Question about Garden
The pressure washer 100 Bar PW1300/1400 WATERGUN IS LEAKING/BROKEN AND WANT TO REPLACE IT
Can you suggest an alternative soft flexible hose for a Karcher power pressure washer 100bar
You need to ensure the Hose can handle the PRESSURE your machine is putting out. The Flexibility is a direct correlation to the requirement of the hose's ability to handle the pressure. Your 100 Bar is equal to 1460 psi. Depending on where you live, there are places that have Hose and Couplers and can make a Hose to your Specifications with the above information.
Mar 21, 2015 | Karcher Garden
Campbell Hausfield Electric Pressure Washer 1350 handle leaks
You are probably missing the washer or O-ring. Loosen and separate then check. It may also be a broken O-ring.
Oct 17, 2014 | Campbell Hausfeld PW135000AV 1350 PSI...
How to fix a leaking pressure washer
replace gasskets and washers
May 14, 2014 | Garden
How to fix 12POE-150 power washer leaking gun wand
There are no parts available for the inside of the guns. All you can do is replace the gun.
see parts in link.
http://www.ppe-pressure-washer-parts.com/12POE-150-power-washer-parts
May 01, 2014 | FAIP 1500 PSI Electric Power Washer
Not sprayer engine stop
This is an indication that the unloader not working properly. When you release the trigger the unloader senses the increase in pressure and bypasses the water into the water inlet. When the unloader is not working and you release the trigger, the water pressure builds quickly and overcomes the power of the engine shutting it down. Here is the manual for your machine, http://www.pressurewashersdirect.com/manuals/Simpson_WaterBlaster%20manual_2.pdf
and some information about troubleshooting from the manual.
"Not Unloading. Leak in Gunvalve or Hose. Repair gun leak . Replace leaking or broken hoses. Debris or wear in Check Valve. Remove Check Valve parts and clean. Check O-Ring. Reface with emery cloth, or replace checkvalve. Damaged Piston U-Cup. Rebuild Unloader Valve (Service Center)."
Usually when the unloader fails the pressure regulator will most likely need to be replaced as the unloader is usually incorporated within. For now try lowering the pressure some and just tie the trigger open untill you can service. Good luck.
Jul 14, 2010 | Simpson WS4050V Water Shotgun 4000 Psi...
Honda excell pressure washer does not have pressure
if the machine is running on suction, ie sucking out of a barrel there may be an air leak on the suction hose or pump. it will pull air easier than pulling water .
put the machine under mains water pressure, hose pipe straight from tap to pump.
check all around the pump and inlet pipes for leaks.
if water leaking this needs rectifiying for it to work on suction.
run the pressure washer while on mains pressure with the hose on, does this make a difference?
if not then probably the unloader is stuck in the pump head. remove unloader , clean and replace it
parts breakdowns are available on the internet for your machine.
possibly valves stuck, or the valve springs have broken, seen this quite few times on these machines. if so replace springs .
These sort of machines do not last very long anyway, about 50 hours use if your lucky.
Jul 22, 2009 | Honda Garden
Leaking water
The o-ring and the plastic insert is broken. They may not have a part replacement, may have to get a new gun. Take the gun apart and you'll see the problem.
Jun 18, 2009 | Karcher K2.26 Electric Power Washer
No pump pressure
Sounds like the diaphragm in the pump unit has failed, the engine and the pump are two seperate things the engine only operates the pump but if the diaphragm is leaking or broken you wont get any pressure
May 22, 2009 | Karcher 2500 PSI Pressure Washer
Leaking carburetor
replace to gaskets on the bowl and usually theres a screw/or spring release on the bottom of the bowl....replace those gaskets as well
Feb 27, 2009 | Karcher 2500 PSI Pressure Washer
Pressure Troubleshooting
Light tasks - 100 bar - garden BBQ & furniture, cycles, bins. Medium tasks - 110 bar - cars, fences, boats, pools, hot tubs. Tougher jobs - 110-130 bar - Roofs, garden decking, bricks, farm machinery.
Aug 27, 2008 | Karcher Quick Connect Nozzle Set
Garden Logo
107 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
