How can i switch the powersuply on with out
How can i switch the power supply on with out connecting it to the motherboard
  • Chris Hingee
    Chris Hingee May 11, 2010
    Why are you trying to do this, I cannot follow your logic? The switch mode power supply is powered on by sensing contact switch on the motherboard. Are you trying to use the ATX switch mode power supply as a 12V and/or 5V power supply for a project without connecting it to a motherboard? Please let me know what you are trying to do.
  • 2,418 Answers
Most newer computers will have to be hooked to the MB to recive the signal to power up.
Posted on Sep 11, 2009
Intel fw82801db
on your board theres is a spot where the fan from the cpu goes it saids cpu fan on the board near by cpu socket
Aug 06, 2013 | Asrock Computers & Internet
My computer did not start when i tryied to turn it on, so i pushed the red butten to the side at my power suply and tryied again ther was a loud bang from the powersuply and ther was smoke comming out from...
The only thing to do at this point is to replace the Power Supply with a KNOWN to be good, compatible unit, and see if the rest of the computer hardware components are okay.
Going by your information stated that the Power Supply is an Enhance ENP-2224B SMPS, (Switched-Mode Power Supply), it is a special shape.
If it wasn't for the Slim Micro-ATX computer case you have, you could use an easy to obtain ATX form factor Power Supply.
From a quick search though it looks like a replacement unit is affordable,
http://www.censuspc.com/Enhance-ENP-2224B-2G-240W-SATA-TFX12V-P4-Power-Supply-for-Slim-microATX-Desktop-Case-Serial-ATA-Ready-bulk-pack-SKU-ENP-2224B-2G-pr-3033.html
There is simply no way to tell if the motherboard, and/or Processor, and/or Ram Memory, and/or Harddrive, etc., is okay without having power.
Unless you transfer the components on the motherboard to another working motherboard.
[NOTE*
If your Power Supply has a rocker switch on the back that lets you use 120 volts, or 220 volts, make SURE it is set to the right voltage.
USA?
120 Volts
Europe?
220 Volts
Australia?
220 Volts
Japan?
100 Volts ]
For additional questions please post in a Comment.
Regards,
joecoolvette
Jun 26, 2011 | Enhance Technology ENP-2224B, Enhance 240W...
There is no power switch on the enhance atx 1123b that I have . What actually powers it up?
Just about every power supply I've owned doesn't have a power switch. The power supply is turned on by one of the wires in the 24 pin connector. According to this it looks to be pin 16 and how to turn it on:
"Short this pin to GND to switch power supply ON, disconnect from GND to switch OFF."
Hope this helps
Ray
Mar 01, 2011 | Enhance Technology ATX-1123B, Enhance...
My old power supply had 4 wires going to the front panel on\off switch. The Dynex power supply does not support the switch. what do I use to turn the unit on or off. Will the unit function with out the...
Normally the front panel on/off power button and the front panel reset button plug into connector pins on your motherboard.
If you can find a User Manual for your motherboard it will show you exactly where the switch leads plug in on the motherboard. The motherboard's manufacturer and model number will be printed on the board somewhere.
Good luck.
Feb 05, 2011 | Dynex DX-400WPS 400-Watt Power Supply
So i bought a new graphic card, its a sapphire HD 5870 vapor-x 1gb gddr5. after much problems with putting it into the case (the card is very big) i get no picture on the monitor from it, a friend said my...
You can use just about any WATT power supply. The demand of wattage is limited to the use of each item that the computer needs to operate correctly. So you can't blow out your system if you install everything correctly and properly. So you could install a 1Giga Watt with safety. Make sure that the power supply that you get fills the needs of your video card.. Reference the video card box for the proper Power supply..
Thank you for your visit to Fixya.com
Dec 06, 2010 | Foxconn G31MX-K socket LGA775 motherboard
I want to buy Cobalt Qube 3 Power Supply
google for it in your area or buy on the net
maby ebay be sure the powersuply are not broakdown
ben.pluijm@viveole.com
Aug 19, 2009 | Computers & Internet
W2686 eMachine doesnt turn on after changing powersupplies
hi im josh in cebu phils.may i help you? Friend if the pc does'nt power on even you have replace the power supply. it means that there is a major problem in your hardware definetly if not the power suppy the motherboard or the processor.be sure to have compatible mainboard and processor because there are mainboard that does'nt support a certain processor please try to check it .try to replace another motherboard that is compatible to your processor. or check the connection of the power on button and the wires from supply to motherboard.please do that to solve your problem hope i helped you good luck.
Feb 25, 2009 | E-Machines eMachines W2686 PC Desktop
Intel d845gvsr m/b did not power on with good powersuply
Hello, make sure that the power supply is propertly connect to the mobo and look for the cmos jumper and try moving it, also take out the cmos battery and wait 2 minutes. Thanks let me know if it helps.
Nov 26, 2008 | Intel D845GVSR Motherboard
No power up no post no nothing on dimension 3100
An Amber blinking power button indicates a low voltage problem. This can be caused by a defective power supply or a defective motherboard. It sounds like you have isolated the problem to the motherboard since you removed everything but the board and power supply. You may be able to locate one by browsing the internet. Just type in “DELL Dimension 3100 motherboard” and see if you can locate one at a reasonable price.
Your responses are intended to improve the level of service provided. Please rate your experience.
Thank You
Sep 27, 2008 | Dell Dimension 3100 PC Desktop
Computers & Internet Logo
46 people viewed this question
David Payne
David Payne
