Indesit widl126 is kind of dead. Nothing happens when pushing main start button. Can anyone help? Is there a fuse to check anywhere inside the machine? Is there a reset function? Located far up in Norwegian mountains, so looong way to service
5 Suggested Answers
  • 1294 Answers
SOURCE: indesit widl126s
Suggestion: Possible your outlet filter is blocked; this needs periodic cleaning, depending on your usage. Clean this out and re-fit. Refer to your users' manual re. where the filter is....
Posted on Jun 16, 2007
evanusa
  • 197 Answers
SOURCE: indesit widl126s humming noise on spin cycle and
Your drain filter is clogged with debris. Usually small items like dirt, paper, money, and much more. Clean the filter and you should be set to go.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread. If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Posted on May 01, 2009
SOURCE: indesit 1200 washing machine boils everything and
make sure you have connected the cold water feed and not a hot water supply, these machines need a cold water feed only
Posted on Jul 27, 2010
Daniel S
  • 4323 Answers
SOURCE: Indesit Washer Dryer widl126s Error
Hi
It is an issue with the thermister which has gone bad and needs to be replaced. Hope this helps...please post back for further assistance.
Daniel
Posted on Jul 04, 2011
I have a Kenmore 70 series. About 10 years old. The inside light comes one, the timer ticks when turned but nothing happens when I push the start button. We have already checked the breaker. Is there...
you either have a blown thermostat, blown thermal fuse, or a bad heating element most likely a blown thermostat
email me if you need more help in replacing or testing
Nov 16, 2010 | Kenmore 73952 Gas Dryer
DVD player in Ford Freestar quit working with a DVD inside. It's like there is no power - nothing happens when you push the AUX button on the dash or when you push the eject button on the player itself....
Have you checked the fuse to see if it is good. you may just need to replace it. If you look in the owners manual it will show you where to find it.
Jan 30, 2010 | 2005 Ford Freestar
No engine start or any windo raido head lights nothing
Couple of things could be wrong. I would first try to have someone jump start your car, if it stays on, probably your battery, if it does not stay on, probably your alternator. Batteries you can get just about anywhere, just bring in your old one when you make your purchase to make sure its the correct one. Alternators can run you $90 - $150 depending on engine size, new or remfurbished. Check with your local auto parts store. Also, check your fuses (under the hood and inside) and make sure your battery terminals / clamps are clean. Hope this is helpful. Good luck!
Aug 10, 2009 | 2001 Chevrolet Impala
Push the start button but nothing happens
check thermal fuse inside back of dryer usually little white fuse unplug and ohm out should ge a reading if good
Aug 09, 2009 | Whirlpool Dryers
Ido not have a manual for this machine (WIDL126 ) and don't know
http://www.instructionsmanuals.com/u2/pdf/lavadora/Indesit-WIDL126-en.pdf
Nov 20, 2008 | Indesit Washing Machines
I have a indesit WIDL126. Half way through through the drying cycle all the lights on the buttons start flashing and it stops spinning. I can still hear the motor working but all I end up with is a machine...
I have had the same problem and this has worked in the past:switch off the machine, then unplug it at the mains. Leave it unplugged for about a minute then plug it back in and try again.
Mar 04, 2008 | Washing Machines
Indesit widl126s
Jun 15, 2007 | Indesit WA 125 Front Load Washer
Washing Machines Logo
126 people viewed this question
Top Washing Machines Experts
