I have a brand new Whirlpool electric front load (Duet) dryer. The controls are all working, but there is no heat. Any ideas?
Thank you!
Need more info on your unit the ending of the model here is a link to the service manual on this unit just pick the right ending to your model if you have any more questions please post it here http://servicematters.com/docs/wiring/wiring_main.htm
Here is the test you need
TEST #3 Heater Test
This test is performed when either of the
following situations occur:
✔ Dryer doesn’t heat
✔ Heat won’t shut off
This test checks the components making up the
heating circuit. The following items are part of
this system:
– Harness/connection
– Heater relay
– Thermal cut-off
– High limit thermostat
– Heat element
assembly
– Centrifugal switch
– Thermistor
– Machine control
electronics. See
ESD information,
page 1.
– Console
electronics
Dryer does not heat:
1. Unplug dryer or disconnect power.
2. Remove the toe panel to access the thermal
components. See figure 11, page 7. Locate
the components using figure 8.
3. Using an ohmmeter and referring to the
wiring diagram, measure the resistance from
the red wire at the thermal cutoff to the red
wire at the heater.
➔ If the resistance is about 10 ohms, go to
step 5.
➔ If an open circuit is detected, go to step 4.
4. Visually check the wire connections to the
thermal cutoff, high limit thermostat, and
heater. If connections look good, check for
continuity across each of these components.
Replace the one that is electrically open.
5. If no open circuit is detected, measure the
resistance between P2-5 (red/white wire) and
P2-6 (black wire) at the machine control
board.
➔ If 6–7 k ohms are measured, replace the
machine control electronics.
➔ If the resistance is less than 1 k ohm,
replace the thermistor
Your electrical connection is not correct on the dryer. check your owners manual and if it is correct make sure you didn't pop a circuit breaker.
SOURCE: Whirlpool duet electric dryer - drum turns; no heat
Turn off the breaker and check the heating element.
for more help go to live chat.
hope this helps
len west
SOURCE: dryer runs, no heat Whirlpool duet 9250
Most likely, it is the thermostat which controls the heating element. The Bios Thermostat will have two wires connected to a round disc which has a flange and screw holes to hold it next to the blower vent or the center of the drum. Use an ohm meter to see if it open or take it to an appliance parts store to have them check it for you. You may also see a thermal fuse and a high temperature cut-off thermostat which should not read open with an ohm meter. Any open thermostat will prevent the heater element from turning on. The part should be about $25.00.
SOURCE: Whirlpool duet electric dryer turns on but doesn't
If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat.
check outthis electric no heat tip...
heatman101
gas dryer not heating the most common problem is that the ignitor
goes bad. Even though it glows sometimes it is still not working
properly.
if
no heat
tip....
have many different things that can go wrong causing the dryer not to
heat.
check
out this electric
no heat
tip...
heatman101
We have the same problem - it's tumbling fine, but there's no heat and the clothes aren't drying. We just flipped the circuit breaker and that didn't work, so we'll try some other things tomorrow
