Question about Sony Televison & Video
At power On, the screen shows an array of colors and after a few seconds the video blank.
    Problem Solver:
  • 18 Answers
There are times that your TV screen exhibits color variations/problems, especially, if there are any electro-magnetic devices placed near it.
A typical example of this are hi-fi speakers, radio, mobile phones. Such devices can interfere with your viewing capacity, and may cause static on your TV screen. You may try to isolate them and see if that would help restore the normal color of your screen
Since, after some time, due to vibration from sound or movement of such equipments and due to gravity the first 3 (red, blue and green video) have the tendency to loosen some from the connections.
Go back to your TV and try pushing them in again until they feel tight again. Check you TV screen. If it continues, go to the rear of the cable box or Satellite receiver and do the same. That should bring your colors back to normal. If you are using an other type of connection, disregard this operation.
best regards,
Jazerblue
Posted on Sep 11, 2009
Emerson LC320EMX LCD color patterns
Did you find a solution, I have the same problem with my Emerson TV. Same color pattern loop. Tech support was no help and TV is just 3 months out of warranty.
Jul 13, 2010 | Televison & Video
Monitor goes blank.
Did you swap the monitors to see if the problem follows or stays at the same video output port since you have dual monitors set up? Need verify before opening up the monitor.
Mar 30, 2010 | Gateway FPD2275W LCD Monitor
My Sony KP-46WT500 screen shows the tv image in blue only for a few seconds, then it goes completely blank (as if it were off). Do I need to replace the bulbs?
It is rear projection TV that use 3 picture tubes of red-green-blue to show color picture on tv front screen.
Do you see standby red light blinking when TV shuts off after showing blue image for a while?
If red standby light is blinking, please count it how many times it blinks, there would be 3 seconds pause between blinks so count pause to pause and post it here to find out possible solution.
Thanks.
Dec 22, 2009 | Sony KP-46WT500 46" Rear Projection...
Asus Monitor boes blank and comes back after power recycle
1. You can see images on the screen for a few minutes. That means there is nothing wrong with your computer.
2. When your screen goes blank, if you disconnect and then reconnect the monitor, it shows fine again for a few minutes before going blank (or dim) again. That means the problem is not with you video card.
3. It always shows the image after reconnection for exactly a few minutes before going blank again. yes? this means that there is nothing wrong with your cable.
Conclusion: Sorry, but you do not have many options. I bleieve that the problem is with your monitor that's going bad. Its far cheaper to get it replaced than to repair it.
Oct 04, 2009 | ASUS MW221U LCD Monitor
Hp flat panel monitor comes on shows logon and then blank screen
Ok, another words, monitor powers up for few seconds and shuts down by itself. If green LED on the front panel turns off as well or stays on?
If stays on, then inverter turns into protection mode because of old backlight lamps.
If it turns off in same time with an image on the screen, then there are some bad electrolytic capacitors in the power supply.
Sep 11, 2009 | Dell E152FP 15" Flat Panel LCD Monitor
HP Pavillion DV9700 Laptop Blank Screen on Boot Problem
remove battery,ac adapter and other external medias,then hold on power button for 30seconds
later
with ac adapter attached try to power on still probs ...then its bios probs need to use bootable disk or recovery disk of your laptop
Feb 20, 2009 | HP Pavilion dv6000z Notebook
Dell E173FPb 17" TFT LCD Flatpanel
Video cards that can handle two monitors at the same time have cables with two plugs on the monitor end.
If your video cable has two plugs on the monitor end, try the other plug.
Dec 29, 2008 | Dell E173FPb 17" TFT LCD Monitor
Televison & Video Logo
23 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
