Question about Kenmore Elite HE4 Electric Dryer
Dryer won't heat up. Replaced ignighter, still
Dryer won't heat up. Replaced ignighter, still doesn't work. Turns and blows air, but no heat. Gas is on.
    President:
  • 1,776 Answers
I would suspect faulty gas valve coils. These electrical coils are right above the gas valves and when energized these solenoids open the gas valves to permit gas flow to the burner. It's recommended that if any are suspected of being faulty that both (all) be replaced at the same time. Really sorry for your trouble and I hope this helped. Best wishes.
Posted on Sep 11, 2009
Dryer not heating
If your dryer won\'t heat up the first thing to do is clean out the vent from the back of your dryer up to the roof. (or where ever your vent leads to). You will have to clean it our from both ends. Use a vacuum cleaner that has the ability to switch and BLOW air rather than suck air to blow it through. This usually fixes the problem because there is no air flow and it takes HOURS to dry. If that doesn\'t work then look at the back of your dryer. MAKE SURE IT IS UNPLUGGED IN EVERY EVENT! Then disconnect the wires one at a time and clean and reconnect to make sure you have a good solid connection. Plug back in and see how if it works.
Mar 10, 2014 | Roper Dryers
Whirlpool Duet: GGW9200lq0 Dryer Works, No HEAT runs fine but has no heat... vent is clear
This happened to me. Turned out it was a gas valve fracture which had to be replaced by the gas company. That's if you have a gas dryer
Apr 10, 2011 | Dryers
Whirlpool Model LGN2000KQ0 ignighter glows, flame turns on for a few minutes then it goes out and the ignighter never glows again nor does the flame return
The problem is the dryer coils have failed. They tend to fail as they heat up. They are inexpensive and easy to replace. Here is a link that should help troubleshooting a gas dryer
Sep 25, 2010 | Whirlpool GGQ8831L Gas Dryer
I plug my electric dryer directly into the fuse box my dryer is a 220 dyer works but is not blowing hot air,. it blowes cool air what can possibly be wrong with a dryer ....because it usedto work at a...
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Jul 09, 2010 | Kenmore 62602 Electric Dryer
Cold air
heatman101
Jun 14, 2010 | Dryers
Dryer spins and drum turns, but only cold air c...
heatman101
May 20, 2010 | Kenmore 800 7982 Dryer
My dryer works (spins, blows air) but it won't hea...
heatman101
May 19, 2010 | Dryers
My GE gas dryer is blowing cold air and wont blow hot air. what could possibly be the ploblem.
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer won t Heat
heatman101
May 06, 2010 | Dryers
Dryer Ignitor turns on then back off with no flames afterwards
the government mandated that gas appliances start using electronic ignighters because pilot lights would keep blowing gas even after they blew out now the way they work is calibrated on how much amps the glow bar draws the rest of the amps go to the safety valve to open it when the glow bar is drawing enough amps to be hot enough to ignite the gas now what this means is even though the glow bar glows it can still not be hot enough to ig night the gas so the safety valves don't get the right amps to the solenoids to open so you could have a weak ignighter or bad solenoids on the safety valves now i would lean toward the solenoids but i would buy both and first replace the solenoids then the ignighter if the solenoids work take the ignighter back
May 22, 2008 | Kenmore 74602 Gas Dryer
Kenmore Elite HE4 Electric Dryer Logo
91 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
