Have lost sound on pc all cables & wires seem ok but pc says no audio connected
  • stansfiel154 Sep 12, 2009
    Have tried this but message comes up "Unable to load device manager programme file devmgr.dll"
  • 115 Answers
Reinstall your sound drivers and check device manager for any yellow marks on them
you can find device manager by right click on my computer -properties
Posted on Sep 11, 2009
How to connect receiver to TV for sound
Does the TV have an audio ear phone jack? if it does get an audio jack that fits the TV Audio out Phone plug. Then connect it to an Audio Amplifier that would run the speakers.
This is one way...or you can solder onto the speaker weirs and run that to the audio amp that is connected to the wall spekers.
Feb 03, 2014 | Audio Players & Recorders
Hi i have connected all the cables up correctly & have it all working except i have some sort of interferance coming through.i have a contant crackling & on & off buzzing sound,sound like...
First thing: Make sure ALL and I do mean ALL of your interconnected equipment is POWERED from the SAME receptacle. Powering different parts from different receptacles in a building will surely get ground bounce buzz and ALSO subject the equipment to hazards of circuit damage.
The audio connecting cables should be BALANCED lines where possible... either XLR or TRS cables. Problems like you are having are common when CONSUMER grade equipment is mixed with PROFESSIONAL equipment. Anyway, get all the stuff powered from the same receptacle and get back to me if you still have the problem. Note you may have to run three wire extension cords if devices are separated a bit... the pro's have to do that to avoid noise. All devices should have three wire (grounding) cords and/or grounding wires connecting chassis...
Jul 16, 2011 | Mixvibes U-Mix 44 4-in 4-out USB Audio...
APX400.4M. 12 volts on.... Power LED on....fuse OK...but no sound...not even a hiss from the speakers
Make sure that your speaker cables are connected properly and that the amp is not in protection mode. Also make sure that the amp ground wire is connected solidly to the vehicle chassis in a paint-free location. If you do all of that and it still doesn't work, make sure the head unit lead is connected correctly to the amp (these should be RCA cables).
Feb 27, 2011 | Clarion APX400.4M Car Audio Amplifier
MTX Thunder 3401 not responding. Lit but no sound.
turn down music open sub box and put another speaker at wire and check again if work means sub is ok if not check the signal cable, and put there the speaker to try signal
Apr 05, 2010 | MTX Thunder 3401 Car Audio Amplifier
HP Compaq 6720s Sound problems!!!!
pls. check the internal speaker audio cable is ok or not. and also check the audio cable is connected on the audio section of motherboard.
Feb 16, 2009 | HP Compaq 6720s Notebook
AMPLIFIER NOT WORKING
With your multimeter set to DC volts, the black meter lead on the ground terminal of the amp (not on the point where the ground wire connected to the vehicle) and the head unit on (so the amp will have remote voltage applied), touch the red lead alternately to the B+ and remote terminals of the amp. If the voltage is below ~11 volts, you need to check the wiring feeding whichever line is too low.
Aug 19, 2008 | JBL GTO75.4 Car Audio Amplifier
No sound coming from monitor when sound icon indicates up high
Check audio cable connected correctly, then check the monitor menu for sound settings are correct. If that all seems OK, plug in some external speakers to check if soundcard is functioning.
Mar 02, 2008 | Acer Aspire™ T180 PC Desktop
Amp is on, Subwoofer works, but no sound.
here is a short test you can try, remove the rca audio cable from the amp & connect a diskman or toher audio o/p device that you can hook up with the same rca wires, turn on the amp & see if you have sound. you can also remove the speaker wires from the sub & using multi meter read the ohm's of the sub, most subs are 4 ohm. Hope this help locate your problem
Oct 24, 2006 | Pioneer GM-7200M Car Audio Amplifier
 Grubhead
Grubhead
