Question about Brother HL-2070N Laser Printer
BROTHER HL-2040 MY PRINTER IS STUCK. IT THINKS IT WANTS TONER BUT I GAVE IT NEW TONER AND IT STILL WONT WORK Changed drum & toner. All lights or off exempt green/go light. motor runs high as it would if drum was needed. Wont print though.
  • 1 more comment
  • relliott Feb 21, 2008
    Same problem - I had the print cartridge refilled with toner at the cost of $67 and put the refilled cartridge back in the printer, but the toner light stays on and the printer won't print. I tried the solution listed here - holding down the GO button for 4 seconds until all the lights came on, then released the GO button - but the toner light still stays on and it still won't print.
  • Anonymous Mar 20, 2014
    Cant get cartridge out
  • Anonymous Mar 24, 2014
    I have turned off printer, slid the green tab over and everything I can think of with no help
  • 4 Answers
I think the previous post applies to resetting the drum light after replacing the drum.
You need to reset the toner end-of-life condition.
  1. Open the Front cover
  2. Press and hold the GO button
  3. Power ON the printer while continuing to hold the GO button
  4. All 4 LED's will light up and then 3. Once the 3 LED's are lit, release the GO button
  5. Press the GO button 2 times. This will cause the
    LED's to light solid
  6. With the LED's lit solid, press the GO button 5 times
  7. At this point the Paper light should be blinking. Toner end-of-life has been reset
  8. Close the front cover.
Posted on Mar 21, 2008
  • 4,402 Answers
Press and hold down Go button for about 4 seconds until al the LEDs light up. Once all 4 LEDs are lit, release the Go button.
Posted on Dec 18, 2007
How do i change the toner on m my HL 2040 brother printer
How to Change a Toner Cart in a Brother HL 2040
The Brother HL 2040 laser printer has a toner cartridge that supplies toner to the drum assembly so that the printer can print properly. When the LED on the front of the printer indicates you are low on toner, you will need to replace the toner cartridge to maintain good print quality. Fortunately, the toner cartridge can be replaced without any special tools.
Things You'll Need:
* Replacement toner cartridge (part number TN350 or TN360)
* Paper towel or scrap paper
Grasp the front cover of the printer and pull it toward you to open the toner door. Reach into the printer and grab the combined toner cartridge/drum assembly. Lift up slightly and pull it out of the front of the printer.
Place the cartridge and drum on a paper towel, spare sheet of paper, rag or other surface that can get dirty. Loose toner particles may spill from the cartridge.
Press the blue locking lever on the cartridge/drum unit to unlock the toner cartridge from the drum. Lift the toner cartridge up and away from the drum unit. Dispose of the old toner cartridge in accordance with your local regulations. Seal it in a plastic bag to keep loose toner from spilling.
Gently shake your new toner cartridge back and forth a few times to distribute the toner evenly across the width of the cartridge. Remove the plastic protective cover from the bottom of the cartridge.
Place the new toner cartridge onto the drum unit and press it down gently until it locks into place. The blue locking lever will automatically click into place. Verify that the toner cartridge is securely connected to the drum.
Locate the corona wire cleaner tab at the front of the drum unit. Slide it back and forth several times to improve the print quality of the drum. Set the tab back in the home position when finished.
Slide the combined toner cartridge/drum unit back into the printer and close the front cover.
Hope it helps...
Dec 02, 2010 | Brother HL-2040 Laser Printer
Brother HL 2040 prints extremely light and seems to smudge? Just changed out the tone cartridge and no change.
I'm not sure if the drum is going out or not. How many toners have you used? The drum is rated at 12,000 pages and the toner is supposed to yeild 2500 pages, so 4 or 5 toners ought to finish the drum. Did you clean the area around the drum? I don't think you're supposed to touch it, but I've never had to touch my 7240 in 4 years, except to change the toner.
The good news is the toner will fit in more than one Brother machine and the printers are inexpensive. It almost makes buying a new machine more economical than a drum :-}
The HL printer is Manufacturer Discontinued, the new ones use a 360 series drum and toner, and the MFC's (7220 etc.) are about $200 vs. $116 for the drum. Hmmm.
Might be time to upgrade.
Jan 08, 2010 | Brother HL-2040 Laser Printer
The drum light is flashing and I just changed the toner this morning. Not sure where I can either buy a new drum, or if I will need a new printer (which I hope not, I love this printer!)
Yes you can replace just the drum in the printer. If you think it may be under warranty give brother a call. Their number is: 877-276-8437
If you don't think it's under warranty then you can find a replacement drum for around $40, just google: Brother HL-2040 drum
Jul 07, 2009 | Brother HL-2040 Laser Printer
Drum light HL-2040 Brother
  1. Open the front cover.
  2. Locate the control panel button under the LED lights on the left side.
  3. Press the control panel button until all lights are lit, then release it.
    The Drum counter is now reset.
On older models
  2. Remove the drum and toner
  3. Press the Go buttom button until all lights are lit, (they come on one at a time) then release it.
Oct 14, 2008 | Brother HL-2040 Laser Printer
Take the drum out and wrap it up to keep the light out of it.  Check the contacts inside the printer and make sure there is nothing broken on them.  If there is toner on them, try to clean them off.
Oct 06, 2008 | Brother HL-2040 Laser Printer
Brother HL-2040
you must change a new drum also new toner
Jul 27, 2008 | Brother HL 1440 Laser Printer
Reset the drum counter by opening the front panel, then hold down the power button for about 5seconds until ALL the leds are on. Then realease the button and close the front panel. Your coutner will be resetted.
Dec 22, 2007 | Brother HL-2040 Laser Printer
Brother HL 2040 problem
if the Drum LED is still lit after replacing the drum unit, the Drum counter may not be reset.
Reset the Drum counter as follows:
Sep 14, 2007 | Brother HL 5250DN Laser Printer
Brother HL-2070N Laser Printer Logo
457 people viewed this question
James Cagle
James Cagle
Jim Keysor
