Question about HP LaserJet 3055 All-In-One Printer
JAM IN OUTPUT BIN
I am having trouble in my printer HP all in One 3055. When I am trying to copy someting, I am getting 1 printout bot after that I am getting this Message JAM IN OUTPUT BIN. OPEN THE DOOR & CLEAR THE JAM. When I am removing the cartredge (Toner) there is no jam there. but message is still there.
  • 26 Answers
I personally couldnt find the user guide but i found a quick start user guide.
Hope it helps
Cheers
Posted on Sep 11, 2009
Display reads - " jam in output bin " jam was
look at the output area, make sure that the paper lever is working. Sometimes they come loose after a jam.
Nov 21, 2010 | HP Laserjet CM 1312NFI Color Printer
Paper Jam errror
Jam in output bin - duplex area
Error message
Jam in output bin
alternates with
Open door and clear jam
Description
Paper jam in duplex reversing area
Action
  1. Clear the jam.
  2. Press the (SELECT) button on the control panel.
  3. If the problem continues, contact HP Customer Support Center for technical assistance at http://www.hp.com/support/clj2600n or see the flyer that came in the printer box for additional contact information.
Jam in output bin - fuser area
Error message
Jam in output bin
alternates with
Description
A paper jam has occurred in the output bin near the fuser area.
Action
  1. Clear the jam.
Goodluck..
May 14, 2008 | HP Color LaserJet 2600n Printer
My printer says there is a jam in the output bin but there is no visable jam. HP color laserjet 2600n
Just try the steps
Jam in output bin - fuser area Error messageJam in output binalternates withOpen door and clear jam DescriptionA paper jam has occurred in the output bin near the fuser area. Action
  1. Clear the jam.
  2. Press the c00381085.jpg (SELECT) button on the control panel.
Jam in output bin - duplex area Error messageJam in output binalternates withOpen door and clear jam DescriptionPaper jam in duplex reversing area Action
  1. Clear the jam.
  2. Press the c00381085.jpg (SELECT) button on the control panel.Please Rate my response!!!Thanks, SF
Jan 28, 2010 | HP Color LaserJet 2600n Printer
Getting the error on my HP 4345mfp - TOP OUTPUT BIN, PAPER LATE JAM. 5017-Oct-2009 02:02 PM18209913.09.0048.081.2TOP OUTPUT BIN, PAPER LATE JAM 4917-Oct-2009 02:00 PM18209613.09.0048.081.2TOP OUTPUT BIN,...
my experience says jamming in duplex area using card stock. this may occur if default is duplexing. set default to single side and / or try same job using plain a4 80gm2
Oct 20, 2009 | HP LaserJet M4345 MultiFunction Printer
Jam in Output Bin Message
The output Bin message comes from the sensor that reads when there are to many pages printed and they are sitting on the top BIN. Check the BIN sensor or arm and make sure that it is reading. Most of the time the sensor has a broken arm the the sensor reads to let it know when the BIN is full. You might want make sure that you reconnected the sensor and you have take the top cover off to replace the fuser.
Bruce
Jul 08, 2009 | HP Color LaserJet 2600n Printer
When trying to copy papers do not feed but if you scan they will
HP LaserJet 3050z, 3050 All-in-one, 3052, 3055, 3390 and 3392 versatile printer - Error reported: Document Feeder Jam ISSUE: How to correct the HP LaserJet 3050z, 3050 All-In-One, 3052, 3055, 3390 and 3392 versatile printer if this error is reported: Document Feeder Jam SOLUTION:
  • Clear the jammed media from ADF (HP LaserJet 3050, 3050z).
  2. Remove any jammed media with care.Take out the page gently. NOTE: Take care not to tear the paper. c01075162.gif
  3. Close the ADF cover plate.
  • Clear the jammed media from ADF (HP LaserJet 3390, 3392, 3052 and 3055).
  1. Open the ADF cover plate. NOTE: Check whether all packaging straps inside the ADF are removed. c01075163.gif
  2. Unload the jam clearance component.Lift the two handles with both hands until the component clutch is released.Rotate and lift the jam clearance component, and then put it aside. c01075164.gif
  3. Lift the green handle, and rotate the paper picker until it is opened. c01075165.gif
  4. Gently remove the page without tearing it.If you feel resistance, go to the next step. c01075166.gif
  5. Open the ADF cover plate, and loosen the media gently with both hands. c01075167.gif
  6. When the media are stopped, pull the media out gently along the shown direction. c01075168.gif
  7. Close the cover plate of the flat scanner (HP LaserJet 3390, 3392, 3052, 3055). c01075169.gif
  9. Insert the jam clearance component to reinstall it.Press the two reeds until the component is properly engaged.Install the clearance component correctly. Otherwise, paper jams will continue to occur. c01075171.gif
Have a good day
Jun 22, 2009 | HP LaserJet 3055 All-In-One Printer
Getting System PCL XL Error
I think u have installed the PCL 5 or PCL 6 driver.Not to worry
Go to www.hp.com and download the PS driver for LJ 3055. Install the driver,u will not get the PCL XL error any more.
Thanks
All the Best!!!!!!!!!!1
Jan 08, 2009 | HP LaserJet 3055 All-In-One Printer
HP 3055 model scaner problem
Document feeder error means that the printer is expecting you to have a document in the ADF "automatic Document Feeder" on top. If you are having this on the laptop, go into the scanner set up on your laptop, and change the device from document feeder to flatbed. It should work fine. You can also mimic the settings from your desktop to your laptop.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Oct 02, 2008 | HP LaserJet 3055 All-In-One Printer
i want repair HP laserjet 3055
Scanner error 6
Sep 15, 2008 | HP LaserJet 3055 All-In-One Printer
Jam in output bin
Make absolutely sure there actually is no paper jammed in there.
I came to this page with the same warning, convinced I had a software glitch. Turned out there was a page accordion-folded down to the size of a pencil lead. I didn't know paper could be folded that small.
Of course, everyone here may be a lot brighter than I am, in which case sorry to waste your time. But for me, the obvious first fix needed to be thoroughly explored before cursing HP and their machine.
Jul 08, 2008 | HP Color LaserJet 2600n Printer
HP LaserJet 3055 All-In-One Printer Logo
729 people viewed this question
Seeker5211
Seeker5211
