is not getting to temperature
Check the breakers/fuses that supply the power to the oven. It sounds like it is not getting enough power.
Jun 16, 2010 | Whirlpool AKZ159IX Oven
Oven says: ''supply open neutral'' no buttons work what to do?
That means the range is not connected properly, or the power supply to it is not correct. The range needs the neutral (along with one of the hot leads) to supply the 120 volt portion of the voltage required to operate the control. On built in ovens, the red and black are connected to the two hot supply wires, the white to neutral, and the green or bare copper wire to ground. If your supply only has three incomming wires (older homes) then the green (or bare copper wire) and white are both connected to the neutral.
Nov 11, 2009 | GE Profile JT980 Electric Double Oven
Cold Whirlpool AKZ451!!
You may have had a surge during the storm. Check main control board in console for damage.
Sep 01, 2009 | Whirlpool AKZ159IX Oven
Ovens Logo
37 people viewed this question
Top Bosch Ovens Experts
ashburton
reliableservice
Are you a Bosch Oven Expert? Answer questions, earn points and help others
