Question about Hitachi 53SWX12B 53" Rear Projection Television
No sound on analog inputs, digital sound is ok
My 5+ year old 53SWX12B recently lost all sound coming in across any of the line inputs, including the front panel. However, sound is working through the TOSLink, the coaxial digital, and when using the internal tuners.
Before going out completely, it would come on ok, play for about 10 minutes, then go out. Turning the unit off for 30 seconds then back on fixed it, and then it would play for hours with no problem.
Any ideas where to look? I'd at least like to be sure what board to attack first with an iron, if it's just a cold joint. I have no reference materials on this TV. Naturally, it went out of extended warranty about 9 months ago.
Picture is great. Convergence is fine. Just lost sound on 3 of the 5 inputs, which sucks.
  • 1,153 Answers
Re: No sound on analog inputs, digital sound is ok
1) IT02 Shorted, pins 92 and 93
Cause: Solder splash
2) IT05 pins 20 & 21 shorted.
Cause: Seems to have been cause by too much solder.
3) IT02 was found to be defective.
Cause: Defective component.
4) IS11 missing circuit trace.
Cause: Caused by some one that replaced/removed this IC previously.
5) IT02 solder, pins 42, 43 & 44
Cause: Two boards found with these same pins with cracked solder
6) IS13, pins 1 & 2 shorted
7) Audio Quits when board is tapped.
Cause: Soldered all IC's on bottom of board. Also soldered IT04, I516, I517, I510, I501.
8) Also, please resolder IT05 and IT06
9) Check for cracked patterns under IT05
Posted on Dec 10, 2007
0 characters
3 Points
Green Lines on Samsung DLP
Either bad capcitors, or (if you're lucky) the color wheel needs lubed up. Probably bad caps.
Jun 12, 2012 | Samsung Projection Televisions
Hitachi 53SWX12B: Sound goes out for a while, then comes back on
A bad solder on the TV cause of external overheating of the Television..
Mar 12, 2008 | Hitachi 53SWX12B 53" Rear Projection...
I have audio cables going from HD 61g887 jvc tv, to my phillips surround sound system under aux but it is not giving me sound?
you didn't mentioned the model number of your surround sound system, for a better solution its important. any why try the following.
if you are connected the analog audio output of your tv to the system using RCA cable, then go to the setup of the surround sound system and change the input assignment setting from digital to analog.
If your connected the digital output of your tv to the digital input of your surround system using optical cable then, goto the setup of your surround system and change the input assignment to digital (optical) input.
if u need any further assistance fell free to contact through fixya
Jan 20, 2011 | JVC HD-61G787 61" Television
I have 65 inch pro elite 710hd 6 years old. Do I have to get analog box
Yes you still have to get digital to analog converter. Although you can feed a hd signal through the component inputs, the tv is still set up to only receive analog signals through the coaxial input
hope this helps
Jan 14, 2011 | Pioneer PRO-710HD 64" Rear Projection...
Samsung 50 HLN5065WX has wavy lines on analog input
this is an inherit problem of this set - - search 'wavy line' and you'll see many samsung sets have this - there is no cure ! use the set with component or hdmi good luck
Jul 16, 2010 | Samsung SP50L6HX 50" DLP HDTV
Black line across screen
module problem take it to a Authorized dealer or a NESDA dealer service manuals hard to say if available since analog TVs are slowly going away and parts well another story might as well go buy a new HDTV set as a CET no garuntee how long it will be analog TV parts will be discontinued. FCC has alot to do with it.
Apr 16, 2009 | Projection Televisions
DLP Colors Are Off - Picture Is Mostly Blue and Yellow
Sounds like you've lost your red video signal (chroma) somewhere along the line. This tv has a 3 board video path. Analog main pcb --->Digital main pcb --->DMD pcb. The analog has all your inputs on it, except DVI and RGB which go straight into the digital board. The digital scales (upconverts) the signal to HD (1080 or native) and sends it to the DMD or light engine. See which inputs are distorted. If only DVI is clean then you problem is the analog board. If you menu and everything is distorted then suspect the DMD board. If you run component or DVI through the resolutions (480i, 480p, 720p, 1080i) you can get an idea between the digital board and dmd. The menu is generated on the digital board. Somewhere red is getting lost.
Dec 08, 2008 | Samsung HLN5065W 50" Rear Projection...
Green Plaid then Vertical Lines, Failure of hard controls, Analog Board?
You are absolutely correct, When anyone complains of vertical lines or bars, the next step is to see if it happens on only digital inputs ( digital board ) , only analog inputs ( analog board ) , or both ( DMD board ) .
Analog board can be purchased at ,
Jun 04, 2008 | Samsung HLR5067WX 50" Rear Projection HDTV
Hitachi 53SWX12B 53" Rear Projection Television Logo
70 people viewed this question
Top Hitachi Projection Televisions Experts
Jaime Hernandez
matt martin
matt martin
Are you a Hitachi Projection Television Expert? Answer questions, earn points and help others
