I have a problem with my Sony Trinitron Color TV ModelKV-EF29 M91. The Power Unit/Power Regulator was burst with a good bang and one or two Resistences nearby to it are out of order. The correct values of the resistences are not known and no circuit diagram of this model TV is available with the repairer. I would be gratelful if you can send me a copy of the entire circuit diagram or the circuit diagram of the Power Unit by email or fax urgently for which I would be ever grateful to you. Thanks.My email add: pks_vasan@hotmail.com Fax No. (Maharashtra, India) 0251-2230356
  • pks_vasan Sep 12, 2009
    Thanks for your reply.
    I checked and confirm the TV model is KV-EF29 M 91. The Operation Instruction Manual also says that both models KV-EF29 M91 and KV-EF29 M80 are same to each other for operation.
    Thank you once again.
    PK Srinivasan
  • tvtechlady May 11, 2010
    I went on the sony web site and your model is not listed the closes I could get to it is kvef29n6p could you check the model number again to see if it is correct.
Sony model kvef 29m91 trinitron tv i need remot condrol model no
Posted on Nov 24, 2012
  • 1340 Answers
SOURCE: I have Sharp 20V-L80M, Power
I have tried numerous times and the TV manufacturers will not sell parts or diagrams to consumers.You have to be a repair shop with a username and password just to view the stuff.Here is one possibility.
http://www.eserviceinfo.com/most_wanted_link.php?what=list&requestid=44394
I will try for others...hang on please.Here is another possibility.All I usually find is user's manuals which are free few and far between.Schematics just aren't out there.
http://esupport.sharp-cee.com/html/om/index.php?ProdLine=40&TemplateLang=en
Sorry to have to tell you that.I like to fix my own stuff too.There is nothing more I can suggest with all the limited access.Good luck!Maybe if you take the regulator out and ask a shop?
Posted on Aug 02, 2010
SOURCE: Albatron LNX-21TIS-3 lcd tv does not power
I just fixed my Albatron LNX-21TIS-3.
The power supply had gone out so I took an ATX computer power supply and changed the plug.
The Albatron runs on 12V and 5V just like the ATX computers. The trick is to find a power supply that is the same size then you just modify the wires on the power plugs to match up.
Posted on Apr 15, 2008
  • 92 Answers
SOURCE: User Manual for Sony Trinitron KV-25DA55
try downloading from sony.com
Posted on May 20, 2009
AJIN G
  • 6694 Answers
SOURCE: i want circuit diagram of
hi,
i have the circuit diagram with me . if u contact me through fixya, i will send u the schematic diagram
ok
Posted on Jan 11, 2011
vinceisaac
  • 2432 Answers
SOURCE: can you send me the
hi click this link www.scribd.com/doc/2964180/Training-Toshiba-PLASMA-TV-PDP-42WP37 actually is not exactly the circuit diagram for the model that you are looking for but this training manual is for 42wp plasma series with block diagram for main board and power supply that maybe your guide in locating the problem that you are looking for. however you can also ask or consult the problem with your unit i'm glad to help you.hope this may help thanks for consulting through fixya service.
Posted on Jul 29, 2011
What is the code for a 2001 Sony Trinitron?
Search Results
    Sony eSupport - Remote Control Codes & Programming ...
    https://esupport.sony.com/.../select-system.pl?...RCOD...
    Sony CorporationFind the codes you need to program your remote control. ... Television - Accessories; Television - FD Trinitron® & WEGA™; Television - Internet TV & Players ...
    [PDF]Trinitron Color TV - Manuals, Specs & Warranty - Sony
    https://docs.sony.com/release/KV20FV12.PDF Sony CorporationRefer to section 54-300 of Canadian Electrical Code for Antenna Grounding. Lightning .... Congratulations on your purchase of the Sony Trinitron Color TV.
Dec 08, 2015 | Sony Televison & Video
TV emits single, loud pop when turned on cold.
It sounds that any electrolytic capacitor at its main power regulator section have bursted out, due to a over-voltage. Contact any service technician. To get more details, http://electronicshelponline.blogspot.com/
Nov 14, 2013 | Sony FD Trinitron WEGA KV-32FS100 32" TV
Sony Wega Trinitron TV image has shrunk?
Check its main power regulator section circuit for any loose solder terminals. Low power regulator voltage output is the problem to your TV.
Nov 19, 2012 | Sony FD Trinitron WEGA KV-32FS120 32" TV
110 sony flat tv was plugged in 220
change the regulator of your tv and check also the resistor value 2.2 5 watts or lower value.
May 09, 2009 | Sony FD Trinitron WEGA KV-21CL10 21" TV
Intermitant color bursts of red, green, purple
Kevin,
for the color problem,most likely you do have problem with loose contact of components from C-board ( small board connected at the back of CRT "picture tube" which drives every color and size of the screen)if you have knowledge with soldering electronic component parts, resolder this board and also check main board for possible loose contact.
cheers,
mark
Feb 04, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
COLOR TONE NOT WORKING
ntsc and pal is just systems for processing your antenna signals weather be cable or outside, the color or tint circuits are downstream of this. tint is the phase adjustment of a color burst that rides on the horizontal sync pulse before it hits your color amplifiers. Ntsc is US and Canada, Mexico, basicly a Western standard here.
Jan 23, 2009 | Sony FD Trinitron WEGA KV-21CL10 21" TV
Sony Trinitron 27V42
And it probably won't - - A common problem for this unit is regulator failure caused by one or more instabilities in the SMPS...
Are you any good at replacing caps?? If so check C633 located next to Ic600 and test it for open.. If open replace it and that should restore unit to normal operation. If it's not open you probably have a regulator failure and my advice would be to take it to a qualified shop for the repair...
Bill
Nov 19, 2007 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Sony WEGA 36" Trinitron HD
Check for unit posting any blink codes on the timer LED. Google "sony blinking codes" for the explanation. Try turning unit off for 4 hours to force a hard reset of your set, you need to unplug it. Sounds like a low voltage problem in the HV circuit.
Oct 29, 2006 | Sony FD Trinitron WEGA KV-32HS510 32" TV
Televison & Video Logo
118 people viewed this question
Top Televison & Video Experts
