Question about Acer Televison & Video
I have an Acer TV 2671W which freezes intermittantly. The controls on the front panel do not work and it will not switch off.
2 Suggested Answers
vinceisaac
  • 2432 Answers
SOURCE: My RCA 52" HDTV Rear Projection TV Model
you must check the light indicator if how many times does it blink which tell the main problem or the error code of the tv. either the power supply doesn't work normally or the lamp need replacement.
Posted on Sep 24, 2013
My RCA 52" HDTV Rear Projection TV Model #MM52110JX1 will not turn on. Neither the remote, nor the front panel switch will turn on the TV. When you press the power button on the remote, the red indicator...
Sep 23, 2013 | RCA D52W19 52" Rear Projection Television
Intermittantly the curser freezes then erratically moves around the screen by itself. I am unable to move or 'control' the curser so find it difficult to shut down to do a re-start. I usually have to hold...
Make sure that you are not placing the hand on the touchpad while typing.... This might be due to the drivers issue with the touchpad.. Try to unistall the drivers of touchpad from the device manager.. Then install a fresh copy from the dell website(www.support.acer.com).. If the issue is yet to be fixed please contact Acer to replace the touchpad....
Sep 16, 2010 | Acer Computers & Internet
I have a AL2671w LCD Acer TV ON OFF switching
looks like the same problem i have with my 32" acer tv, it seems to be a problem of acer TVs get someone to check the capacitors in the power supply.... I think one might be bad.
Dec 05, 2009 | Acer Televison & Video
When i switched on the tv it looks like normal. but after a few minutes the tv shotdown .and when i tried to switched on again the tv, standby power is there but when i press the channel button, the...
It sounds like you may have faulty tact switches on the front control panel that are acting intermittently. If one of the switches is defective it can cause all kinds of erratic behaviour.
Nov 29, 2009 | Sanyo DS20930 20" TV
My Tv wont turn on, the standby light stay orange, When i press the button it should go blue and switch on but it wont.
Hi, l had the same problem. HAD !!
l bought a universal remote control (5 euro), but unfortunetly no codes for Acer in it.
Then l did the setting up by auto search and YES : there was a code. But, wheeehh, it did not work.
A little bit sad l took the Acer control and guess what: it worked again!!!!! l guess the TV had a total reset, and l use only the Acer remote control now.....
Female and blond!
Oct 20, 2009 | Acer AL2671W 26 in. LCD Television
Magnavox LCD HDTV starts on its own since last few months and sometimes it changes channel on its own. This problem happens intermittently and really apprecaite fix for this. This TV is 15 months old.
it either needs new front switch panel or new signal module, turn the tv on and disconnect the front switch board if it quits doing things on it's own you need a new front switch panel, if it still does functions on it's own you need a new signal board.
Sep 08, 2009 | Philips Magnavox 15MF400T 15 in. LCD...
Start/pause switch works intermittently. How do I
i have found that the micro switch burns out on them and needs to be replaced. remove rear screws remove top cover , remove shield the unclip cables and front panel
Use a multi meter to test micro swicth on circuit board replace if faultsy
Mar 06, 2009 | LG WM2077CW XL Front Load Stackable Washer...
Acer AL2671W stuck in standby
This too was my problem... ended up googling my heart out trying to find the solution to this problem and found a blog posting
"AL2671W Stuck in Standby Hey - I fixed a TV! It' s been a long time actually since I did something useful for someone. I got asked to look at an Acer AL2671W LCD TV. Bought for about £500 five years ago, and that was cheap then, recently it has regularly refused to come out of standby. Now it is stuck in Standby and won't work. So where do you start? Google of course! Some results showed that this was a common fault on these TV's. One guy in a forum said 'easy fix, replace C280 100uF 16V on the main board'. Good enough of a clue to take a look. You have to firstly remove the SCART socket block before the back will come off and then the inner metal cover over the PSU, audio card and main card as mentioned before. It looks just like a mini ATX card. It is a multi layer, double sided PEC with surface mount and traditional components. Bad news though, no C280 to be found. I buzzed through the front power switch to check it wasn't stuck and traced the cabling to the socket on the main board. Very close by the socket is C380, this is an electrolytic 100uF 16V. Too much of a coincidence? Anyway worth a punt I thought so I changed it for an 100uF 40V I think it was and re-assembled the TV. It worked! the TV now comes out of standby and has been returned to its owners. Result! Posted by andychamb"
I end up finding an old ATI card (since it was unsupported with win7) that had the same value capacitor and replaced C380, located around the centre, bottom left corner (the left one). works like a dream.
Jun 13, 2008 | Acer AL2671W 26 in. LCD Television
Buttons/ Remote won't operate TV
Defective tactil switch?? Remove tact switch control board.
unplug connector,use meter--check each switch.
If no problem found,leave unplugged overnight or longer.
Sony is famous for getting brain freeze!.........T.
Oct 24, 2007 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Televison & Video Logo
111 people viewed this question
Top Acer Televison & Video Experts
Gareth Cockram
Gareth Cockram
Rommel Balcita
Martin Murray
Are you an Acer Televison and Video Expert? Answer questions, earn points and help others
