Question about ASUS Eee PC 701 Notebook
I dropped my asus and now it will not switch on or off and will not charge up
  • 31 Answers
It depends on which side did it fell ... if one of the corners.. it might be the motherboard.
If you are good at opening and closing electronic devices, you can open it and check for any loose cables or components (make sure you unplug the battery+charger before you start)
Also, check if your charger is working or try different one if you can.
It might only be that the power cable came off with the chock. it's worth trying.
hope this helped thanks
Posted on Sep 11, 2009
Why does my asus notbook not turn on and is blank?
Sounds like the battery is completely flat.
Ensure your charger is plugged into the mains socket and plug into your notebook. Leave to charge for about an hour, then it should switch on.
When you have finished using it, make sure it is shut down correctly and leave it charging over night for a full charge. (When it is switched on whilst charging, it takes much longer to charge.)
Jun 24, 2014 | ASUS B50A-B1 (90NQ9A1232244EQL150YB50AB1)...
Asus tablet want turn on or off
does it show charging when connected ,
if yes then
there is a very tiny reset hole with switch on the side clik it an hold 10 sec it will likely wipe some changes.
if not charging then its dead jim.
May 07, 2014 | ASUS Tablets & eReaders
Tf201 keyboard won't charge
I had same problem. I had a look at the connection. I took the two sections of the black charging plug, inside there were two steel pins. They looked a bit bent in towards each other, so I gently bent them a bit outwards. It worked. I have had no further problems charging. But I have another problem. It is fully charged, but will not switch on. I have an Asus tf300t.
Oct 06, 2013 | ASUS Eee Pad Transformer Prime TF201 10.1"...
Battery won't charge above 5%
If the laptop battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all. OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time. If the battery drops to an unacceptable charge level then the battery needs to be replaced. Rechargeable batteries will fail if stored in a discharged state for long periods.
Mar 18, 2013 | ASUS Eee PC 1000HD Notebook
Battery is not working
Jan 13, 2013 | ASUS U50F Notebook
My Computer Kepps Turning off!
Aug 15, 2012 | ASUS Computers & Internet
Asus short battery life
If thelaptop battery is more than 3 - 4 years old then the battery could be worn out.Rechargeable batteries have a finite number of charge and discharge cycles andwill lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up at all. OR Thebattery shows a 100% charge but when the adapter is disconnected the batterydrops off to zero capacity in a very short time. If the battery drops to anunacceptable charge level then the battery needs to be replaced.
Feb 21, 2012 | ASUS Computers & Internet
Asus A626 won't charge.
Power supply problems are relatively common with ASUS products like this one it should be covered under warranty and be easily replaceable if not simply order one online.
(it is rare for the device itself to have charging issues, unless it was dropped in which case that could be a possible explanation)
Mar 01, 2011 | ASUS MyPal A626
Am using sony ericssion mobile model no. is w760a AT&T, from last two day am connecting charger, but its charging asusally, after i disconnect charger is showing battery empty..
Ifthe sell phone battery is more than 3 - 4 years old then the battery could be wornout. Rechargeable batteries have a finite number of charge and discharge cyclesand will lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up atall. ORThe battery shows a 100% charge but when the adapter is disconnected thebattery drops off to zero capacity in a very short time. Ifthe battery drops to an unacceptable charge level then the battery needs to bereplaced.
Feb 24, 2011 | AT&T Cell Phones
Our Asus Eee Pc 4G doesn't want to recharge battery. Why?
Hi sammykea,
Ok so you have a ASUS EEEPC and you don't have a copy of the manual.
To get a copy of the manual just goto this link:
http://support.asus.com/download/download.aspx?SLanguage=en-us
Just click on the drop down "Select Product" and choose EEE FAMILY, then go next to the drop down for "Select Series" which is EEE PC then last drop down "Select Model" choose your model. It will then bring you to the next page which has the link to download the Manual for the PC just pick the language of the manual you need, and download it and read the manual for more details on how to use the PC.
Hope this helps!
Peace! :)
Oct 19, 2008 | ASUS Eee 4G Notebook
ASUS Eee PC 701 Notebook Logo
103 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
