Question about Lexmark 4600 MFP
Lexmark wireless printer 4600 won't connect to computer I've followed all the instructions on the disc, HELP Rachel
otacon
  • 1944 Answers
SOURCE: Installation of a downloaded driver for Lexmark X1290 All-In_One
You need to download the Vista compatible setup here from Lexmark,
http://downloads.lexmark.com/cgi-perl/downloads.cgi?ccs=229:1:0:567:0:0&searchLang=en&os_group=Windows%20Vista&target=
Run the setup after it finishes downloading but ONLY connect the printer to the computer when the setup instructs you to do so.
Posted on Apr 18, 2008
I bought a Lexmark X1290 printer and installed a wrong driver (for WinXP) from the enclosed CD. Then I could not run the All in One program. After many reinstallation attemps, I finally found a solution (which is unfortunately quite hidden at the Lexmark website):
1) Unplug the printer's USB cable from the computer.
2) Download the cleaning utility from ftp://ftp.lexmark.com/driver/inkjet_drivers/Cleanup/.
3) Double-click on the cleanup utility and follow the on-screen instructions to run it.
4) Restart the computer.
5) Download all files from ftp://ftp.lexmark.com/driver/inkjet_drivers/Cleanup/reg/
6) Follow the instructions in the "Vista BackDoor Instructions.txt" and delete all remaining Lexmark
keys in the registry.
7) Restart the computer
8) Download a proper driver for Windows Vista from the Lexmark website.
9) Install the driver accordingly to the instructions (it's important to plug the printer's USB cable when you are ask to, not before)
The problem with Lexmark Unistall and CleanUp Utility is that you cannot delete all Lexmark registry keys while you arelogged in the system. This is anellegant way how to circumvent the problem.
Posted on Sep 14, 2008
  • 11 Answers
SOURCE: lexmark N2050 wireless adapter for X3500-4500 series printer
i cant tell you too much because i dnt know too much about your situation but try completely resseting everything and try sending something again
if its allwireless c if you can pick up the wireless points if you cant there's your problem
Posted on Jan 01, 2009
SOURCE: wireless
I had the same problem. It is now working.
The problem was a bad conecction of the network interface card.
I simply pluged it out and inserted it in and it is now working fine !!
Hope it works for you.
Posted on Feb 08, 2009
  • 3278 Answers
SOURCE: Hello, I have a Lexmark 3600-4600
Hello.
I'm trying to determine which light you are referring to. Are you referring to the front WiFi light, which blinks orange or steady green ?
If not WiFi, please be more specific as to which light.
Hope this helps.
Posted on Jun 30, 2011
Connecting to a lexmark 7600
Simply execute the printer software on your computer and follow the instructions on your computer screen to complete the installation. The program contains step-by-step instructions on how to setup your printer for usb and wireless connection.
I hope this helps.
Mar 04, 2012 | Lexmark X7675 AllInOne InkJet Printer
I've lost the cd that came with my s405 printer
Please visit the Lexmark website to download and install the Lexmark Interpret S405 Printer Driver on your computer. Select your operating system > click on "FILTER" > click on the driver under Recommended Downloads > download and execute the file. Simply follow the instructions on your computer screen to complete the installation.
Feb 24, 2012 | Lexmark Interpret S405 Wireless All-in-One...
How to stop orange wi fi light from blinking
The blinking WiFi light on your printer could indicate that it's trying to communicate with your wireless network or it's not connected to your wireless network anymore. A quick fix to this problem can be achieved by rebooting your system. Simply unplug and re-plug your printer and your wireless router into the power outlet and reboot your computer. Once everything turns back on, check the status of the WiFi light and try to print again to verify that the problem is fixed.
You can also do the following steps to reset the printer wireless network adapter:1. From the printer operator panel, press the Setup button.2. Select Network Setup.3. Select Reset Network Adapter.4. Hit the OK button.
The WiFi light will momentarily turn off and then on solid orange. You can then try to reconfigure the printer to connect to wireless network using the Lexmark Wireless Setup Utility application on your computer. Go to Start menu > Programs > Lexmark 4600 Series folder > Lexmark Wireless Setup Utility. Simply follow the instructions on your computer screen.
However, if you wish to have it connected directly to your computer. Simply connect the printer with the USB cable that came with it in the package.
Should you still need assistance, please leave a comment to my response and I'll get back to you. Should this resolves your problem, your rating will be greatly appreciated.
Nov 20, 2011 | Lexmark X4650 All-In-One InkJet Printer
I have a Lexmark 2500 printer scanner and fax all in one. I've lost or misplaced my setup disc to install on a new computer. How can I get my Lexmark to work on my new computer without the set up...
Please visit the Lexmark website to download and install the Lexmark X2500 printer driver on your computer. Select your operating sytem > download > execute the file. Just follow the instructions on your computer screen.
Sep 03, 2011 | Lexmark X2500 All-In-One Printer
How to connect my printer to wifi
Here's what you can do:
  • If this is your first time to install the printer on your computer and if you have the Lexmark installation disc that came with your printer, just insert the disc into the computer hard drive and execute the application. The software will guide you on how to setup the printer for wireless connection.
  • If the printer software is already installed on your computer, go to Start (for Windows) menu > Programs > Lexmark 5600-6600 Series > Wireless Setup Utility. Follow the instructions on your computer.
  • You can also download the Lexmark X6650 printer driver from the Lexmark website at http://bit.ly/gFQFVh. Follow the instructions on your computer.
Aug 30, 2011 | Lexmark X6650 4-In-One Wireless InkJet...
Cannot get the wireless connection to work on the printer. The USB cable is connected to the back of the PCU. I've installed and uninstalled twice and nothing. It did work when I first got it and...
Here are some guidelines to identify and fix your wireless communication issue:
  • What is the status of the Wi-Fi light on the printer? Green light means that it's connected to a wireless network while Orange light means it's not connected to a network.
  • Try to print the printer's wireless network settings to determine if it's connected to your own wireless network. On the printer operator panel, touch the Setup button > Network Setup > Print Setup Page. Your printer will then print the its wireless network information page. Ensure that the printer is connected to your network by checking the Network Card Status, Wireless SSID, Quality or Trouble Code.
  • If printer is not connected to your network, you may need to reset your printer's wireless network settings. On the printer operator panel, press Setup button > Network Setup > Reset Network Settings. The Wi-Fi light on the printer will momentarily turn off then back on to solid orange. You can then run the Wireless Setup Utility application on your computer to reconfigure the printer to connect to your wireless network. On your computer, launch the Lexmark Printer Home application > go to Settings tab > Wireless Setup Utility. Please follow the instructions on your computer screen.
If you still need assistance, please contact Lexmark Technical Support Center for additional assistance.
Aug 21, 2011 | Lexmark Pro901 All-In-One Inkjet Printer
Is the Lexmark x5495 wireless? If it is, how do you connect it to a laptop. I lost my installation disk.
The Lexmark X5495 printer is not a wireless printer, however, you have the option to connect it to a wireless print server. You can then connect the wireless print server to your wireless network so all the computers connected to your network will have access to the printer.
To connect the printer to your laptop, please visit the Lexmark website at http://bit.ly/hsBChY to download and install the printer driver. Execute the file and follow the instructions on your computer screen.
Aug 11, 2011 | Lexmark X5495 Printer
How do you connect a lexmark x2600 printer to my computer.?
If you have the Lexmark X2600 installation disc that came with your printer, insert it in your computer hard drive and it will automatically launch the software installation. Simply follow the step-by-step instructions on your computer screen. If you don't have the install disc, you can download the X2600 driver by visiting the Lexmark website at http://bit.ly/aNGYmW. Select your operating system, download and execute the file. Follow the instructions on your computer screen.
May 15, 2011 | Lexmark X2600 InkJet Printer
I`ve just purchaced a kodak esp 5250 printer.and im unable to connect to my bt home hub wireless . I`ve followed the instructions that came with the printer Can you help.Thanks
You can try to check if you have done the steps here. If everything fails, you might consider getting a USB cable to connect the printer directly to the computer first and use the Kodak Printer Setup Utility to connect. Make sure to install the printer's driver and software using the disc beforehand.
Apr 14, 2011 | Office Equipment & Supplies
Is the correct disk for the printer X3650, series 3600-4600? I bought a new computer and I think that I installed the wrong printer. I had another printer before this one, and this must be the disk from...
Yes, Lexmark 3600-4600 Series installer works on a Lexmark X3650. If that doesn't work on the computer, drivers are available from the Lexmark website at http://bit.ly/cXIEFa. Click on the Microsoft, Macintosh or Linux/Unix drop-down, found below the page, to choose the version of your computer's operating system. Download, execute the file and follow the instructions in the software. Thanks.
Sep 22, 2010 | Lexmark X3650 Printer
Lexmark 4600 MFP Logo
349 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
