Question about HP LaserJet 2500L Printer
HP laserjet 2500
I dowloaded a driver for my windows xp professional but every time I print I get the red light come on. When I press the green button on the top, I then get the last couple of things I printed run off again. Obviously I can get it to print but I have to turn everything off between print runs to get it back to standard mode.
    Novelist:
  • 208 Answers
I would recommend going back to the site and chosing a different driver.
There is a PCL 5 a PCL 6, PS drivers and some patches on the HP site.
You sometimes have to try different drivers to perform with your specific machine.
you do have a driver issue here. Sometimes it is frustraiting getting the right one, be persistant, it will work fine.
Posted on Dec 10, 2007
My HP Laserjet 4350 is printing 3 copies all the time even the test page.
Press the green button (with the "check" sign on it), then press the "down" arrow button four times.
The display should read "configure device".
Press the green button again.
Press the down arrow one time? until you see "printing".
Press the green button.
Scroll down to "copies"... it probably reads "3".
Set it back to "1" and then press the green arrow button.
Nov 02, 2010 | HP LaserJet 4350 Printer
I am having HP 2300 LaserJet printer. From Yesterday it started printing continuously. When you give one test page from XP It will print that Test continuously without stopping. I need to cancel the Job...
Hello .
First select the configure device menu by up & down arrow keys in display select them by pressing green button find no of copies in sub menu change this value to 1 & set them by pressing the green button.Your value set to no of copies to 1 & your problem will be 100% resolved.
Sep 19, 2010 | HP LaserJet 2300d Printer
HOW TO GET METER READING?
Switch it on and load paper.
Press the red and green buttons together, and several pages should print out, test page, config page, and perhaps a EIO or network config page.
The second page should show the page count.
Feb 03, 2010 | HP LaserJet 2500 Printer
I have a HP laserjet 2500L printer, when I try to find out the status of my supplies, by going to Toolbox/device/information. I get an error message "can't find server" I have uninstalled/reinstalled the...
you can print out a status page by holding down the green button untill all lights flash than let go..( this will than print out a config page showing your supplies status..
Jan 30, 2010 | HP LaserJet 2500L Printer
Only prints in black. Windows 7 driver update
Print a 'Configuration Page' from the printers <Information Menu>
Press the green tick button to enter the menus, and use the <, > arrows to scroll thru menus.
Then press the green tick button to select...
If, as I suspect, your Configuration Page is in colour, and looking ok - the the problem is in your computer - Printer Driver setup, or Windows......
Like all the others
Have fun.
Dec 21, 2009 | HP LaserJet 2605DTN Color Printer
Downloaded driver from HP. connected printer via
HP Support says “If the Ready light is blinking, and the Go light is on, it indicates Data in the printer memory is waiting to be printed. Pressing the GO button prints from Tray 1 or from another tray if Tray 1 is empty and the paper size is supported in the other Tray. Pressing the JOB CANCEL button cancels the current job and the printer returns to ready.
Make sure the paper size is correctly defined.
Dec 05, 2009 | HP LaserJet 2100tn Printer
Laserjet 1022 not printing on shared computers
on printer properties try to set on sharing tab check marks on : share this printer- render print jobs on client computers- list in the directory ..( all of this must be chacked).. on port tab see on what port is printer ..(tcp/ip - or virtual), on advance tab.. check alway available, spool print documents first., under security see if you have set group permission.. if you did not ,, add the computers to use this printer ( in most cases this is the problem).... if all of the above s set , and you can still not able to print .. enter in run...services.msc... find print spooler and restart it .. then try to print.
Dec 02, 2009 | HP LaserJet 1022 Printer
'Printer out of paper' message
on note pad or word you should select the paper size first because it might set to a different size. when you click file click print click properties or printing preference and choose what size of paper you have in your tray and then click ok. print ok.
check the printer paper tray setting to make sure the paper tray side guide is right agains the paper. I hope this will solve your problem.
HH
Aug 12, 2009 | HP LaserJet 5p Printer
One page jammed after switching off when 1 page printed. Orange light on
Hi ,
First off all u switched off the printer and on switch off mode press the green button and on pressing the button switch on the printer hold that button for 5 seconds and then release the button whenever u realese the button the printer start migrating . After migrating if the printer have same problem then u reinstall the printer driver and again reinstall the driver, after reinstalling the driver the printer will working fine .
May 26, 2009 | HP LaserJet 1010 Printer
Hp laserjet 4 plus printer, message window "Ready", off line button shows red
You can try to do a "Cold reset"
turn off the printer hold down  the Menu/reset button and turn it back on.
Do you hear the machine go into rotation? the 4 plus has a high pitch sound follwed by the fuser turning ( you'll know when it does it) if it doesn't go into rotation then there is another problem.
Oct 13, 2007 | HP LaserJet 4 plus Printer
HP LaserJet 2500L Printer Logo
65 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
