Question about Sony PlayStation Portable (PSP) Console
My psp was fast now slow
It works fine for everything else but when i run my game through UMD it just hangs for about 1-3minutes then works then hangs an endless annoying cycle i dont know whats wrong i tried updating it but its still no good.. please help (PSP-2000)
  • 148 Answers
Seems like your umd drive is not good, maybe could be mechanical hardware failure...try to clean and test with another umd disc...if doensn´t work try to buy and install a new one...
http://www.diytrade.com/china/4/products/3314368/PSP_2000_Slim_Laser_Lens_KHM-420BAA.html
Posted on Sep 11, 2009
Starting direct to umd and hang
If u don't want ur psp to start automatically when turning it on u can change it in the system system settings
To run the UMD smoothly yo need to:
a) Try cleaning the UMD with a clean smooth cloth gently...
b) Try cleaning the psp's umd drive (where the lens is)...
c)Put the umd properly in the drive...
Mar 13, 2011 | Sony PSP-3000 Black Console
Ive come to realise that most of the older game for psp made into download format are currently running slow in framerate,rendering and gameplay no matter what psp system i use,examples:gta vice city...
The big difference is that the PSP is having to pull everything (in terms of music, graphics, etc.) from the internal memory unit of the PSP itself. This takes processing speed and therefor slows down the entire unit. When playing a game off UMD, most of the information is being drawn from the UMD itself, which takes substantially less memory then running from the system itself. There's really no way to fix this until they get a PSP that has a beefier processor in it.
Aug 13, 2010 | Sony Ratchet and Clank: Size Matters for...
My psp works really good but when i try to play games or movies it starts to slow down and flicker
1. Set “UMD Mode” to M33 driver NO UMD
The PSP firmware version was 3.71 M33 but is also tested with higher versions like 3.8 M33. These firmware versions should have the UMD mode to M33 NO UMD.
To set the following you need to go to the Configuration Page. To go there you need to:
i. Turn off your PSP
ii. Press and hold the R button. While doing that slide and hold the power button up. This would turn on your PSP. You should hold until the black screen appears saying “M33 Recovery Menu Configuration”
iii. If the PSP just turns on to the normal menu, just repeat the two steps above.
2. Set “Use VshMenu” to Disabled.
It is also in the configuration page. Use the steps above and you should be able to find it.
Now after these two steps, if you continue no further, your PS would run faster – but only for the menu screen. The menu would be fast and really responsive. However, try playing a game. You would notice that loading is still slow and the gameplay is still played in slow motion
3. Set the CPU speed to Default.
Now this is really important. The CPU may not really be used when playing music or in the menu screen but its very important when you play games.
There are two settings you need to adjust. Speed in XMB and Speed in UMD/ISO. For us normal users we just need to set these two to “Default”.
After this, your PSP should be running ok. However, I recommend that you do another step which would also help the performance of your PSP.
4. Free up memory from your Memory Stick.
You can do this using two methods. One, you could connect your PSP to your PC using a USB cable. Two, you could remove your memory stick and use a card reader. I prefer the second method but you may use any of the two.
Method Two: Remove your memory stick and use a card reader.
Freeing up memory is easy, if you know what files to remove. As my friend is not really using her PSP for music and videos, majority of her files are game files. What she does is that she just puts games that she really plays. I recommend doing the same for your PSP.
Game files are located at the folder named “ISO”. The game files have a .CSO file name extension. You don’t need to delete them. Just transfer them to your hard disk. That way, when you want to play them again, you just have to transfer them back to your memory stick.
But if you have music and video files that take up much space, I recommend that you look into those first. Normally you would like to have at least 500MB of free disk space. You’d need the space for your game saves.
My friends have done the steps above with ease and have solved their slow PSP problems. Most of them, if not all, had to do all four mentioned above. The first three usually solves the problem.
Mar 07, 2010 | Sony PlayStation Portable (PSP) Console
Psp always read from umd,making it hang
Hi! I incounter this problem as well even without UMD its still loading and even I disable auto-start UMD still same so I tried reflashing the software but still same problem so I discover the solution before you turn-on your PSP try to open your UMD cover you'll see it will load faster then close again the cover once you see the battery and clock icon... The problem that causing this is the switch inside the UMD possible its stock-up or spoiled already!
Jun 08, 2009 | Sony PlayStation Portable (PSP) Console
My psp dosen't work well
have you modded the psp in anyway? are you trying to use homebrew apps? if you are trying to use a umd and you have modified anything other than stock then you need to clock your psp back to the factory level because the voltage is dropping too low from the umd reader activating and the strain the cpu is putting on the battery you could also try resetting everything to factory defaults afterall this is what the games are designed for
Mar 16, 2009 | Sony PlayStation Portable (PSP) Slim...
Psp(1001)won't read umd games or movies
If your PSP isn't reading games and/or movies and the problem isn't that your trying to play dirty, bent, or damaged UMD discs there are a number of other reasons your PSP is not reading disks correctly =
- Your UMD motor may be malfunctioning.
- Your laser may have worn down from use over time.
- Your UMD drive tray may be bent.
- There may be a foreign object in your UMD drive
Common symptoms
* disks fail to load
* extremely slow loading
* strange whirring noise when trying to read disks
For whatever reason your PSP has stopped reading games and/or movies we will get your PSP back to you and playing like like new fast! Our price includes labor, parts, and return shipping via priority mail.
Visit PSP UMD Drive REPAIR if you are interested in an affordable and reliable PSP repair service. We have been serving the whole United States for more than 2 years!
Jan 05, 2009 | Sony PlayStation Portable (PSP) Console
Psp games moving in slowmotion
It is the problem of the psp umd driver and thegame. The umd driver is moving slow and the umd maybe having a lot of scratches.
Dec 17, 2008 | Sony PlayStation Portable (PSP) Slim...
UMD on PSP Slim will not spin
No idea, if its not spinning u definitely need to buy a new Laser Assembly. Sry!
Nov 13, 2008 | Sony PlayStation Portable (PSP) Slim...
Where is the UMD?
UMD is Universal Media Disc, its a small disc are used for PSP.  press the "eject" button on the top to open the disc tray. Usually the problem its not from the UMD, but from the console.
The first check the version you are running on psp, >> Go to the PSP Menu and move across to the "Settings Menu". Scroll down, select to "System Settings" >> "System Information" and you should see version of your PSP. If the UMD has a high version than ur console, u need to update ur psp.
plz visit my blog, for psp update guide.
Oct 28, 2007 | Sony PlayStation Portable (PSP) Console
Psp keeps loading
http://www.answerbag.com/c_view/2832 go to that link sir! search your problem in their!
Apr 01, 2007 | Sony PlayStation Portable (PSP) Console
Sony PlayStation Portable (PSP) Console Logo
Top Sony Video Game Consoles & Games Experts
shaun taylor
marley mcelhinney
Jonathon summesfield
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
