Question about Slant Fin GF200 Air Purifier
How to clean the Slant Fin GF 200
I lost the cleaning instructions, could you let me know how to do it. I know there are several steps to follow. I remember that in the manual says to use vinegar too!..thanks
  • richdavidson Dec 25, 2007
    I need cleaning instructions!
  • Anonymous Dec 06, 2008
    I also would like to get the manual for maintenance.
    My unit used to work pretty well and sudenly just stoped.
    I would appreciate an on-line manual.
    Thanks
Http://www.appliancefactoryparts.com/content/pdfs/116637.pdf
Posted on Jan 06, 2008
Resetting Filter status after cleaning filter
MAKE SURE THAT THE LID OF THE FILTER IS PROPERLY CONNECTED SOMETIMES THESE DEVICES ARE
BUILT WITH SWITCH FILTER
Jan 13, 2014 | Honeywell Air Purifiers
Blueaire 501 dust caked up on wires and fan,how do you take it apart to clean it?
Hi, I have had the same problem and have figured out how to open it.
To open your blueair air purifier, follow the steps below;
1. Get a phillips head screwdriver,
2. Open the unit and remove the air filters.
3. Use the phillips head screwdriver to remove the screws that you can see.
4. After taking out the screws, remove the "galvanizedSwedish steel housing"
(cream coloured sides) of the purifier by lifting it upwards (i.e. from bottom to top of unit).
4. You will now have access to the interior of the purifier.
5. You can now take out the fan and clean it, or what ever part you are trying to clean. I used a Dyson HEPA vacuum cleaner.
6. To reassemble, reverse the instructions above to reassemble the purifier.
Feb 28, 2011 | Blueair 501 Air Purifier
I have cleaned my ionic pro several times works for a few minutes and then says clean again what can I do?
Please call customer service for Ionic Pro at 800-875-8577. They will provide troubleshooting instructions and if they do not correct the issue, they will give you instructions on how to get your unit replaced. Thank you.
Feb 08, 2010 | Ionic Pro TURBO Air Purifier
I do not know how to clean it. It is called Fresh
The Fresh Air has a reminder on the LCD to Perform Cleaning. This reminder will display if the purifier runs for 30 days. When this reminder is displayed perform the following steps to clean your purifier.
1. Cleaning the Case:
Wipe the unit with a soft cloth dampened with water. Do not use chemicals or solvents. Vacuum the front and rear grills to remove any lint buildup.
2. To clean the lint screen, RCI cell and purification plate:
3. To remove the back cover:
Remove the plug from the back of the unit. Unscrew the screw above the plug socket on the back cover. To remove the back cover, press the back sides of the back cover to unlatch and tilt the bottom of the back cover to remove.
4. To remove the rear lint screen:
Remove the two thumbscrews holding the top of the lint screen. Remove the lint screen by pulling back the top of the screen, then lift it up and out.
5. Removing the RCI cell:
Remove the RCI cell connector by pressing the connector locking tabs. Pull the connector straight out to unplug.
Remove the RCI cell by removing the two thumbscrews. Slide the RCI cell down and out of the unit.
6. Cleaning the RCI Cell:
Remove the RCI cell and carefully vacuum accumulated lint. Do not wash the RCI cell. Damage from water may result.
7. Rear lint screen cleaning:
You have two options
  1. When visibly dirty, simply remove the rear lint screen from the unit and with a duster attachment on a vacuum, remove the heavy particulate.
  2. In addition to step 1, the filter can be washed with hot water (do not use soap). Allow to dry prior to reinstalling. Replace if damaged.
8. Cleaning the Purifier Plate:
Remove the plate from the card cage by grasping the middle edge nearest to you, and slowly pull it straight out. Clean with mixture of one part water and one part ammonia. Place plate and ammonia mixture in a dish and allow it to soak for no more than 10 minutes. Remove plate and scrub with a toothbrush. Rinse thoroughly and air dry for 24 hours or use a blow dryer to dry thoroughly.
After all parts have been cleaned and are thoroughly dry, reinstall components in reverse order. Turn the purifier on, and on the key pad, press the reminder Reset button to clear the Perform Cleaning message.
If this has been helpful, please rate this solution. Thanks
Jan 28, 2010 | Ecoquest Fresh Air Living Air Purifier
My front control will not function. I have lost my remote. I have serviced, cleaned the unit several times but the unit always comes bak on and tell me it need normal cleaning . I cannot clear the display....
If the front control does not function, you can not clear the perform cleaning message from the display.
Contact the dealer whom you bought the machine he/she should be able to help you. The machine has a 3 year warranty.
Otherwise, contact the manufacturer EcoQuest at 1-800-989-2299 and choose technical assistance from the menu. You will be guided through some trouble shooting and if needed you will get an RMA number so you can send your unit in for repair.
Nov 11, 2009 | Ecoquest Fresh Air Living Air Purifier
I purchased a Hybrid GP germicidal Air Purifier, Model # S1724 ((Electric Air Cleaner AC110v 20w 50/60Hz)). My unit is severly malfunctioning and i nee to either send it in for repair or be given detailed...
Locate the photo electric eye that picks up the need to clean and give it a thorought cleaning. Good Luck and I hope you get it repaired. That photo cell should be your problem It's probably a little black or ruby red dot in a fin or on the housing where yhe air passes.
Jul 06, 2009 | Sharper Image Hybrid GP (SI724) Air...
Honeywell F 50 F air filter
take out the cells, they weigh about 8 pounds apiece. Make sure you remove both. Put the door back on and turn the fan in the furnace on. IF the light on the power supply comes on, then the power head is most likely good.
Then insert one cell at a time, individually. Push the single cell in all the way to the back, put the door back on, if the light is on, that cell is fine. If the cell does not come on, there is most likely a bent fin on the cell. simply bend the fin so it does not touch the other fins and you should be fine. Repeat this step on the other cell.
Make sure the door to the filter is closed, the power switch is on and the furnace fan is on.
Good luck.
Nov 18, 2008 | Honeywell (F50F1032) Air Purifier
Honeywell HFD-135 -- lost instructions -- how do i clean removable filter?
Manual can be found here: http://www.kaz.com/kaz/support/manual/?ProductManualAction=renderProductManualById&ProductManualId=47a366c04a65e77c69850893b979e142
Sep 10, 2008 | Kaz Honeywell QuietClean HFD-135 Air...
IONICPRO TURBO
I had the same problem and was about to open the unit up to see if I could adjust the sensitivity of the "clean light" trigger. Yeah yeah I know.. high voltage and all... but I'm an electrical engineer (which means I would know exactly what killed my dumb-a$$ after the fact). While looking I discovered a separate set of contacts under the swivel door. That is to say, unplug the unit, open the door, and remove the metal filter part (the thing you clean) according to the instructions. Look just below the lower part of the door (in between the door and the case) and you'll see a metal post and another metal tab. When the door closes, the two make contact which completes the circuit. In my case, they were covered with dust. I took some long Q-tips and cleaned them off and the unit started working properly again. There may be other things to clean along the circuit, but I believe that this is a step that should be done each time you clean the filter. Good luck.
May 18, 2008 | Ionic Pro TURBO Air Purifier
Slant Fin GF200 Air Purifier Logo
456 people viewed this question
Top Slant Fin Air Purifiers Experts
Michael Youngman
Michael Youngman
Are you a Slant Fin Air Purifier Expert? Answer questions, earn points and help others
