Question about Nikon D80 Digital Camera with 18-135mm Lens
Help please Sounds like a motor trying to focus/zoom and not taking pictures I taken it this is the Camera and not the lens
  • 35 Answers
Is the lens moving/focusing?
If you switch to manual focus, can you make a shot?
Is it possible that "remote control" mode is selected (the button on top, right, in front of AF button) - in this mode the camera focuses but waits for the remote to shoot - just press the mode button until the LCD shows [S]
Posted on Jan 09, 2008
I have a nikon 55-200mm lens for the D40X digital camera. The pictures I take are blurred. I use the auto settings. the 18-55mm lens works fine and there are no problems with the picture clarity. Is the...
One of a few things might be happening
1. Photos being taken at high zoom (i.e. 200mm) are susceptible to camera shake, even though the lens is focusing properly. The solution here is use a tripod, zoom out, or steady yourself.
2. Photos being taken without flash when flash should really be used will result in motion blur (which is slightly different than camera shake). This is due to the camera using a longer shutter speed to let more light in, with the side effect being that objects will move while the shutter is open, blurring the picture. The solution here is to use a flash, or take pictures in better light.
3. The camera may be focusing on something other than what you intended.
3. If you are taking photos in good light with a steady hand, and the camera is choosing the correct subject to focus on, then yes, the lens could need readjusted, though this is not a very likely scenario.
If the lens is "hunting" for focus, that could be a sign that something is amiss.
A local camera shop can verify the accuracy of focus for your lens.
Mar 04, 2011 | Nikon D40x Digital Camera
Picture not focused at 12x zoom
It's probably something to do with a lag or jam on your shutterspeed. so when you hit the button, and move you get a little blur. If its not this you might need to have your lens cleaned inside and out due to the camera zooms and catches the blurs on the lens after zooming so far in. I would recommend taking it to your local camera shop for adjustments and cleaning.
Sep 19, 2007 | Panasonic Lumix DMC-FZ7 Digital Camera
When trying to take a picture the lense moves back and forth trying to focus. When it finall stops the subject is out of focus. There is a grinding sound as it tries to focus. Some times the picture will...
It sounds like you need a new lens. This particular camera does not have an autofocus motor built in, which means it can only use lenses that have a motor already built in. Look for any Nikon lenses that have the AF-S in their name.
Amazon Search for "Nikon AF-S": http://www.amazon.com/s/ref=nb_sb_noss?url=search-alias%3Daps&field-keywords=Nikon+AF-S&x=0&y=0
This is also a good "general use" lens: http://www.amazon.com/Nikon-18-55mm-3-5-5-6G-AF-S-Nikkor/dp/B000LWJ1ES/ref=sr_1_10?ie=UTF8&qid=1298926690&sr=8-10
Hope this helps.
Feb 28, 2011 | Nikon D40x Digital Camera
The lens keeps trying to focus it zooms in and
Try jiggling the lens. Use compressed air to blow out any grit around the lens barrel. If that doesn't do it, you'll need to get the camera serviced.
Dec 02, 2009 | Nikon Cameras
Quantaray 70-300
Sounds like the aperture inside the lens is broken. You shuld send it in for service.
Aug 07, 2009 | Quantaray AF 70-300mm f/4.0-5.6 High Speed...
Digital camera got dropped into the sand, and some sand worked its way into the lens and focusing system, and now the camera cannot zoom or focus, but still turns on and takes pictures i have a lumix dmc...
THIS SOUNDS TERMINAL, BUT YOU MIGHT TRY USING CANNED AIR LIKE YOU USE TO BLOW DUST OUT OF YOUR COMPUTER, AND SEE IF IT HELPS ANY. MOST OF THESE CAMERAS ARE MADE WITH THE IDEA THAT THEY WILL NEVER BE TAKEN APART OR OPENED FOR CLEANING ETC. SO, THAT IS THE ONE PROBLEM YOU ARE FACING. I DOUBT IF IT WOULD BE WORTH SPENDING THE MONEY TO SEND IT IN TO BE CLEANED. THAT CAN GET VERY EXPENSIVE IN A HURRY, PLUS TAKE A GOOD MONTH OR MORE FOR THE REPAIR. SORRY, I CAN'T HAVE MORE CHEERY NEWS, BUT THINGS LIKE THIS JUST AREN'T TAKEN INTO ACCORD WHEN THEY MAKE THESE CAMERAS. IF I CAN HELP MORE JUST REPLY TO:
ARCLIGHT1217
Nov 04, 2008 | Cameras
All zoom pictures blurry
I am sure your lens is clean but from what you describing you have a definte problem with the lens assy which includes the autofocus sensors. Sometimes is can be a faulty focus motor , dirt between sensor and outer lens. Camera needs to be stripped and checked up.
Mar 27, 2008 | HP Photosmart R817 Digital Camera
Lens Problem
sir, replace ur image sensor,
Feb 22, 2008 | Nikon 18-70mm f/3.5-4.5G ED-IF AF-S DX...
Blury Display on FE140
It sounds like your lens's focus element is stuck. Given the events you describe it is possible that a grain of sand has worked its way into the focus motor's gearing and jammed it up. Normally the small motor moves the focus optic in and out to achieve proper focus, if its movement is limited or completely jammed you will experience blurry pictures. The camera will have to be disassembled and the sand cleaned out to restore normal function. There are repair providers you can find online who can work on your camera. David Millier Advance Camera Repair
Mar 20, 2007 | Olympus FE-140 Digital Camera
Nikon D80 Digital Camera with 18-135mm Lens Logo
44 people viewed this question
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
