Question about Canon PIXMA iP4300 InkJet Photo Printer
The printer started jamming and shreading up paper. Now the paper is being pulled through at an angle if at all. When there is no paper going through the printer still seems to be going through the printing motions. How do you get into the printer to take out anything stuck?
  • 615 Answers
The following a step by step instructions for the printer issue:
First Set Prevent paper abrasion (Windows)
By using the Prevent paper abrasion function, the space between the print head and paper is increased, preventing print head contact with the paper.
When printing, if there is any foreign material (such as a piece of metal or a pencil) in the printer, the printer maybe damaged. If there is any foreign material, remove it at once.
1. Power the printer off.
2. Open the paper support and confirm that there is not any foreign material in the auto sheet feeder. If there is any foreign material, remove it by hand or with tweezers.
3. Open the front cover and confirm that there is not any foreign material in the printer. If there is any foreign material, remove it by hand or with tweezers.
4. Power the printer on and confirm that the printer operate normally.
Removing paper jam:
If the paper tears and a piece remains inside the printer, open the Top Cover and remove it. If you cannot pull the paper out, turn the printer off and turn it back on. The paper will be ejected automatically.
Paper Loaded in the Cassette Jams inside the Printer
(1) Press the POWER button of the printer to turn off the power. Then, open the Rear Cover.
(2) Fold a piece of A4 or Letter-sized plain paper in four, push it in until it hits the jammed paper, then pull out the paper folded in four.
(3) Close the Rear Cover, then press the POWER button of the printer to turn on the power.
Wait until the jammed paper is automatically ejected.
Your feedback is very important to us, please do not forget to rate my service for the site to continue helping everyone and improve on it.
I thank you for the opportunity to help and please do not hesitate in contacting me for any further questions…god bless
Posted on Sep 17, 2009
Paper jam, open cover and remove jammed paper.... how am i suppose to do that??
No video, no model name...I can assume it is a printer. There are MANY kinds of printers you know! But, here goes...THere are front and back swing doors on printers. If you find one carefully open it anfd find the path the paper follows to be printed upon. Open each door one by one until you see the actual paper jammed between the rollers. Carefully remove the paper being careful not to tear it leaving shreaded sections to get caught again!
Dec 31, 2012 | Office Equipment & Supplies
Screen stating carriage jam "Open door
Some times the paper is not visible. On my HP I have a rear panel that I can open and look between the rollers, and usually there is a small piece that will block the sensor that needs to be cleared out.
Jan 29, 2011 | Office Equipment & Supplies
Paper jam printer 3524
Clear the jammed paper as follows.
If the jammed paper is removed completely by using the information in the following steps, you can install the paper tray first, and then close the front cover and the printer will resume printing automatically.
If the printer does not start printing automatically, press the Go button. If the printer still does not start printing, please check that all the remaining jammed paper has been removed from the printer. Then try printing again.
Pull the paper tray completely out of the printer.
Pull the jammed paper up and out of the printer.
Press the cover release button and then open the front cover.
Pull out the drum unit assembly. Pull the jammed paper up and out of the printer. If you cannot remove the drum unit assembly easily at this time, do not use extra force. Instead, pull the edge of the jammed paper from the paper tray. If the jammed paper can not be pulled out easily, turn the jam dial towards you as you gently pull the paper out.
Open the face-up output tray. Pull the jammed paper out of the fuser unit. If the paper jam can be cleared, go to Step 7.
Open the jam clear cover. Pull the jammed paper out of the fuser unit.
Close the jam clear cover. Close the face-up output tray. If the paper jam still cannot be cleared, for HL-5130 and HL-5140 users go to Step 10, and for all other users go to the next step.
Pull the Duplex Tray completly out of the printer.
Pull the jammed paper out of the printer or the Duplex tray. Put the Duplex tray back into the printer.
Push the lock lever down and take the toner cartridge out of the drum unit assembly. Take out the jammed paper if there is any inside the drum unit.
Put the toner cartridge into the drum unit until you hear it lock into place. If you put it in properly, the lock lever will lift automatically.
Put the drum unit assembly back in the printer.
Put the paper tray in the printer.
Close the front cover.
Dec 21, 2010 | Office Equipment & Supplies
I have a canon printer and it says paper output slot is jammed and we don't have any paper jammed?
WEll, take it apart and look for tiny paper shreads stuck somewhere...then unplug power for at least 60 sec. and try again.
Sep 06, 2010 | Canon Office Equipment & Supplies
Printer pulls paper in from one corner
this problem occurs only when one side of the paper spooler is jammed and stuck. the spooler pulls the paper causing the paper to rotate inside the printer and getting stuck.
take professional help in clearing the jam and freeing up the spooler.
Mar 15, 2010 | Canon PIXMA MP160 All-In-One InkJet...
How do I fix a paper jam? I've got paper jam around the exit roller and I can't get it out?
There should be a way to unlock one of the sides. Try taking out the toner cartridge and going in that way. If you can see the paper, get a pair of needle nose pliers and SLOWLY see if you can pull the paper out.
Sep 21, 2009 | Samsung CLP-510 Laser Printer
Paper loading at angle annd now paper stuck inside
check behind your printer you wil see the cover pull and remove and jam paper, put off the printer before performing this task please
Jul 03, 2009 | Canon PIXMA iP4200 InkJet Photo Printer
Canon LBP 1120 Offset paper feed and subsequent jamming.
G'day, I pulled the whole printer down and gave it a clean and put it back together and set it to work. All good.
May 11, 2009 | Canon LBP 1120 Laser Printer
When going to print paper is pulled in angled and jams thanks
i do not know the model of the printer that you have, but the most common problem is that you have something stuck in the area where the paper is not being pulled in. You might have a small piece of paper jammed in there or some foreign object. It is also possible your sensor is jammed and the paper is hitting it.
Lastly, if you have 2 pickup rollers (depends on the printer that you have), one could be worn out.
thanks adi
May 07, 2009 | Office Equipment & Supplies
Canon PIXMA  iP4300 InkJet Photo Printer Logo
159 people viewed this question
old marine
old marine
