Question about HP Officejet 6310 All-In-One InkJet Printer
Paper logjam Had paperjam, released it but printer not working showing paperjam as fault. What should I do
    Scholar:
  • 81 Answers
There is a line of sensors along the paper path, if any of these are obscured by even the smallest scrap of paper you will get the messasge, re check the paper path again it only needs a scrap of paper, if you can spot any of the sensors give them a blow with some compressed air (paper dust build up), last but worth a try unplug for 2 minutes to allow residual power to drain and then try power up and see if the message has cleared
Posted on Sep 11, 2009
Paper jam printer
kindly check it what shows in the display:
"paperjam 0" , its related to pick up roller related problem.
"paperjam 1", its related to cartridge unit, kindly re inserted the cartridge.
"paperjam 2", its related fuser unit, kindly open the rear cover of printer, ther you can see the fuser unit. check the one liver from fuser unit to HVPS .
kindly check all these things and contact
Jan 29, 2014 | Samsung SCX 4521F All-In-One Laser Printer
How to deal with paperjam. The printer is not printing and is showing paperjam
Hello and Welcome to FixYa!
You have to follow the steps described by the HP in there support article here.
Be careful with the jammed paper, do not force the paper more then required that may mis-align the carriage assembly.
I hope this will help you out.
If you are having any problem/questions, do ask me.
Thank you for using FixYa!
Concerned, Nooh
Aug 17, 2010 | HP Deskjet D2360 InkJet Printer
Paperjam in hp 1000 printer
two reason in paperjam 1200 series printer
one some senser not working so remove back sight cover and clean dust help with air blower.
and paper pick roller is not working
first you remove paper pick roller
and change direction of paper pick roller
means change direction means just opposite site use.
i think solve your problem.
Apr 10, 2010 | HP LaserJet 1200 Printer
Says paper jam but NO paper is in the machine
One problem i found with those printers is that over time the casting around the paper tray is wearing off and printers starts to show paperjams when there is no paperjam.
One way to fix is try and positions the paper tray better or perhaps raising it a bit with piece of wood or paper.
Cast unfortenately is too expensive to replace so if this doesnt work and you are sure there is no paperjam and nothing obstructing the sensor then replace the printer.
Nov 02, 2009 | HP LaserJet 2200D Printer
CLX 2160 - paperjam
There is probably a jam in the paper feed area. Pull the paper tray out and stick your hand in to find and remove any paper stuck there. Then reinstall the paper tray and open and close the front door of the printer. The jam should be cleared.
If it is still showing paper jam, pull the tray out again and look to make sure you didn't miss any paper, then check the other areas of the printer (starting with the exit area) for paper.
Oct 24, 2009 | Samsung CLX-2160N All-In-One Printer
Canon irc3380i paperjam
This problem fault manual presenting the track. Follows to consider several reasons. Check the condition rubber roller seizure of the paper. Check and clean lower brake platform. Check and value the possible ragged sheet of paper. Check presence a stranger subject in giving device. Try to give the paper along on format by narrow side. Thank you, good luck!
Sep 16, 2009 | Canon C2058 Color Copier
Printer wont pull paper down then says paper jam
Dell does not make printers. They put their name on Lexmark printers.
I just repaired a 926 which had a paperjam alarm...and no paper jam. The paper sensor microswitch had been bent up onto a paper roller so the printer thought a piece of paper was stuck under it. It was hard to get the little lever off the roller and back, hanging free, without breaking it. This did not happen on its own so I can't fault the printer.
Look for this tiny black plastic lever hanging down right in the middle of the upper paper rollers, just behind where the carts run.
Jul 03, 2009 | Dell 926 All-In-One InkJet Printer
HP Laserjet P2015n error
If paper jam light is solid or printer shows paper out light solid all the time,
Then try these suggeted steps:
Take the Tray 2 out and check if all the paper guides are moving freely if they are than remove the toner cartridge and check if any toner sensor is not align correctly.
If they are aligned correctly than next to the pickup roller there is a small piece of plastic make sure it should be hanging freely if it is than we need to perform cold reset of the printer.
Switch off the printer press and hold down the go button and switch the printer on keep holding down go button till the time three lights lit up on control panel, as soon as three lights lits up release the go button and let the printer initialise of it s own.
If that doesn't fix than Formatter Board of the printer is faulty.
Logic:
If there is no paper jam and printer rep[orts the jam means either any of the sensors is not aligned correctly and reporting the jam or formatter Board(Motherboard) of the printer is faulty and showing incorrect display.
Thanks and Regards
Jun 30, 2009 | HP LaserJet P2015dn Printer
My printer says there is a paperjam but I don't see a paperjam.
its a mechanical problem ...
check the rollers of the printer ..and the paper pick mechanism ..maybe it can't caught the paper in the tray that why it display an error of jammed..
May 24, 2009 | HP DeskJet 3653 InkJet Printer
PaperJam
I found that the little plastic hinge guide that supports/aligns the scanning area with the printer (stage 4 on the internal paper jam problem) was misaligned. I just removed it and the printer now works OK
Aug 28, 2008 | Samsung CLX-2160N All-In-One Printer
HP Officejet 6310 All-In-One InkJet Printer Logo
144 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
