Question about Samsung SF-5100 Plain Paper Laser Fax
Samsung sf5100 fax How do i replace the toner
Samsung sf5100 fax How do i replace the toner cartridge fuse
  • 76 Answers
Open front cover,then pull out toner and in the middle you will see a tiny fuse. Take it out and put a new one in. Put back toner,close everything and let it run.
Posted on Oct 06, 2009
On my samsung fax sf5100 machine there has been a new ink cartridge installe dand the machine is still asking to insatll new cartridge , do i need to tell the machine new cartridge installed if so how
you will see there is a fuse on the cartridge. replace it with a new one. it can be biger becouse you will remove it again.
put the cartrige back with other fuse and close door for 3 secons. take cartridge out and remove the fuse.
put cartrige back with out the fuse. it sould work.
the other way is to push setup and then # 1934.
push setup again check for new cartrige or egnore cartrige.
swich m/c off and on.
Aug 10, 2011 | Samsung SF-5100 Plain Paper Laser Fax
We placed 3 new toner cartridges - one after the other - and each time it still says ' Toner Empty'. We wonder if something else is broken. How can we retrieve faxes that are still in the memory prior to...
The toner empty condition resets by a little glass fuse on the cartridge. First check and be sure that you toners have a fuses. If you insert a new cartridge the fax blows this fuse (mark that happens only once) . Buy yourself only fuses (25mm / 0,063 A or 0,1 A) and mount it on the one of your cartridges.
DO NOT turn off the power of the fax to avoid loss of information.
good luck
pifonski
Mar 01, 2011 | Samsung SF-5100 Plain Paper Laser Fax
The printer samsung scx-452f cannot print out fax in,it shown on screen as memory receive
you have received faxes, but they can't be print until you replace toner because probably you have TONER EMPTY message also on the display.
You can buy only fuse for toner cartridge (25mm, 250V/ 0,063A or 0,1A and maximum 0,125A)
When you pull out toner cartridge you will see the glass fuse on the front left side of the cartridge.
The new fuse will reset toner empty condition
pifonski
Feb 28, 2011 | Samsung SCX 4521F All-In-One Laser Printer
Cr fuse error?
CR Fuse Error Samsung 4016. Replacement toner cartridge threw this error, found small glass cartridge fuse on top-front edge of cartridge, swapped fuses with my old cartridge, voila. Replacement fuse was good, had continuity, but felt to me to be slightly smaller diameter than original fuse.
Oct 15, 2010 | Samsung SF-5100 Plain Paper Laser Fax
Samsung sf-5100 fax toner empty
I have a feeling that it is a re-manufactured or compatible cartridge??
There is a fuse that needs to be replaced on this unit. it blows when the cartridge is installed to reset the machine. If the fuse has not been replaced or is defective the machine will not recognize the new unit.
Mar 05, 2009 | Samsung SF-5100 Plain Paper Laser Fax
Can't receive fax but can send fax
Feb 12, 2009 | Samsung SF-5100 Plain Paper Laser Fax
Samsung SF560 Message reads "toner empty". Replaced new toner cartidges and still get same message. have change toner in fax but getting message (jam 1) or toner empty it seems pretty common problem as...
Turn off the Machine for safety.
- Try to double check if the toner cartridge is properly installed
- Clean it also if dusty
- Make sure he sensor have no paper or dust.
Apr 15, 2008 | Samsung SF-560 Plain Paper Laser Fax
Samsung SF5100 has a loud buzzing noise
Hi there you might have a faulty toner cartridge is it a original or has it been refilled? I suggest to install a new toner cartridge and hopefully that will cure the fault. If this dosen't there maybe a small piece of paper stuck in the cartridge or after the toner cartridge within the heat section open the back of the machine (the jam door) and check there is no paper.
If the printed document is getting stuck just after the toner cartridge it will most likely to be the heat section will need replacing.
Hope this helps you and please rate me
Thanks J
Dec 31, 2007 | Samsung SF-5100 Plain Paper Laser Fax
"toner empty" problem
The samsung sf 5100 toner cartridge has a .05 Amps fuse in it. This gets blowed when you switch on the machine.This is used to reset the page counter and also to inform the machine that you have inserted a new toner. Now this recycled cartriges will not have this fuse and this is the reason why your machine shows TONER EMTY message! If you dont get the same rating fuse, put any fuse of the same size, insert the toner, close the door and just switch on the power and switch off immediately. Then take out the Toner cartridge and remove the fuse. Now your cartridge is ready for use.
Dec 06, 2007 | Samsung SF-5100 Plain Paper Laser Fax
Samsung SF-5100 Plain Paper Laser Fax Logo
133 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
